大数据技术HDFS之Shell指令
人工智能-张晨光 发表于 2024/02/15 08:49:23 2024/02/15
【摘要】 hdfs dfs -ls和linux的命令差不多hdfs dfs -查看相关帮助命令hadoop dfs -ls /hadoop fs -ls /版本不同创建目录hdfs dfs -mkdir -p /aaa/01/02hdfs dfs -lsr /aaa会看到01 02二.使用dfs创建文件查看文件结果echo "hello,zhangChenguang">>localfilehdfs d...
hdfs dfs -查看相关帮助命令
hadoop dfs -ls /
hadoop fs -ls /
版本不同
创建目录
hdfs dfs -lsr /aaa
会看到01 02
二.使用dfs创建文件
查看文件
结果
hdfs dfs -appendToFile localfile output3/file2
一直报错:
Failed to replace a bad datanode on the existing pipeline due to no more good datanodes being available to try. (Nodes: current=[DatanodeInfoWithStorage[192.168.80.131:50010,DS-ae4d2aae-49b9-4d3f-bbf1-a255217746b8,DISK], DatanodeInfoWithStorage[192.168.80.132:50010,DS-2e26c66c-f173-489a-af5c-671377ec4eae,DISK]], original=[DatanodeInfoWithStorage[192.168.80.131:50010,DS-ae4d2aae-49b9-4d3f-bbf1-a255217746b8,DISK], DatanodeInfoWithStorage[192.168.80.132:50010,DS-2e26c66c-f173-489a-af5c-671377ec4eae,DISK]]). The current failed datanode replacement policy is DEFAULT, and a client may configure this via 'dfs.client.block.write.replace-datanode-on-failure.policy' in its configuration.
    at org.apache.hadoop.hdfs.DataStreamer.findNewDatanode(DataStreamer.java:1281)
    at org.apache.hadoop.hdfs.DataStreamer.addDatanode2ExistingPipeline(DataStreamer.java:1351)
    at org.apache.hadoop.hdfs.DataStreamer.handleDatanodeReplacement(DataStreamer.java:1539)
    at org.apache.hadoop.hdfs.DataStreamer.setupPipelineForAppendOrRecovery(DataStreamer.java:1440)
    at org.apache.hadoop.hdfs.DataStreamer.run(DataStreamer.java:708)
一个是节点原因,新建不报错,但是追加报错:
最后发现解决办法,在hdfs-site.xml增加内容
<property>
    <name>
        dfs.client.block.write.replace-datanode-on-failure.enable
    </name>
    <value>true</value>
    </property>
    <property>
    <name>
    </name>
    <value>never</value>
    </property>
hdfs dfs -cat output3/file2
19/06/25 00:00:22 WARN util.NativeCodeLoader: Unable to load native-hadoop library for your platform... using builtin-java classes where applicable
hello,HDFS
hello,HDFS
拷贝命令
查看结果
3. 文件的移动
移动并改名
4. 上传文件
5. 拷贝命令
6. 下载命令
7. 查看HDFS的文件内容
-text|tail|cat三种方式分别试验
8. 文件大小列举
9. 删除指定文件
-rm
10. 删除指定的目录
