Spring Cloud 集成Seata分布式事务(Seata+Nacos+OpenFeign)
王二蛋! 发表于 2024/01/06 19:37:50 2024/01/06
【摘要】 环境搭建 Nacos搭建最新版本快速搭建 使用Mysql模式Nacos直接启动即可。控制台默认账号密码是nacos/nacos,Mysql账户密码有两个 root/root 和 nacos/nacos。 Seata搭建Seata版本1.5.0 快速搭建Seata1.5.0版本直接是一个SpringBoot项目,下载后修改application.yml 文件中注册中心、配置中心、存储模式...
环境搭建
Nacos搭建
最新版本快速搭建 使用Mysql模式
Seata搭建
Seata版本1.5.0 快速搭建
Seata1.5.0版本直接是一个SpringBoot项目,下载后修改application.yml 文件中注册中心、配置中心、存储模式配置。参考resources/application.example.yml 文件 ,修改后如下
server:
  port: 7091
spring:
  application:
logging:
  config: classpath:logback-spring.xml
  file:
    path: ${user.home}/logs/seata
  extend:
    logstash-appender:
      destination: 127.0.0.1:4560
    kafka-appender:
      bootstrap-servers: 127.0.0.1:9092
      topic: logback_to_logstash
console:
  user:
    username: seata
    password: seata
seata:
  config:
    # support: nacos, consul, apollo, zk, etcd3
    type: file
  registry:
    # support: nacos, eureka, redis, zk, consul, etcd3, sofa
    type: nacos
    nacos:
      application: seata-server
      server-addr: 127.0.0.1:8848
      namespace:
      group: SEATA_GROUP
      cluster: default
      username: nacos
      password: nacos
      ##if use MSE Nacos with auth, mutex with username/password attribute
      #access-key: ""
      #secret-key: ""
  store:
    # support: file 、 db 、 redis
    mode: db
    db:
      datasource: druid
      db-type: mysql
      driver-class-name: com.mysql.jdbc.Driver
      url: jdbc:mysql://127.0.0.1:3306/seata?rewriteBatchedStatements=true
      user: root
      password: root
      min-conn: 5
      max-conn: 100
      global-table: global_table
      branch-table: branch_table
      lock-table: lock_table
      distributed-lock-table: distributed_lock
      query-limit: 100
      max-wait: 5000
#  server:
#    service-port: 8091 #If not configured, the default is '${server.port} + 1000'
  security:
    secretKey: SeataSecretKey0c382ef121d778043159209298fd40bf3850a017
    tokenValidityInMilliseconds: 1800000
    ignore:
      urls: /,/**/*.css,/**/*.js,/**/*.html,/**/*.map,/**/*.svg,/**/*.png,/**/*.ico,/console-fe/public/**,/api/v1/auth/login
创建seata数据库,执行脚本建表
-- -------------------------------- The script used when storeMode is 'db' --------------------------------
-- the table to store GlobalSession data
CREATE TABLE IF NOT EXISTS `global_table`
    `xid`                       VARCHAR(128) NOT NULL,
    `transaction_id`            BIGINT,
    `status`                    TINYINT      NOT NULL,
    `application_id`            VARCHAR(32),
    `transaction_service_group` VARCHAR(32),
    `transaction_name`          VARCHAR(128),
    `timeout`                   INT,
    `begin_time`                BIGINT,
    `application_data`          VARCHAR(2000),
    `gmt_create`                DATETIME,
    `gmt_modified`              DATETIME,
    PRIMARY KEY (`xid`),
    KEY `idx_status_gmt_modified` (`status` , `gmt_modified`),
    KEY `idx_transaction_id` (`transaction_id`)
) ENGINE = InnoDB
  DEFAULT CHARSET = utf8mb4;
-- the table to store BranchSession data
CREATE TABLE IF NOT EXISTS `branch_table`
    `branch_id`         BIGINT       NOT NULL,
    `resource_group_id` VARCHAR(32),
    `resource_id`       VARCHAR(256),
    `branch_type`       VARCHAR(8),
    `status`            TINYINT,
    `client_id`         VARCHAR(64),
    `gmt_create`        DATETIME(6),
    `gmt_modified`      DATETIME(6),
    PRIMARY KEY (`branch_id`),
    KEY `idx_xid` (`xid`)
) ENGINE = InnoDB
-- the table to store lock data
CREATE TABLE IF NOT EXISTS `lock_table`
    `row_key`        VARCHAR(128) NOT NULL,
    `xid`            VARCHAR(128),
    `table_name`     VARCHAR(32),
    `pk`             VARCHAR(36),
    `status`         TINYINT      NOT NULL DEFAULT '0' COMMENT '0:locked ,1:rollbacking',
    PRIMARY KEY (`row_key`),
    KEY `idx_status` (`status`),
    KEY `idx_branch_id` (`branch_id`),
) ENGINE = InnoDB
CREATE TABLE IF NOT EXISTS `distributed_lock`
    `lock_key`       CHAR(20) NOT NULL,
    `lock_value`     VARCHAR(20) NOT NULL,
    `expire`         BIGINT,
    primary key (`lock_key`)
) ENGINE = InnoDB
INSERT INTO `distributed_lock` (lock_key, lock_value, expire) VALUES ('AsyncCommitting', ' ', 0);
INSERT INTO `distributed_lock` (lock_key, lock_value, expire) VALUES ('RetryCommitting', ' ', 0);
INSERT INTO `distributed_lock` (lock_key, lock_value, expire) VALUES ('RetryRollbacking', ' ', 0);
INSERT INTO `distributed_lock` (lock_key, lock_value, expire) VALUES ('TxTimeoutCheck', ' ', 0);
启动seata-server,控制台登录页面如下,账号密码为seata/seata。
项目搭建
业务背景
用户购买商品的业务逻辑。整个业务逻辑由3个微服务提供支持:
  • 仓储服务:对给定的商品扣除仓储数量。
  • 订单服务:根据采购需求创建订单。
  • 帐户服务:从用户帐户中扣除余额。
架构
业务表创建
-- Table structure for t_account
DROP TABLE IF EXISTS `t_account`;
CREATE TABLE `t_account`
    `id`      int(11) NOT NULL AUTO_INCREMENT,
    `user_id` varchar(255) DEFAULT NULL,
    `amount`  double(14, 2
) DEFAULT '0.00',
  PRIMARY KEY (`id`)
) ENGINE=InnoDB AUTO_INCREMENT=2 DEFAULT CHARSET=utf8;
-- Records of t_account
INSERT INTO `t_account`
VALUES ('1', '1', '4000.00');
-- Table structure for t_order
DROP TABLE IF EXISTS `t_order`;
CREATE TABLE `t_order`
    `order_no`       varchar(255) DEFAULT NULL,
    `commodity_code` varchar(255) DEFAULT NULL,
    `count`          int(11) DEFAULT '0',
) DEFAULT '0.00',
  PRIMARY KEY (`id`)
) ENGINE=InnoDB AUTO_INCREMENT=64 DEFAULT CHARSET=utf8;
-- Records of t_order
-- Table structure for t_stock
DROP TABLE IF EXISTS `t_stock`;
CREATE TABLE `t_stock`
    `name`           varchar(255) DEFAULT NULL,
    PRIMARY KEY (`id`),
    UNIQUE KEY `commodity_code` (`commodity_code`)
-- Records of t_stock
INSERT INTO `t_stock`
VALUES ('1', 'C201901140001', '水杯', '1000');
-- Table structure for undo_log
-- 注意此处0.3.0+ 增加唯一索引 ux_undo_log
DROP TABLE IF EXISTS `undo_log`;
CREATE TABLE `undo_log`
    `id`            bigint(20) NOT NULL AUTO_INCREMENT,
    `branch_id`     bigint(20) NOT NULL,
    `xid`           varchar(100) NOT NULL,
    `context`       varchar(128) NOT NULL,
    `rollback_info` longblob     NOT NULL,
    `log_status`    int(11) NOT NULL,
    `log_created`   datetime     NOT NULL,
    `log_modified`  datetime     NOT NULL,
    PRIMARY KEY (`id`),
    UNIQUE KEY `ux_undo_log` (`xid`,`branch_id`)
) ENGINE=InnoDB AUTO_INCREMENT=1 DEFAULT CHARSET=utf8;
-- Records of undo_log
SET
FOREIGN_KEY_CHECKS=1;
服务创建
业务服务
以order服务为例,引入依赖、配置参数、提供创建订单接口。
  1. pom.xml文件中引入依赖
    <dependencies>
            <dependency>
                <artifactId>spring-boot-starter-web</artifactId>
            </dependency>
            <dependency>
                <groupId>com.alibaba.cloud</groupId>
                <artifactId>spring-cloud-starter-alibaba-nacos-discovery</artifactId>
            </dependency>
            <dependency>
                <artifactId>spring-cloud-starter-alibaba-seata</artifactId>
            </dependency>
            <dependency>
                <groupId>com.alibaba</groupId>
                <artifactId>druid</artifactId>
            </dependency>
            <dependency>
                <groupId>com.baomidou</groupId>
                <artifactId>mybatis-plus-boot-starter</artifactId>
            </dependency>
            <dependency>
                <groupId>mysql</groupId>
                <artifactId>mysql-connector-java</artifactId>
            </dependency>
        </dependencies>
  2. application.properties配置参数
    server.port=81
    spring.application.name=order
    spring.cloud.nacos.discovery.server-addr=127.0.0.1:8848
    spring.cloud.nacos.username=nacos
    spring.cloud.nacos.password=nacos
    spring.datasource.type=com.alibaba.druid.pool.DruidDataSource
    spring.datasource.driver-class-name=com.mysql.cj.jdbc.Driver
    spring.datasource.url=jdbc:mysql://127.0.0.1:3306/seata_samples?allowPublicKeyRetrieval=true&useSSL=false&useUnicode=true&characterEncoding=utf-8&allowMultiQueries=true
    spring.datasource.username=root
    spring.datasource.password=root
    mybatis-plus.mapper-locations=classpath:mapper/*.xml
    mybatis-plus.configuration.log-impl=org.apache.ibatis.logging.stdout.StdOutImpl
  3. 提供创建订单接口
       @RequestMapping("/add")
        public void add(String userId, String commodityCode, Integer count, BigDecimal amount) {
            Order order = new Order();
            order.setOrderNo(UUID.randomUUID().toString());
            order.setUserId(userId);
            order.setAmount(amount);
            order.setCommodityCode(commodityCode);
            order.setCount(count);
            orderService.save(order);
聚合服务
business服务远程调用仓储、订单、帐户服务,完成下单流程。
  1. pom.xml文件中引入依赖
        <dependencies>
            <dependency>
            </dependency>
            <dependency>
            </dependency>
            <dependency>
            </dependency>
            <dependency>
            </dependency>
            <dependency>
                <groupId>org.springframework.cloud</groupId>
                <artifactId>spring-cloud-starter-openfeign</artifactId>
            </dependency>
        </dependencies>
    server.port=80
    spring.application.name=business
    service.disableGlobalTransaction=false
    # 连接超时时间
    ribbon.ConnectTimeout=3000
    # 响应超时时间
    ribbon.ReadTimeout=5000
  3. 声明account、stock、order的feign接口。
    @FeignClient(value = "account")
    public interface AccountFeign {
        @RequestMapping("/account/reduce")
        public void reduce(@RequestParam("userId") String userId, @RequestParam("amount") BigDecimal amount);
    @FeignClient(value = "order")
    public interface OrderFeign {
        @RequestMapping("/order/add")
        public void add(@RequestParam("userId") String userId, @RequestParam("commodityCode") String commodityCode, @RequestParam("count") Integer count, @RequestParam("amount") BigDecimal amount);
    @FeignClient(value = "stock")
    public interface StockFeign {
        @RequestMapping("/stock/deduct")
        public void deduct(@RequestParam("commodityCode") String commodityCode, @RequestParam("count") Integer count);
  4. 全局事务开启,调用feign接口
    @Autowired
    private OrderFeign orderFeign;
    @Autowired
    private StockFeign stockFeign;
    @Autowired
    private AccountFeign accountFeign;
    @GlobalTransactional
    @RequestMapping("/toOrder")
    public void toOrder(String userId, String commodityCode, Integer count, BigDecimal amount) {
        accountFeign.reduce(userId, amount);
        stockFeign.deduct(commodityCode, count);
        orderFeign.add(userId, commodityCode, count, amount);
测试验证
当前资金账户4000,库存1000,模拟用户购买商品2000个,消费4000,业务调用后,数据库数据状态应该如下:
  • 用户资金满足4000,数据库更新用户资金为0。
  • 商品库存不满足2000个,异常。
  • business服务提交全局回滚。
  • 资金服务回滚操作,更新资金为4000。
验证:
  1. 浏览器输入地址请求访问http://127.0.0.1/business/toOrder?userId=1&commodityCode=C201901140001&count=2000&amount=4000
  2. account、stock服务日志观察。
  3. 数据库数据依然为原始状态。
注意事项
  1. Seata1.5版本的mysql驱动是5.7,需要为8,在libs文件夹删除mysql-connector-java-5.xx.jar,替换mysql-connector-java-8.xx.jar即可
  2. Spring Boot &Spring Cloud&Spring Cloud Alibaba版本兼容问题
    Spring Cloud Alibaba版本说明
  3. druid和数据驱动版本兼容
    通过druid仓库版本查看各依赖版本说明
代码仓库
代码仓库
