学习 华为云 API exporler python方式 第一天
学习使我快乐哇咔咔 发表于 2024/01/28 16:38:13 2024/01/28
【摘要】 import jsonimport timeimport yamlimport argparsefrom huaweicloudsdkims.v2 import *from huaweicloudsdkevs.v2 import *from huaweicloudsdkecs.v2 import *from huaweicloudsdkcore.exceptions import excep...
import json
import time
import yaml
import argparse
from huaweicloudsdkcore.exceptions import exceptions
from huaweicloudsdkims.v2.region.ims_region import ImsRegion
from huaweicloudsdkevs.v2.region.evs_region import EvsRegion
from huaweicloudsdkecs.v2.region.ecs_region import EcsRegion
from huaweicloudsdkcore.auth.credentials import BasicCredentials
ak = "UCJEM0YMIIEGCS3SGW4R"
sk = "ueyWtMjX5o9KBbQkFKPWx14Jkiqbq4VQ2EQjacfn"
region = "cn-north-4"
dev_server_id = 'cb13603f-f736-4d00-bb06-0c56f13ca288'
def ShowServer(server_id: str):
    credentials = BasicCredentials(ak, sk)
    client = EcsClient.new_builder().with_credentials(credentials).with_region(EcsRegion.value_of(region)).build()
    try:
        request = ShowServerRequest()
        request.server_id = server_id
        response = client.show_server(request)
        print(response)
        return response
    except exceptions.ClientRequestException as e:
        print(e.status_code)
        print(e.request_id)
        print(e.error_code)
        print(e.error_msg)
        return e.status_code, e.request_id, e.error_code, e.error_msg
def ListImages():
    client = ImsClient.new_builder().with_credentials(credentials).with_region(ImsRegion.value_of(region)).build()
    try:
        request = ListImagesRequest()
        response = client.list_images(request)
        print(response)
        return response
        print(e.request_id)
        print(e.error_code)
        print(e.error_msg)
def CreatePostPaidServers(name: str, flavor_ref: str, image_ref: str, volumetype: str, vpcid: str, subnet_id: str):
    try:
        request = CreatePostPaidServersRequest()
        # SATA: 普通IO磁盘类型。
        # SAS: 高IO磁盘类型。
        # SSD: 超高IO磁盘类型。
        # GPSSD: 为通用型SSD磁盘类型。
        # co - p1: 高IO(性能优化I型)。
        # uh - l1: 超高IO(时延优化)。
        # ESSD: 为极速IO磁盘类型。
        # GPSSD2: 通用型SSD
        # V2磁盘类型。
        # ESSD2: 极速型SSD
        # V2磁盘类型。
        rootVolumeServer = PostPaidServerRootVolume(
            volumetype=volumetype
        listNicsServer = [
            PostPaidServerNic(
                subnet_id=subnet_id
        serverbody = PostPaidServer(
            flavor_ref=flavor_ref,
            image_ref=image_ref,
            name=name,
            nics=listNicsServer,
            root_volume=rootVolumeServer,
            vpcid=vpcid
        request.body = CreatePostPaidServersRequestBody(
            server=serverbody
        response = client.create_post_paid_servers(request)
        print(response)
        return response
        print(e.request_id)
        print(e.error_code)
        print(e.error_msg)
def ListServersDetails():
    try:
        request = ListServersDetailsRequest()
        response = client.list_servers_details(request)
        print(response)
        return response
        print(e.request_id)
        print(e.error_code)
        print(e.error_msg)
def DeleteServers(server_id: str):
    try:
        request = DeleteServersRequest()
        listServersbody = [
            ServerId(
                id=server_id
        request.body = DeleteServersRequestBody(
            servers=listServersbody,
            delete_volume=True,
            delete_publicip=True
        response = client.delete_servers(request)
        print(response)
        return response
        print(e.request_id)
        print(e.error_code)
        print(e.error_msg)
def ShowVolume(volume_id: str):
    client = EvsClient.new_builder().with_credentials(credentials).with_region(EvsRegion.value_of(region)).build()
    try:
        request = ShowVolumeRequest()
        request.volume_id = volume_id
        response = client.show_volume(request)
        print(response)
        return response
        print(e.request_id)
        print(e.error_code)
        print(e.error_msg)
def ListServerInterfaces(server_id: str):
    try:
        request = ListServerInterfacesRequest()
        response = client.list_server_interfaces(request)
        print(response)
        return response
        print(e.request_id)
        print(e.error_code)
        print(e.error_msg)
if __name__ == "__main__":
    parser = argparse.ArgumentParser()
    sub = parser.add_subparsers(dest='command')
    sub1 = sub.add_parser('create')
    sub1.add_argument('-i', '--input', type=json.loads)
    sub2 = sub.add_parser('get')
    sub2.add_argument('-n', '--name')
    sub2.add_argument('-o', '--output')
    sub3 = sub.add_parser('getall')
    sub3.add_argument('-o', '--output')
    sub4 = sub.add_parser('delete')
    sub4.add_argument('-n', '--name')
    args = parser.parse_args()
    print(args)
    if args.command == 'create':
        print(args.input)
        dev_info = ShowServer(dev_server_id)
        print(dev_info)
        dev_info = dev_info.to_dict()
        name = args.input['name']
        flavor_ref = dev_info['server']['flavor']['id']
        image_ref = args.input['imagename']
        # image_ref = '02a17486-1214-4e42-8da7-7d200cac585e'  # Centos 7.9 64bit
        volumetype = ShowVolume(dev_info['server']['os_extended_volumesvolumes_attached'][0]['id']).to_dict()['volume']['volume_type']
        vpcid = dev_info['server']['metadata']['vpc_id']
        subnet_id = ListServerInterfaces(dev_server_id).to_dict()['interface_attachments'][0]['net_id']
        new_server_id = CreatePostPaidServers(name=name, flavor_ref=flavor_ref, image_ref=image_ref, volumetype=volumetype, vpcid=vpcid, subnet_id=subnet_id).to_dict()['server_ids'][0]
        print(new_server_id)
        time.sleep(10)
        print(str(ShowServer(new_server_id)))
    elif args.command == 'get':
        args_name = args.name
        args_output = args.output
        resp = ListServersDetails().to_dict()
        for i in resp['servers']:
            if i['name'] == args_name:
                with open(args_output, 'w') as f:
                    f.write(str(ShowServer(i['id'])))
                print('break')
                break
    elif args.command == 'getall':
        with open(args.output,'w') as f:
          f.write(yaml.dump(ListServersDetails().to_dict()))
    elif args.command == 'delete':
                print(str(DeleteServers(i['id'])))
                print('break')
                break
