springboot3整合mybatis-plus多数据源
QGS 发表于 2024/01/05 23:40:04 2024/01/05
【摘要】 springboot3整合mybatis-plus多数据源
环境介绍
技术栈
springboot+mybatis-plus+mysql
软件
版本
mysql
8
IDEA
IntelliJ IDEA 2022.2.1
JDK
17
Spring Boot
3.1.7
dynamic-datasource
3.6.1
mybatis-plus
3.5.3.2
加入依赖
<dependency>
            <groupId>com.baomidou</groupId>
            <artifactId>mybatis-plus-boot-starter</artifactId>
            <version>3.5.4.1</version>
            <exclusions>
                <exclusion>
                    <artifactId>mybatis-plus-generator</artifactId>
                </exclusion>
            </exclusions>
        </dependency>
        <dependency>
            <groupId>com.github.pagehelper</groupId>
            <artifactId>pagehelper-spring-boot-starter</artifactId>
            <version>1.4.3</version>
        </dependency>
        <dependency>
            <artifactId>spring-boot-devtools</artifactId>
            <scope>runtime</scope>
            <optional>true</optional>
        </dependency>
        <dependency>
            <groupId>com.mysql</groupId>
            <artifactId>mysql-connector-j</artifactId>
        </dependency>
<dependency>
    <groupId>com.alibaba</groupId>
    <artifactId>druid-spring-boot-starter</artifactId>
    <version>1.1.14</version>
</dependency>
<dependency>
    <artifactId>dynamic-datasource-spring-boot-starter</artifactId>
    <version>3.6.1</version>
</dependency>
<dependency>
    <groupId>p6spy</groupId>
    <artifactId>p6spy</artifactId>
    <version>3.9.1</version>
</dependency>
application.yml文件配置
server:
  port: 8007
hxiot:
  swagger2:
    # 是否开启swagger2 开启为true,关闭为false
    enable: true
spring:
  datasource:
    dynamic:
      primary: sys2 #设置默认的数据源或者数据源组,默认值即为master
      strict: false #严格匹配数据源,默认false. true未匹配到指定数据源时抛异常,false使用默认数据源
      datasource:
        wms:
          url: jdbc:p6spy:mysql://127.0.0.1:3306/Wms?useUnicode=true&characterEncoding=UTF-8
          username: root
          password: 111111
          driver-class-name: com.p6spy.engine.spy.P6SpyDriver
        #          driver-class-name: com.mysql.jdbc.Driver
        sys2:
          url: jdbc:p6spy:mysql://127.0.0.1:3306/sys?serverTimezone=Asia/Shanghai&useUnicode=true&characterEncoding=UTF-8
          username: root
          password: 111111
  mvc:
    path match:
      matching-strategy: ant_path_matcher
  profiles:
    active: dev
  application:
management:
  server:
    port: 8008
  endpoints:
    web:
      exposure:
        include: "*"
  endpoint:
    prometheus:
      enabled: true
    health:
      show-details: always
  metrics:
    export:
      prometheus:
        enabled: true
mybatis-plus:
  configuration:
    #输出日志
    log-impl: org.apache.ibatis.logging.stdout.StdOutImpl
    #配置映射规则
    map-underscore-to-camel-case: true #表示支持下划线到驼蜂的映射
    #隐藏mybatis图标
  global-config:
    banner: false
    db-config:
      logic-delete-field: status
      logic-not-delete-value: 1
      logic-delete-value: 0
#mybatis:
#  mapper-locations=classpath: com/example/dao/*.xml
pagehelper:
  propertyName: propertyValue
  reasonable: false
  defaultCount: true # 分页插件默认参数支持 default-count 形式,自定义扩展的参数,必须大小写一致
#主机相关信息
host01:
  host: 192.168.68.133
  port: 22
  user: root
  password: pwd
#邮箱
email:
  user: 123@123
  code: 12314134
  host: 123.qq.com
  auth: true
#爱好
hobbies:
  -打篮球
  -踢足球
  -玩游戏
application中添加DdlApplicationRunner
@Bean
public DdlApplicationRunner ddlApplicationRunner(@Autowired(required = false) List ddlList) {
    return new DdlApplicationRunner(ddlList);
可能遇到的问题
问题
APPLICATION FAILED TO START
Description:
Failed to configure a DataSource: 'url' attribute is not specified and no embedded datasource could be configured.
Reason: Failed to determine a suitable driver class
解决办法
1、方法一
<dependency>
    <exclusions>
        <exclusion>
        </exclusion>
    </exclusions>
</dependency>
或
2、方法二
<dependency>
    <artifactId>
    <version>
3.5.3</version>
    <exclusions>
<exclusion>
<artifactId>mybatis-spring</artifactId>
            <groupId>
org.mybatis</groupId>
</exclusion>
</exclusions>
</dependency>
<dependency>
<groupId>org.mybatis</groupId>
    <artifactId>
    <version>
3.0.3</version>
</dependency>
3、方法三
升级dynamic-datasource-spring-boot-starter版本至3.6.1或最新版本
问题
org.springframework.beans.factory.BeanNotOfRequiredTypeException: Bean named 'ddlApplicationRunner' is expected to be of type 'org.springframework.boot.Runner' but was actually of type 'org.springframework.beans.factory.support.NullBean'
解决办法
在application中添加DdlApplicationRunner
@Bean
https://baomidou.com/
Mybatis-Plus介绍
为简化开发而生
MyBatis-Plus (opens new window)(简称 MP)是一个 MyBatis (opens new window) 的增强工具,在 MyBatis 的基础上只做增强不做改变,为简化开发、提高效率而生。
特性
  • 无侵入:只做增强不做改变,引入它不会对现有工程产生影响,如丝般顺滑
  • 损耗小:启动即会自动注入基本 CURD,性能基本无损耗,直接面向对象操作
  • 强大的 CRUD 操作:内置通用 Mapper、通用 Service,仅仅通过少量配置即可实现单表大部分 CRUD 操作,更有强大的条件构造器,满足各类使用需求
  • 支持 Lambda 形式调用:通过 Lambda 表达式,方便的编写各类查询条件,无需再担心字段写错
  • 支持主键自动生成:支持多达 4 种主键策略(内含分布式唯一 ID 生成器 - Sequence),可自由配置,完美解决主键问题
  • 支持 ActiveRecord 模式:支持 ActiveRecord 形式调用,实体类只需继承 Model 类即可进行强大的 CRUD 操作
  • 支持自定义全局通用操作:支持全局通用方法注入( Write once, use anywhere )
  • 内置代码生成器:采用代码或者 Maven 插件可快速生成 Mapper 、 Model 、 Service 、 Controller 层代码,支持模板引擎,更有超多自定义配置等您来使用
  • 内置分页插件:基于 MyBatis 物理分页,开发者无需关心具体操作,配置好插件之后,写分页等同于普通 List 查询
  • 分页插件支持多种数据库:支持 MySQL、MariaDB、Oracle、DB2、H2、HSQL、SQLite、Postgre、SQLServer 等多种数据库
  • 内置性能分析插件:可输出 SQL 语句以及其执行时间,建议开发测试时启用该功能,能快速揪出慢查询
  • 内置全局拦截插件:提供全表 delete 、 update 操作智能分析阻断,也可自定义拦截规则,预防误操作
