学习利用python写 k8s 第一天笔记
学习使我快乐哇咔咔 发表于 2024/01/28 16:28:53 2024/01/28
【摘要】 import randomfrom kubernetes import client, config, watchtry:    config.load_kube_config('kube_config')    k8s = client.CoreV1Api()    w = watch.Watch()    for event in w.stream(k8s.list_namespaced...
import random
try:
    w = watch.Watch()
    for event in w.stream(k8s.list_namespaced_pod, namespace='default', timeout_seconds=6000):
        o = event['object']
        # print(str(event))
        # print(o.spec.node_name,o.status.phase)
        # print(k8s.read_namespaced_pod(o.metadata.name, 'default'))
        # print(o.status.phase, o.spec.node_name, type(o.status.phase), type(o.spec.node_name))
        # print(o.status.phase == "Pending" or o.status.phase == "Running", o.spec.node_name is None)
        if (o.status.phase == "Pending" or o.status.phase == "Running") and o.spec.node_name is None:
            # print(o.metadata.name)
            nodes = []
            for i in k8s.list_node().items:
                for n in i.status.conditions:
                    if n.status == 'True' and n.type == 'Ready':
                        nodes.append(i.metadata.name)
            nodes = random.choice(nodes)
            # print(nodes)
            t = client.V1Binding(
                metadata=client.V1ObjectReference(name=o.metadata.name),
                target=client.V1ObjectReference(kind='Node', api_version='v1', name=nodes)
            try:
                resp = k8s.create_namespaced_binding('default', body=t)
                print(str(resp))
            except:
                pass
            print(k8s.read_namespaced_pod(o.metadata.name,'default'))
except Exception as e:
    print('err')
    print(e)
print('end')
print('master')
