gRPC (五)kotlin gRPC样例
张俭 发表于 2023/12/29 17:55:20 2023/12/29
【摘要】 本文代码地址https://gitee.com/shoothzj/grpc-examples kotlin实现gRPC客户端服务端 添加依赖import com.google.protobuf.gradle.generateProtoTasksimport com.google.protobuf.gradle.idimport com.google.protobuf.gradle.plug...
本文代码地址
kotlin实现gRPC客户端服务端
添加依赖
import com.google.protobuf.gradle.plugins
import com.google.protobuf.gradle.protobuf
import com.google.protobuf.gradle.protoc
import org.jetbrains.kotlin.gradle.tasks.KotlinCompile
plugins {
    kotlin("jvm") version "1.7.10"
    id("com.google.protobuf") version "0.8.19"
    id("java")
group = "com.github.shoothzj"
version = "1.0-SNAPSHOT"
repositories {
    mavenCentral()
ext["grpcVersion"] = "1.47.0"
ext["protobufVersion"] = "3.21.2"
ext["grpcKotlinVersion"] = "1.3.0"
dependencies {
    api("io.grpc:grpc-netty:${rootProject.ext["grpcVersion"]}")
    api("io.grpc:grpc-stub:${rootProject.ext["grpcVersion"]}")
    api("io.grpc:grpc-protobuf:${rootProject.ext["grpcVersion"]}")
    api("com.google.protobuf:protobuf-java-util:${rootProject.ext["protobufVersion"]}")
    api("com.google.protobuf:protobuf-kotlin:${rootProject.ext["protobufVersion"]}")
    api("io.grpc:grpc-kotlin-stub:${rootProject.ext["grpcKotlinVersion"]}")
    testImplementation(kotlin("test"))
protobuf {
    protoc {
        artifact = "com.google.protobuf:protoc:${rootProject.ext["protobufVersion"]}"
    plugins {
        id("grpc") {
            artifact = "io.grpc:protoc-gen-grpc-java:${rootProject.ext["grpcVersion"]}"
        id("grpckt") {
            artifact = "io.grpc:protoc-gen-grpc-kotlin:${rootProject.ext["grpcKotlinVersion"]}:jdk8@jar"
    generateProtoTasks {
        all().forEach {
            it.plugins {
                id("grpc")
                id("grpckt")
            it.builtins {
                id("kotlin")
tasks.test {
    useJUnitPlatform()
tasks.withType<KotlinCompile> {
    kotlinOptions.jvmTarget = "1.8"
书写proto文件
proto文件就用上述的定义,放置在src/main/proto文件夹下,如下图
server侧代码
package com.github.shoothzj.grpc
import com.github.shoothzj.grpc.example.EchoProto2ServiceGrpcKt
import com.github.shoothzj.grpc.example.MessageProto2
import io.grpc.Server
import io.grpc.ServerBuilder
class EchoServer(private val port: Int) {
    val server: Server = ServerBuilder
        .forPort(port)
        .addService(EchoService())
        .build()
    fun start() {
        server.start()
        println("Server started, listening on $port")
        Runtime.getRuntime().addShutdownHook(
            Thread {
                println("*** shutting down gRPC server since JVM is shutting down")
                this@EchoServer.stop()
                println("*** server shut down")
    private fun stop() {
        server.shutdown()
    fun blockUntilShutdown() {
        server.awaitTermination()
    internal class EchoService : EchoProto2ServiceGrpcKt.EchoProto2ServiceCoroutineImplBase() {
        override suspend fun echoProto2(request: MessageProto2.EchoProto2Req): MessageProto2.EchoProto2Resp {
            return MessageProto2.EchoProto2Resp.newBuilder()
                .setStrReq(request.strReq)
                .setStrOpt(request.strOpt)
                .addAllStrRep(request.strRepList)
                .setInt64Req(request.int64Req)
                .setInt32Opt(request.int32Opt)
                .setComic(request.comic)
                .build()
fun main() {
    val port = System.getenv("PORT")?.toInt() ?: 10240
    val server = EchoServer(port)
    server.start()
    server.blockUntilShutdown()
client侧代码
import io.grpc.ManagedChannel
import io.grpc.ManagedChannelBuilder
import java.io.Closeable
import java.util.concurrent.TimeUnit
class EchoClient(private val channel: ManagedChannel) : Closeable {
    private val stub: EchoProto2ServiceGrpcKt.EchoProto2ServiceCoroutineStub = EchoProto2ServiceGrpcKt.EchoProto2ServiceCoroutineStub(channel)
    suspend fun greet() {
        val request = MessageProto2.EchoProto2Req.newBuilder()
            .setStrReq("strReq")
            .setStrOpt("strOpt")
            .addAllStrRep(listOf("str", "rep"))
            .setInt64Req(1)
            .setInt32Opt(2)
            .setComic(MessageProto2.Comic.Bleach)
            .build()
        val response = stub.echoProto2(request)
        println("Received: $response")
    override fun close() {
        channel.shutdown().awaitTermination(5, TimeUnit.SECONDS)
suspend fun main(args: Array<String>) {
    val port = 10240
    val channel = ManagedChannelBuilder.forAddress("localhost", port).usePlaintext().build()
    val client = EchoClient(channel)
    val user = args.singleOrNull() ?: "world"
    client.greet()
