Spring之事务(2)
哥的时代 发表于 2023/12/28 20:08:13 2023/12/28
【摘要】 一、基于注解的声明式事务 1、准备工作①添加配置在beans.xml添加配置<!--扫描组件--><context:component-scan base-package="com.gedeshidai.spring6"></context:component-scan>②创建表CREATE TABLE `t_book` ( `book_id` int(11) NOT NULL AUTO...
一、基于注解的声明式事务
1、准备工作
①添加配置
在beans.xml添加配置
<!--扫描组件-->
②创建表
  `book_id` int(11) NOT NULL AUTO_INCREMENT COMMENT '主键',
  `book_name` varchar(20) DEFAULT NULL COMMENT '图书名称',
  `price` int(11) DEFAULT NULL COMMENT '价格',
  `stock` int(10) unsigned DEFAULT NULL COMMENT '库存(无符号)',
  PRIMARY KEY (`book_id`)
) ENGINE=InnoDB AUTO_INCREMENT=3 DEFAULT CHARSET=utf8;
insert  into `t_book`(`book_id`,`book_name`,`price`,`stock`) values (1,'斗破苍穹',80,100),(2,'斗罗大陆',50,100);
CREATE TABLE `t_user` (
  `user_id` int(11) NOT NULL AUTO_INCREMENT COMMENT '主键',
  `username` varchar(20) DEFAULT NULL COMMENT '用户名',
  `balance` int(10) unsigned DEFAULT NULL COMMENT '余额(无符号)',
  PRIMARY KEY (`user_id`)
) ENGINE=InnoDB AUTO_INCREMENT=2 DEFAULT CHARSET=utf8;
insert  into `t_user`(`user_id`,`username`,`balance`) values (1,'admin',50);
③创建组件
创建BookController:
package com.gedeshidai.spring6.controller;
@Controller
public class BookController {
    @Autowired
    private BookService bookService;
    public void buyBook(Integer bookId, Integer userId){
        bookService.buyBook(bookId, userId);
创建接口BookService:
package com.gedeshidai.spring6.service;
public interface BookService {
    void buyBook(Integer bookId, Integer userId);
创建实现类BookServiceImpl:
package com.gedeshidai.spring6.service.impl;
@Service
public class BookServiceImpl implements BookService {
    @Autowired
    private BookDao bookDao;
    @Override
    public void buyBook(Integer bookId, Integer userId) {
        //查询图书的价格
        Integer price = bookDao.getPriceByBookId(bookId);
        //更新图书的库存
        bookDao.updateStock(bookId);
        //更新用户的余额
        bookDao.updateBalance(userId, price);
创建接口BookDao:
package com.gedeshidai.spring6.dao;
public interface BookDao {
    Integer getPriceByBookId(Integer bookId);
    void updateStock(Integer bookId);
    void updateBalance(Integer userId, Integer price);
创建实现类BookDaoImpl:
package com.gedeshidai.spring6.dao.impl;
@Repository
public class BookDaoImpl implements BookDao {
    @Autowired
    private JdbcTemplate jdbcTemplate;
    @Override
    public Integer getPriceByBookId(Integer bookId) {
        String sql = "select price from t_book where book_id = ?";
        return jdbcTemplate.queryForObject(sql, Integer.class, bookId);
    @Override
    public void updateStock(Integer bookId) {
        String sql = "update t_book set stock = stock - 1 where book_id = ?";
        jdbcTemplate.update(sql, bookId);
    @Override
    public void updateBalance(Integer userId, Integer price) {
        String sql = "update t_user set balance = balance - ? where user_id = ?";
        jdbcTemplate.update(sql, price, userId);
2、测试无事务情况
①创建测试类
import org.junit.jupiter.api.Test;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.jdbc.core.JdbcTemplate;
import org.springframework.test.context.junit.jupiter.SpringJUnitConfig;
@SpringJUnitConfig(locations = "classpath:beans.xml")
public class TxByAnnotationTest {
    @Autowired
    private BookController bookController;
    @Test
    public void testBuyBook(){
        bookController.buyBook(1, 1);
②模拟场景
用户购买图书,先查询图书的价格,再更新图书的库存和用户的余额
假设用户id为1的用户,购买id为1的图书
用户余额为50,而图书价格为80
购买图书之后,用户的余额为-30,数据库中余额字段设置了无符号,因此无法将-30插入到余额字段
此时执行sql语句会抛出SQLException
③观察结果
因为没有添加事务,图书的库存更新了,但是用户的余额没有更新
显然这样的结果是错误的,购买图书是一个完整的功能,更新库存和更新余额要么都成功要么都失败
3、加入事务
①添加事务配置
在spring配置文件中引入tx命名空间
<beans xmlns="http://www.springframework.org/schema/beans"
       xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
       xmlns:context="http://www.springframework.org/schema/context"
       xmlns:tx="http://www.springframework.org/schema/tx"
       xsi:schemaLocation="http://www.springframework.org/schema/beans
       http://www.springframework.org/schema/beans/spring-beans.xsd
       http://www.springframework.org/schema/context/spring-context.xsd
       http://www.springframework.org/schema/tx/spring-tx.xsd">
在Spring的配置文件中添加配置:
<bean id="transactionManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
    <property name="dataSource" ref="druidDataSource"></property>
</bean>
    开启事务的注解驱动
    通过注解@Transactional所标识的方法或标识的类中所有的方法,都会被事务管理器管理事务
<!-- transaction-manager属性的默认值是transactionManager,如果事务管理器bean的id正好就是这个默认值,则可以省略这个属性 -->
<tx:annotation-driven transaction-manager="transactionManager" />
②添加事务注解
因为service层表示业务逻辑层,一个方法表示一个完成的功能,因此处理事务一般在service层处理
在BookServiceImpl的buybook()添加注解@Transactional
③观察结果
由于使用了Spring的声明式事务,更新库存和更新余额都没有执行
4、@Transactional注解标识的位置
@Transactional标识在方法上,则只会影响该方法
@Transactional标识的类上,则会影响类中所有的方法
5、事务属性:只读
①介绍
对一个查询操作来说,如果我们把它设置成只读,就能够明确告诉数据库,这个操作不涉及写操作。这样数据库就能够针对查询操作来进行优化。
②使用方式
@Transactional(readOnly = true)
    //查询图书的价格
    //更新图书的库存
    //更新用户的余额
    //System.out.println(1/0);
③注意
对增删改操作设置只读会抛出下面异常:
Caused by: java.sql.SQLException: Connection is read-only. Queries leading to data modification are not allowed
6、事务属性:超时
①介绍
事务在执行过程中,有可能因为遇到某些问题,导致程序卡住,从而长时间占用数据库资源。而长时间占用资源,大概率是因为程序运行出现了问题(可能是Java程序或MySQL数据库或网络连接等等)。此时这个很可能出问题的程序应该被回滚,撤销它已做的操作,事务结束,把资源让出来,让其他正常程序可以执行。
概括来说就是一句话:超时回滚,释放资源。
②使用方式
//超时时间单位秒
@Transactional(timeout = 3)
    try {
        TimeUnit.SECONDS.sleep(5);
    } catch (InterruptedException e) {
        e.printStackTrace();
    //查询图书的价格
    //更新图书的库存
    //更新用户的余额
③观察结果
执行过程中抛出异常:
org.springframework.transaction.TransactionTimedOutException: Transaction timed out: deadline was Fri Jun 04 16:25:39 CST 2022
7、事务属性:回滚策略
①介绍
声明式事务默认只针对运行时异常回滚,编译时异常不回滚。
可以通过@Transactional中相关属性设置回滚策略
  • rollbackFor属性:需要设置一个Class类型的对象
  • rollbackForClassName属性:需要设置一个字符串类型的全类名
  • noRollbackFor属性:需要设置一个Class类型的对象
  • rollbackFor属性:需要设置一个字符串类型的全类名
②使用方式
@Transactional(noRollbackFor = ArithmeticException.class)
//@Transactional(noRollbackForClassName = "java.lang.ArithmeticException")
    //查询图书的价格
    //更新图书的库存
    //更新用户的余额
③观察结果
虽然购买图书功能中出现了数学运算异常(ArithmeticException),但是我们设置的回滚策略是,当出现ArithmeticException不发生回滚,因此购买图书的操作正常执行
8、事务属性:隔离级别
①介绍
数据库系统必须具有隔离并发运行各个事务的能力,使它们不会相互影响,避免各种并发问题。一个事务与其他事务隔离的程度称为隔离级别。SQL标准中规定了多种事务隔离级别,不同隔离级别对应不同的干扰程度,隔离级别越高,数据一致性就越好,但并发性越弱。
隔离级别一共有四种:
  • 读未提交:READ UNCOMMITTED
    允许Transaction01读取Transaction02未提交的修改。
  • 读已提交:READ COMMITTED、
    要求Transaction01只能读取Transaction02已提交的修改。
  • 可重复读:REPEATABLE READ
    确保Transaction01可以多次从一个字段中读取到相同的值,即Transaction01执行期间禁止其它事务对这个字段进行更新。
  • 串行化:SERIALIZABLE
    确保Transaction01可以多次从一个表中读取到相同的行,在Transaction01执行期间,禁止其它事务对这个表进行添加、更新、删除操作。可以避免任何并发问题,但性能十分低下。
各个隔离级别解决并发问题的能力见下表:
隔离级别 脏读 不可重复读 幻读
READ UNCOMMITTED 有 有 有
READ COMMITTED 无 有 有
REPEATABLE READ 无 无 有
SERIALIZABLE 无 无 无
各种数据库产品对事务隔离级别的支持程度:
隔离级别 Oracle MySQL
READ UNCOMMITTED × √
READ COMMITTED √(默认) √
REPEATABLE READ × √(默认)
SERIALIZABLE √ √
②使用方式
@Transactional(isolation = Isolation.DEFAULT)//使用数据库默认的隔离级别
@Transactional(isolation = Isolation.READ_UNCOMMITTED)//读未提交
@Transactional(isolation = Isolation.READ_COMMITTED)//读已提交
@Transactional(isolation = Isolation.REPEATABLE_READ)//可重复读
@Transactional(isolation = Isolation.SERIALIZABLE)//串行化
9、事务属性:传播行为
①介绍
什么是事务的传播行为?
在service类中有a()方法和b()方法,a()方法上有事务,b()方法上也有事务,当a()方法执行过程中调用了b()方法,事务是如何传递的?合并到一个事务里?还是开启一个新的事务?这就是事务传播行为。
一共有七种传播行为:
  • REQUIRED:支持当前事务,如果不存在就新建一个(默认)【没有就新建,有就加入】
  • SUPPORTS:支持当前事务,如果当前没有事务,就以非事务方式执行**【有就加入,没有就不管了】**
  • MANDATORY:必须运行在一个事务中,如果当前没有事务正在发生,将抛出一个异常**【有就加入,没有就抛异常】**
  • REQUIRES_NEW:开启一个新的事务,如果一个事务已经存在,则将这个存在的事务挂起**【不管有没有,直接开启一个新事务,开启的新事务和之前的事务不存在嵌套关系,之前事务被挂起】**
  • NOT_SUPPORTED:以非事务方式运行,如果有事务存在,挂起当前事务**【不支持事务,存在就挂起】**
  • NEVER:以非事务方式运行,如果有事务存在,抛出异常**【不支持事务,存在就抛异常】**
  • NESTED:如果当前正有一个事务在进行中,则该方法应当运行在一个嵌套式事务中。被嵌套的事务可以独立于外层事务进行提交或回滚。如果外层事务不存在,行为就像REQUIRED一样。【有事务的话,就在这个事务里再嵌套一个完全独立的事务,嵌套的事务可以独立的提交和回滚。没有事务就和REQUIRED一样。】
②测试
创建接口CheckoutService:
public interface CheckoutService {
    void checkout(Integer[] bookIds, Integer userId);
创建实现类CheckoutServiceImpl:
@Service
public class CheckoutServiceImpl implements CheckoutService {
    @Autowired
    @Override
    @Transactional
    //一次购买多本图书
    public void checkout(Integer[] bookIds, Integer userId) {
        for (Integer bookId : bookIds) {
在BookController中添加方法:
@Autowired
private CheckoutService checkoutService;
public void checkout(Integer[] bookIds, Integer userId){
    checkoutService.checkout(bookIds, userId);
在数据库中将用户的余额修改为100元
③观察结果
可以通过@Transactional中的propagation属性设置事务传播行为
修改BookServiceImpl中buyBook()上,注解@Transactional的propagation属性
@Transactional(propagation = Propagation.REQUIRED),默认情况,表示如果当前线程上有已经开启的事务可用,那么就在这个事务中运行。经过观察,购买图书的方法buyBook()在checkout()中被调用,checkout()上有事务注解,因此在此事务中执行。所购买的两本图书的价格为80和50,而用户的余额为100,因此在购买第二本图书时余额不足失败,导致整个checkout()回滚,即只要有一本书买不了,就都买不了
@Transactional(propagation = Propagation.REQUIRES_NEW),表示不管当前线程上是否有已经开启的事务,都要开启新事务。同样的场景,每次购买图书都是在buyBook()的事务中执行,因此第一本图书购买成功,事务结束,第二本图书购买失败,只在第二次的buyBook()中回滚,购买第一本图书不受影响,即能买几本就买几本。
10、全注解配置事务
①添加配置类
package com.gedeshidai.spring6.config;
import com.alibaba.druid.pool.DruidDataSource;
import org.springframework.context.annotation.Bean;
import org.springframework.context.annotation.ComponentScan;
import org.springframework.context.annotation.Configuration;
import org.springframework.jdbc.datasource.DataSourceTransactionManager;
import org.springframework.transaction.annotation.EnableTransactionManagement;
import javax.sql.DataSource;
@Configuration
@ComponentScan("com.gedeshidai.spring6")
@EnableTransactionManagement
public class SpringConfig {
    @Bean
    public DataSource getDataSource(){
        DruidDataSource dataSource = new DruidDataSource();
        dataSource.setDriverClassName("com.mysql.cj.jdbc.Driver");
        dataSource.setUrl("jdbc:mysql://localhost:3306/spring?characterEncoding=utf8&useSSL=false");
        dataSource.setUsername("root");
        dataSource.setPassword("root");
        return dataSource;
    @Bean(name = "jdbcTemplate")
    public JdbcTemplate getJdbcTemplate(DataSource dataSource){
        JdbcTemplate jdbcTemplate = new JdbcTemplate();
        jdbcTemplate.setDataSource(dataSource);
        return jdbcTemplate;
    @Bean
    public DataSourceTransactionManager getDataSourceTransactionManager(DataSource dataSource){
        DataSourceTransactionManager dataSourceTransactionManager = new DataSourceTransactionManager();
        dataSourceTransactionManager.setDataSource(dataSource);
        return dataSourceTransactionManager;
②测试
import com.gedeshidai.spring6.config.SpringConfig;
import com.gedeshidai.spring6.controller.BookController;
import org.springframework.context.ApplicationContext;
import org.springframework.context.annotation.AnnotationConfigApplicationContext;
public class TxByAllAnnotationTest {
    @Test
    public void testTxAllAnnotation(){
        ApplicationContext applicationContext = new AnnotationConfigApplicationContext(SpringConfig.class);
        BookController accountService = applicationContext.getBean("bookController", BookController.class);
        accountService.buyBook(1, 1);
二、基于XML的声明式事务
1、场景模拟
参考基于注解的声明式事务
2、修改Spring配置文件
将Spring配置文件中去掉tx:annotation-driven 标签,并添加配置:
<aop:config>
    <!-- 配置事务通知和切入点表达式 -->
    <aop:advisor advice-ref="txAdvice" pointcut="execution(* com.gedeshidai.spring.tx.xml.service.impl.*.*(..))"></aop:advisor>
</aop:config>
<!-- tx:advice标签:配置事务通知 -->
<!-- id属性:给事务通知标签设置唯一标识,便于引用 -->
<!-- transaction-manager属性:关联事务管理器 -->
<tx:advice id="txAdvice" transaction-manager="transactionManager">
    <tx:attributes>
        <!-- tx:method标签:配置具体的事务方法 -->
        <!-- name属性:指定方法名,可以使用星号代表多个字符 -->
        <tx:method name="get*" read-only="true"/>
        <tx:method name="query*" read-only="true"/>
        <tx:method name="find*" read-only="true"/>
        <!-- read-only属性:设置只读属性 -->
        <!-- rollback-for属性:设置回滚的异常 -->
        <!-- no-rollback-for属性:设置不回滚的异常 -->
        <!-- isolation属性:设置事务的隔离级别 -->
        <!-- timeout属性:设置事务的超时属性 -->
        <!-- propagation属性:设置事务的传播行为 -->
        <tx:method name="save*" read-only="false" rollback-for="java.lang.Exception" propagation="REQUIRES_NEW"/>
        <tx:method name="update*" read-only="false" rollback-for="java.lang.Exception" propagation="REQUIRES_NEW"/>
        <tx:method name="delete*" read-only="false" rollback-for="java.lang.Exception" propagation="REQUIRES_NEW"/>
    </tx:attributes>
</tx:advice>
注意:基于xml实现的声明式事务,必须引入aspectJ的依赖
 <dependency>
     <groupId>org.springframework</groupId>
     <artifactId>spring-aspects</artifactId>
     <version>6.0.2</version>
</dependency>
以上就是Spring之事务(2)的相关知识点,希望对你有所帮助。
积跬步以至千里,积怠惰以至深渊。时代在这跟着你一起努力哦!
