Mariadb java操作(一) 安装
张俭 发表于 2023/12/29 17:30:04 2023/12/29
【摘要】 下载依赖包yum install -y mariadb-server db初始化mysql_install_db --gssapi=OFF --user=root 命令拉起 初始化SQLCREATE DATABASE IF NOT EXISTS ttbb DEFAULT CHARSET utf8mb4 COLLATE utf8mb4_bin;CREATE USER IF NOT EXIST...
下载依赖包
db初始化
命令拉起
初始化SQL
CREATE USER IF NOT EXISTS hzj identified by 'Mysql@123';
GRANT ALL ON ttbb .* to hzj@'%';
/usr/bin/mysqld_safe --datadir='/var/lib/mysql' --user=root --init-file=/opt/sh/init.sql
代码连接
代码,参考地址 https://github.com/Shoothzj/java-demo
package com.github.shoothzj.demo.db.jdbc.mariadb;
import java.sql.Connection;
import java.sql.DriverManager;
import java.sql.SQLException;
import java.util.Properties;
 * @author akka
public class MariaDBBegin {
    // The JDBC Connector Class.
    private static final String DRIVER_NAME = "org.mariadb.jdbc.Driver";
    private static final String CONNECTION = "jdbc:mariadb://localhost:3306/" + TestConstant.TABLE_NAME;
    public static void main(String[] args) throws ClassNotFoundException, SQLException {
        System.out.println(DRIVER_NAME);
        Class.forName(DRIVER_NAME);
        // Properties for user and password.
        Properties p = new Properties();
        p.put("user", TestConstant.USER_NAME);
        p.put("password", TestConstant.PASSWORD);
        // Now try to connect
        Connection c = DriverManager.getConnection(CONNECTION, p);
        System.out.println("It works !");
        c.close();
输出
It works !
