Spring之容器:IOC(2)
哥的时代 发表于 2023/12/28 19:44:20 2023/12/28
【摘要】 7、实验六:为数组类型属性赋值①修改Student类在Student类中添加以下代码:private String[] hobbies;public String[] getHobbies() { return hobbies;}public void setHobbies(String[] hobbies) { this.hobbies = hobbies;}②配置bean<...
7、实验六:为数组类型属性赋值
①修改Student类
在Student类中添加以下代码:
    return hobbies;
②配置bean
<bean id="studentFour" class="com.gedeshidai.spring.bean6.Student">
    <property name="id" value="1004"></property>
    <property name="name" value="赵六"></property>
    <property name="age" value="26"></property>
    <property name="sex" value="女"></property>
    <!-- ref属性:引用IOC容器中某个bean的id,将所对应的bean为属性赋值 -->
    <property name="clazz" ref="clazzOne"></property>
    <property name="hobbies">
        <array>
            <value>抽烟</value>
            <value>喝酒</value>
            <value>烫头</value>
        </array>
    </property>
</bean>
8、实验七:为集合类型属性赋值
①为List集合类型属性赋值
在Clazz类中添加以下代码:
private List<Student> students;
public List<Student> getStudents() {
    return students;
public void setStudents(List<Student> students) {
    this.students = students;
配置bean:
<bean id="clazzTwo" class="com.gedeshidai.spring6.bean.Clazz">
    <property name="clazzId" value="4444"></property>
    <property name="clazzName" value="Javaee0222"></property>
    <property name="students">
        <list>
            <ref bean="studentOne"></ref>
            <ref bean="studentTwo"></ref>
            <ref bean="studentThree"></ref>
        </list>
    </property>
</bean>
若为Set集合类型属性赋值,只需要将其中的list标签改为set标签即可
②为Map集合类型属性赋值
创建教师类Teacher:
package com.gedeshidai.spring6.bean;
public class Teacher {
    private Integer teacherId;
    private String teacherName;
    public Integer getTeacherId() {
        return teacherId;
    public void setTeacherId(Integer teacherId) {
        this.teacherId = teacherId;
    public String getTeacherName() {
        return teacherName;
    public void setTeacherName(String teacherName) {
        this.teacherName = teacherName;
    public Teacher(Integer teacherId, String teacherName) {
    public Teacher() {
    @Override
    public String toString() {
        return "Teacher{" +
                "teacherId=" + teacherId +
                ", teacherName='" + teacherName + '\'' +
在Student类中添加以下代码:
private Map<String, Teacher> teacherMap;
public Map<String, Teacher> getTeacherMap() {
    return teacherMap;
public void setTeacherMap(Map<String, Teacher> teacherMap) {
    this.teacherMap = teacherMap;
配置bean:
<bean id="teacherOne" class="com.gedeshidai.spring6.bean.Teacher">
    <property name="teacherId" value="10010"></property>
    <property name="teacherName" value="大宝"></property>
</bean>
<bean id="teacherTwo" class="com.gedeshidaia.spring6.bean.Teacher">
    <property name="teacherId" value="10086"></property>
    <property name="teacherName" value="二宝"></property>
</bean>
<bean id="studentFour" class="com.gedeshidai.spring6.bean.Student">
        <array>
            <value>抽烟</value>
            <value>喝酒</value>
            <value>烫头</value>
        </array>
    </property>
    <property name="teacherMap">
        <map>
            <entry>
                <key>
                    <value>10010</value>
                </key>
                <ref bean="teacherOne"></ref>
            </entry>
            <entry>
                <key>
                    <value>10086</value>
                </key>
                <ref bean="teacherTwo"></ref>
            </entry>
        </map>
    </property>
</bean>
③引用集合类型的bean
<!--list集合类型的bean-->
<util:list id="students">
</util:list>
<!--map集合类型的bean-->
<util:map id="teacherMap">
    <entry>
        <key>
        </key>
    </entry>
    <entry>
        <key>
        </key>
    </entry>
</util:map>
    <property name="students" ref="students"></property>
</bean>
        <array>
            <value>抽烟</value>
            <value>喝酒</value>
            <value>烫头</value>
        </array>
    </property>
    <property name="teacherMap" ref="teacherMap"></property>
</bean>
使用util:list、util:map标签必须引入相应的命名空间
<beans xmlns="http://www.springframework.org/schema/beans"
       xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
       xmlns:util="http://www.springframework.org/schema/util"
       xsi:schemaLocation="http://www.springframework.org/schema/util
       http://www.springframework.org/schema/util/spring-util.xsd
       http://www.springframework.org/schema/beans/spring-beans.xsd">
9、实验八:p命名空间
引入p命名空间
       xmlns:p="http://www.springframework.org/schema/p"
引入p命名空间后,可以通过以下方式为bean的各个属性赋值
<bean id="studentSix" class="com.gedeshidai.spring6.bean.Student"
    p:id="1006" p:name="小明" p:clazz-ref="clazzOne" p:teacherMap-ref="teacherMap"></bean>
10、实验九:引入外部属性文件
①加入依赖
 <!-- MySQL驱动 -->
<dependency>
    <groupId>mysql</groupId>
    <artifactId>mysql-connector-java</artifactId>
    <version>8.0.30</version>
</dependency>
<!-- 数据源 -->
<dependency>
    <groupId>com.alibaba</groupId>
    <artifactId>druid</artifactId>
    <version>1.2.15</version>
</dependency>
②创建外部属性文件
jdbc.user=root
jdbc.password=gedeshidai
jdbc.url=jdbc:mysql://localhost:3306/ssm?serverTimezone=UTC
jdbc.driver=com.mysql.cj.jdbc.Driver
③引入属性文件
引入context 名称空间
       xmlns:context="http://www.springframework.org/schema/context"
       xsi:schemaLocation="http://www.springframework.org/schema/beans
       http://www.springframework.org/schema/context/spring-context.xsd">
</beans>
<!-- 引入外部属性文件 -->
<context:property-placeholder location="classpath:jdbc.properties"/>
注意:在使用 context:property-placeholder 元素加载外包配置文件功能前,首先需要在 XML 配置的一级标签 <beans> 中添加 context 相关的约束。
④配置bean
<bean id="druidDataSource" class="com.alibaba.druid.pool.DruidDataSource">
    <property name="url" value="${jdbc.url}"/>
    <property name="driverClassName" value="${jdbc.driver}"/>
    <property name="username" value="${jdbc.user}"/>
    <property name="password" value="${jdbc.password}"/>
</bean>
⑤测试
@Test
public void testDataSource() throws SQLException {
    ApplicationContext ac = new ClassPathXmlApplicationContext("spring-datasource.xml");
    DataSource dataSource = ac.getBean(DataSource.class);
    Connection connection = dataSource.getConnection();
    System.out.println(connection);
以上就是Spring之容器:IOC(2)的相关知识点,希望对你有所帮助。
积跬步以至千里,积怠惰以至深渊。时代在这跟着你一起努力哦!
