gRPC(二)golang gRPC样例
张俭 发表于 2023/12/29 17:52:12 2023/12/29
【摘要】 本文代码地址https://gitee.com/shoothzj/grpc-examples go语言实现gRPC客户端服务端 添加golang package定义option go_package = "go_grpc_examples/echo"; 安装依赖go install google.golang.org/protobuf/cmd/protoc-gen-go@v1.28go i...
本文代码地址
go语言实现gRPC客户端服务端
添加golang package定义
安装依赖
go install google.golang.org/grpc/cmd/protoc-gen-go-grpc@v1.2
go get google.golang.org/grpc
生成golang代码
protoc --go_out=echo --go_opt=paths=source_relative --go-grpc_out=echo --go-grpc_opt=paths=source_relative  --proto_path=..  ../message_proto2.proto
server侧代码
package main
import (
	"context"
	"google.golang.org/grpc"
	"log"
	"net"
type server struct {
	echo.UnimplementedEchoProto2ServiceServer
func (s *server) EchoProto2(ctx context.Context, req *echo.EchoProto2Req) (*echo.EchoProto2Resp, error) {
	return &echo.EchoProto2Resp{
		StrReq:   req.StrReq,
		StrOpt:   req.StrOpt,
		StrRep:   req.StrRep,
		Int64Req: req.Int64Req,
		Int32Opt: req.Int32Opt,
		Comic:    req.Comic,
	}, nil
func main() {
	listen, err := net.Listen("tcp", ":10240")
	if err != nil {
		panic(err)
	s := grpc.NewServer()
	echo.RegisterEchoProto2ServiceServer(s, &server{})
	log.Printf("server listening at %v", listen.Addr())
	if err := s.Serve(listen); err != nil {
		log.Fatalf("failed to serve: %v", err)
客户端代码
package main
import (
	"context"
	"google.golang.org/grpc/credentials/insecure"
	"log"
	"time"
func main() {
	conn, err := grpc.Dial("localhost:10240", grpc.WithTransportCredentials(insecure.NewCredentials()))
	if err != nil {
		panic(err)
	defer conn.Close()
	c := echo.NewEchoProto2ServiceClient(conn)
	// Contact the server and print out its response.
	ctx, cancel := context.WithTimeout(context.Background(), time.Second)
	defer cancel()
	var strReq = "strReq"
	var strOpt = "strOpt"
	var int64Req = int64(64)
	var int32Opt = int32(32)
	comic := echo.Comic_Bleach
	r, err := c.EchoProto2(ctx, &echo.EchoProto2Req{
		StrReq:   &strReq,
		StrOpt:   &strOpt,
		StrRep:   []string{"str", "req"},
		Int64Req: &int64Req,
		Int32Opt: &int32Opt,
		Comic:    &comic,
	if err != nil {
		log.Fatalf("could not greet: %v", err)
	log.Printf("Greeting: %s", r)
