【案例】存储过程慢
给他提单,致命单 发表于 2024/01/14 13:43:24 2024/01/14
【摘要】 查询活跃会话定位到存储过程select * from pgxc_stat_activity where state = 'active' and query like '%%' and usename not in ('omm', 'Ruby');2.根据queryid查询等待视图select * from pgxc_thread_wait_status where query_id=xxx...
  1. 查询活跃会话定位到存储过程
2.根据queryid查询等待视图
select * from pgxc_thread_wait_status where query_id=xxx;
等待视图中未发现持锁
3.通过lwtid打堆栈
gstack lwtid;
持续观察堆栈情况,该堆栈内容持续变化,说明当前非死锁。是业务慢导致。
4.对涉及到的表做analyze,拼接analyze命令
select 'analyze ' ||schemaname|| ‘.’ ||tablename || ';' from PG_TABLES where tableowner in (xxx);
5.该集群已开启TOPSQL,开启TOPSQL子查询功能
gs_guc reload -Z coordinator -N all -I all -c "enable_track_record_subsql = on"
6.查询实时TOPSQL,找到该存储过程
\x
select * from pgxc_wlm_session_statistics where query like '%%';
7.根据queryid查询实时TOPSQL,观察存储过程子语句中执行时间过长的语句
select * from pgxc_wlm_session_statistics where queryid = xxx;
8.观察到有not in 这种效率不佳的写法,建议改为not exist。
