清理数据库合集
张俭 发表于 2023/12/29 17:17:08 2023/12/29
【摘要】 Mysql 查询所有数据库mysql> show databases;+--------------------+| Database |+--------------------+| information_schema || mysql || performance_schema || sys || ttbb ...
Mysql
查询所有数据库
| Database           |
| mysql              |
| sys                |
| ttbb               |
5 rows in set (0.01 sec)
进入数据库一个一个清理
mysql> use ttbb
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
产生删除表的sql语句
mysql> select concat("DROP TABLE IF EXISTS ", table_name, ";") from information_schema.tables where table_schema="ttbb";
| concat("DROP TABLE IF EXISTS ", table_name, ";") |
| DROP TABLE IF EXISTS old_table_etl_scene_2;      |
1 row in set (0.00 sec)
注意table_schema要替换成您的数据库名称
复制执行语句即可
mysql> DROP TABLE IF EXISTS old_table_etl_scene_2;
Query OK, 0 rows affected (0.03 sec)
Mongo
查询所有数据库
> show databases;
admin   0.000GB
config  0.000GB
local   0.000GB
test    0.000GB
ttbb    0.000GB
进入数据库
> use ttbb
switched to db ttbb
清理数据库
> db.dropDatabase();
{ "dropped" : "ttbb", "ok" : 1 }
> show databases;
admin   0.000GB
config  0.000GB
local   0.000GB
test    0.000GB
