java agent 01.搭建agent
张俭 发表于 2023/12/29 17:48:55 2023/12/29
【摘要】 创建一个java maven工程 Step1 添加bytebuddy及日志依赖<dependencies> <dependency> <groupId>org.springframework</groupId> <artifactId>spring-web</artifactId> <version>5.2.9...
创建一个java maven工程
<dependencies>
        <dependency>
            <version>5.2.9.RELEASE</version>
            <scope>provided</scope>
        </dependency>
        <!-- 字节码 注入 -->
        <dependency>
            <groupId>net.bytebuddy</groupId>
            <artifactId>byte-buddy</artifactId>
            <version>1.10.19</version>
        </dependency>
        <dependency>
            <groupId>org.slf4j</groupId>
            <artifactId>slf4j-api</artifactId>
            <version>1.7.30</version>
        </dependency>
    </dependencies>
Step2 书写Agent的入口处
agent有两个入口函数,分别是premain和agentmain,用于两种启动场景-javaagent启动场景和attach启动场景,我们这里先书写-javaagent启动场景
package com.github.shoothzj.demo.agent;
import net.bytebuddy.ByteBuddy;
import net.bytebuddy.agent.builder.AgentBuilder;
import net.bytebuddy.matcher.ElementMatchers;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import java.lang.instrument.Instrumentation;
import static net.bytebuddy.matcher.ElementMatchers.nameStartsWith;
 * @author hezhangjian
public class AgentMain {
    private static final Logger log = LoggerFactory.getLogger(AgentMain.class);
     * call on -javaagnet
     * @param agentArgs
     * @param inst
    public static void premain(String agentArgs, Instrumentation inst) {
        System.out.println("start agent premain");
        final ByteBuddy byteBuddy = new ByteBuddy();
        new AgentBuilder.Default(byteBuddy)
                //这些类都是常见的无需切面注入的类,忽略掉可以提升agent加载速度
                .ignore(nameStartsWith("net.bytebuddy.")
                        .or(nameStartsWith("org.slf4j.")
                        .or(nameStartsWith("org.apache.logging.")
                        .or(nameStartsWith("org.groovy."))
                        .or(nameStartsWith("javassist"))
                        .or(nameStartsWith(".asm."))
                        .or(nameStartsWith("sun.reflect"))
                        .or(ElementMatchers.isSynthetic()))))
                //你想切面的包名
                .type(ElementMatchers.nameStartsWith("com.github.shoothzj.agent.test"))
                .transform(new AgentTransformer())
                .with(AgentBuilder.RedefinitionStrategy.RETRANSFORMATION)
                .installOn(inst);
    public static void agentmain(String agentArgs, Instrumentation inst) {
        System.out.println("start agent main");
这个时候Transform先书写一个空实现
import net.bytebuddy.description.type.TypeDescription;
import net.bytebuddy.dynamic.DynamicType;
import net.bytebuddy.utility.JavaModule;
public class AgentTransformer implements AgentBuilder.Transformer{
    @Override
    public DynamicType.Builder<?> transform(DynamicType.Builder<?> builder, TypeDescription typeDescription, ClassLoader classLoader, JavaModule javaModule) {
        return builder;
Step3 maven pom文件配置打包
<build>
        <plugins>
            <plugin>
                <groupId>org.apache.maven.plugins</groupId>
                <artifactId>maven-shade-plugin</artifactId>
                <version>3.2.4</version>
                <executions>
                    <execution>
                        <phase>package</phase>
                        <goals>
                            <goal>shade</goal>
                        </goals>
                        <configuration>
                            <transformers>
                                <transformer implementation="org.apache.maven.plugins.shade.resource.ManifestResourceTransformer">
                                    <manifestEntries>
                                        <Premain-Class>com.github.shoothzj.demo.agent.AgentMain</Premain-Class>
                                        <Can-Redefine-Classes>true</Can-Redefine-Classes>
                                        <Can-Retransform-Classes>true</Can-Retransform-Classes>
                                    </manifestEntries>
                                </transformer>
                            </transformers>
                            <artifactSet>
                                <includes>
                                    <include>org.slf4j:slf4j-api</include>
                                    <include>org.apache.logging.log4j:log4j-api</include>
                                    <include>org.apache.logging.log4j:log4j-core</include>
                                    <include>org.apache.logging.log4j:log4j-slf4j-impl</include>
                                    <include>org.apache.logging.log4j:log4j-jcl</include>
                                </includes>
                            </artifactSet>
                            <filters>
                                <filter>
                                    <artifact>*:*</artifact>
                                    <excludes>
                                        <exclude>META-INF/*.SF</exclude>
                                        <exclude>META-INF/*.DSA</exclude>
                                        <exclude>META-INF/*.RSA</exclude>
                                    </excludes>
                                </filter>
                            </filters>
                            <relocations>
                                <relocation>
                                    <pattern>org.slf4j</pattern>
                                    <shadedPattern>com.github.shoothzj.org.slf4j</shadedPattern>
                                </relocation>
                                <relocation>
                                    <pattern>org.apache.logging</pattern>
                                    <shadedPattern>com.github.shoothzj.org.apache.logging</shadedPattern>
                                </relocation>
                            </relocations>
                        </configuration>
                    </execution>
                </executions>
            </plugin>
        </plugins>
    </build>
这里配置了打java agent的包,和打shade包规避类冲突的问题,关于打shade包,可以参考https://www.jianshu.com/p/8171607ce03f
创建一个测试SpringBoot工程
Step1 书写主函数
package com.github.shoothzj.demo.agent.test;
import lombok.extern.slf4j.Slf4j;
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.SpringBootApplication;
@Slf4j
@SpringBootApplication
public class AgentTestMain {
        SpringApplication.run(AgentTestMain.class);
Step2 修改运行参数,加载java agent
这里我的agent,maven package后的路径在 /Users/akka/master/maven-demo/demo-agent/target/demo-agent-0.0.1.SNAPSHOT.jar
-javaagent:/Users/akka/master/maven-demo/demo-agent/target/demo-agent-0.0.1.SNAPSHOT.jar
Step3 运行结果
可以看到agent已经正常启动
