源码分析springboot自定义jackson序列化,默认null值个性化处理返回值
努力的小雨 发表于 2023/12/26 10:05:48 2023/12/26
【摘要】 最近项目要实现一种需求,对于后端返回给前端的json格式的一种规范,不允许缺少字段和字段值都为null,所以琢磨了一下如何进行将springboot的Jackson序列化自定义一下,先看看如何实现,再去看源码第一步:写配置类@Configurationpublic class WebConfiguration extends WebMvcConfigurationSupport {@Ove...
第一步:写配置类
@Configuration
@Override
    protected void extendMessageConverters(List<HttpMessageConverter<?>> converters) {
        converters.stream().filter(c -> c instanceof MappingJackson2HttpMessageConverter)
                .map(c ->(MappingJackson2HttpMessageConverter)c)
                .forEach(c->{
                    ObjectMapper mapper = c.getObjectMapper();
                    // 为mapper注册一个带有SerializerModifier的Factory,此modifier主要做的事情为:当序列化类型为array,list、set时,当值为空时,序列化成[]
                    mapper.setSerializerFactory(mapper.getSerializerFactory().withSerializerModifier(new MyBeanSerializerModifier()));
                    c.setObjectMapper(mapper);
第二步:编写值为null时的自定义序列化
public class MyBeanSerializerModifier extends BeanSerializerModifier {
    private MyNullStringJsonSerializer myNullStringJsonSerializer;
    private MyNullArrayJsonSerializer MyNullArrayJsonSerializer;
    private MyNullObjectJsonSerializer MyNullObjectJsonSerializer;
    private MyNullJsonSerializer myNullJsonSerializer;
    public MyBeanSerializerModifier(){
        myNullStringJsonSerializer = new MyNullStringJsonSerializer();
        MyNullArrayJsonSerializer = new MyNullArrayJsonSerializer();
        MyNullObjectJsonSerializer =  new MyNullObjectJsonSerializer();
        myNullJsonSerializer = new MyNullJsonSerializer();
    @Override
    public List<BeanPropertyWriter> changeProperties(SerializationConfig config, BeanDescription beanDesc,
                                                     List<BeanPropertyWriter> beanProperties) {
        // 循环所有的beanPropertyWriter
        beanProperties.forEach(writer ->{
            // 判断字段的类型
            if (isArrayType(writer)) {
                //给writer注册一个自己的nullSerializer
                writer.assignNullSerializer(MyNullArrayJsonSerializer);
            } else if (isObjectType(writer)) {
                writer.assignNullSerializer(MyNullObjectJsonSerializer);
            } else if (isStringType(writer)) {
                writer.assignNullSerializer(myNullStringJsonSerializer);
            } else if (isPrimitiveType(writer)) {
                writer.assignNullSerializer(myNullJsonSerializer);
        return beanProperties;
    // 判断是否是boolean类型
    private boolean isPrimitiveType(BeanPropertyWriter writer) {
        Class<?> clazz = writer.getType().getRawClass();
        return clazz.isPrimitive();
    // 判断是否是string类型
    private boolean isStringType(BeanPropertyWriter writer) {
        return clazz.equals(String.class);
    // 判断是否是对象类型
    private boolean isObjectType(BeanPropertyWriter writer) {
        return !clazz.isPrimitive() && !clazz.equals(String.class)
                && clazz.isAssignableFrom(Object.class);
    // 判断是否是集合类型
    protected boolean isArrayType(BeanPropertyWriter writer) {
        return clazz.isArray() || clazz.equals(List.class) || clazz.equals(Set.class);
    class MyNullJsonSerializer extends JsonSerializer<Object>{
        @Override
        public void serialize(Object value, JsonGenerator jgen, SerializerProvider serializers) throws IOException {
            if (value == null) {
                jgen.writeNull();
    class MyNullStringJsonSerializer extends JsonSerializer<Object>{
        @Override
                jgen.writeString(StringUtils.EMPTY);
    class MyNullArrayJsonSerializer extends JsonSerializer<Object>{
        @Override
                jgen.writeStartArray();
                jgen.writeEndArray();
    class MyNullObjectJsonSerializer extends JsonSerializer<Object>{
        @Override
                jgen.writeStartObject();
                jgen.writeEndObject();
这样基本配置就完事了,现在可以试试效果了,自己定义一个bean用来返回,定义一个简单的controller去接受访问就行了,博主就不进行写这两个类了。返回结果如下
这是我的项目需求需要实现的,大家可以根据的自己的需求去改写MyBeanSerializerModifier这个类。还有另一种实现方式:不继承
@Configuration
public class WebConfiguration {
@Bean
    public MappingJackson2HttpMessageConverter mappingJackson2HttpMessageConverter(){
        MappingJackson2HttpMessageConverter mappingJackson2HttpMessageConverter = new MappingJackson2HttpMessageConverter();
        ObjectMapper mapper = mappingJackson2HttpMessageConverter.getObjectMapper();
        mappingJackson2HttpMessageConverter.setObjectMapper(mapper);
        return mappingJackson2HttpMessageConverter;
这种方法也是可以设置成功的,主要是不是继承了WebMvcConfigurationSupport类,毕竟这个类有很多可以自定义的方法,用起来顺手而已。
第一个问题:为什么继承WebMvcConfigurationSupport后,要重写extendMessageConverters方法;
第二个问题:为什么继承WebMvcConfigurationSupport后,再去生成@Bean的MappingJackson2HttpMessageConverter,却不生效;
第三个问题:为什么不继承WebMvcConfigurationSupport时,生成@Bean的MappingJackson2HttpMessageConverter是生效的;
这几个问题,都需要我们进入源码观察,废活不多说,我们来进入源码的世界。解决问题之前必须搞清楚在哪里进行了序列化。
第一步:我们要弄清楚在哪里进行的Jackson序列化,看这里https://www.processon.com/embed/5f5c6464f346fb7afd55448b,从返回请求开始的序列化基本流程就在这里了,虽然图有点low,但是清楚的记录的每一步,我们主要看一下下面的源码
    /* Field serialization methods
    //序列化每一个字段
    protected void serializeFields(Object bean, JsonGenerator gen, SerializerProvider provider)
            throws IOException
        final BeanPropertyWriter[] props;
        if (_filteredProps != null && provider.getActiveView() != null) {
            props = _filteredProps;
            props = _props;
        int i = 0;
        try {
            for (final int len = props.length; i < len; ++i) {
                BeanPropertyWriter prop = props[i];
                if (prop != null) { // can have nulls in filtered list
                    //关键就在这一步进行的序列化,而为什么BeanPropertyWriter是数组,我们一会解释
                    prop.serializeAsField(bean, gen, provider);
            if (_anyGetterWriter != null) {
                _anyGetterWriter.getAndSerialize(bean, gen, provider);
        } catch (Exception e) {
            String name = (i == props.length) ? "[anySetter]" : props[i].getName();
            wrapAndThrow(provider, e, bean, name);
        } catch (StackOverflowError e) {
            // 04-Sep-2009, tatu: Dealing with this is tricky, since we don't have many
            //   stack frames to spare... just one or two; can't make many calls.
            // 10-Dec-2015, tatu: and due to above, avoid "from" method, call ctor directly:
            //JsonMappingException mapE = JsonMappingException.from(gen, "Infinite recursion (StackOverflowError)", e);
            JsonMappingException mapE = new JsonMappingException(gen, "Infinite recursion (StackOverflowError)", e);
            mapE.prependPath(new JsonMappingException.Reference(bean, name));
            throw mapE;
既然已经找到了在哪里要进行序列化,那我们看看是如何实现的:
     * Method called to access property that this bean stands for, from within
     * given bean, and to serialize it as a JSON Object field using appropriate
     * serializer.
    @Override
    public void serializeAsField(Object bean, JsonGenerator gen,
                                 SerializerProvider prov) throws Exception {
        // inlined 'get()'
        final Object value = (_accessorMethod == null) ? _field.get(bean)
                : _accessorMethod.invoke(bean, (Object[]) null);
        // Null handling is bit different, check that first
            //看到这里大家应该就知道null值是如何进行序列化 的了,如果不配置的话,默认是返回null
            //因为_nullSerializer是有默认值的,大家看一看这个类的初始化
            //那我们要是改一下_nullSerializer的这个默认类,让每一个字段调用我们自己的_nullSerializer不就可以了吗,
            //yes、我们就这么干
            if (_nullSerializer != null) {
                gen.writeFieldName(_name);
                _nullSerializer.serialize(null, gen, prov);
            return;
        // then find serializer to use
        JsonSerializer<Object> ser = _serializer;
        if (ser == null) {
            Class<?> cls = value.getClass();
            PropertySerializerMap m = _dynamicSerializers;
            ser = m.serializerFor(cls);
            if (ser == null) {
                ser = _findAndAddDynamic(m, cls, prov);
        // and then see if we must suppress certain values (default, empty)
        if (_suppressableValue != null) {
            if (MARKER_FOR_EMPTY == _suppressableValue) {
                if (ser.isEmpty(prov, value)) {
                    return;
            } else if (_suppressableValue.equals(value)) {
                return;
        // For non-nulls: simple check for direct cycles
        if (value == bean) {
            // three choices: exception; handled by call; or pass-through
            if (_handleSelfReference(bean, gen, prov, ser)) {
                return;
        if (_typeSerializer == null) {
            ser.serialize(value, gen, prov);
            ser.serializeWithType(value, gen, prov, _typeSerializer);
那我们来解决第一个问题:为什么继承WebMvcConfigurationSupport后,要重写extendMessageConverters方法?
不知道大家记得不记得我们请求过来的时候,如果我们配置类集成了WebMvcConfigurationSupport类,dispatchservlet处理handle请求的ha,其实就是RequestMappingHandlerAdapter类,这个类是在WebMvcConfigurationSupport配置的,看源码:
@Bean
    public RequestMappingHandlerAdapter requestMappingHandlerAdapter(
            @Qualifier("mvcContentNegotiationManager") ContentNegotiationManager contentNegotiationManager,
            @Qualifier("mvcConversionService") FormattingConversionService conversionService,
            @Qualifier("mvcValidator") Validator validator) {
        RequestMappingHandlerAdapter adapter = createRequestMappingHandlerAdapter();
        adapter.setContentNegotiationManager(contentNegotiationManager);
        adapter.setMessageConverters(getMessageConverters());
        adapter.setWebBindingInitializer(getConfigurableWebBindingInitializer(conversionService, validator));
        adapter.setCustomArgumentResolvers(getArgumentResolvers());
        adapter.setCustomReturnValueHandlers(getReturnValueHandlers());
        if (jackson2Present) {
            adapter.setRequestBodyAdvice(Collections.singletonList(new JsonViewRequestBodyAdvice()));
            adapter.setResponseBodyAdvice(Collections.singletonList(new JsonViewResponseBodyAdvice()));
        AsyncSupportConfigurer configurer = new AsyncSupportConfigurer();
        configureAsyncSupport(configurer);
        if (configurer.getTaskExecutor() != null) {
            adapter.setTaskExecutor(configurer.getTaskExecutor());
        if (configurer.getTimeout() != null) {
            adapter.setAsyncRequestTimeout(configurer.getTimeout());
        adapter.setCallableInterceptors(configurer.getCallableInterceptors());
        adapter.setDeferredResultInterceptors(configurer.getDeferredResultInterceptors());
        return adapter;
adapter.setMessageConverters(getMessageConverters());当大家看到这个方法的时候,应该就会想到我们的默认jackson转换器:MappingJackson2HttpMessageConverter,我们看看这个getMessageConverters()有什么幺蛾子:
protected final List<HttpMessageConverter<?>> getMessageConverters() {
        if (this.messageConverters == null) {
            this.messageConverters = new ArrayList<>();
            configureMessageConverters(this.messageConverters);
            if (this.messageConverters.isEmpty()) {
                addDefaultHttpMessageConverters(this.messageConverters);
            extendMessageConverters(this.messageConverters);
        return this.messageConverters;
 protected final void addDefaultHttpMessageConverters(List<HttpMessageConverter<?>> messageConverters) {
              //这些都不用管,跟我们的需求没啥作用,我们只看关键的部分,在下面
              messageConverters.add(new ByteArrayHttpMessageConverter());
              messageConverters.add(new StringHttpMessageConverter());
              messageConverters.add(new ResourceHttpMessageConverter());
              messageConverters.add(new ResourceRegionHttpMessageConverter());
              try {
                  messageConverters.add(new SourceHttpMessageConverter<>());
             catch (Throwable ex) {
                 // Ignore when no TransformerFactory implementation is available...
             messageConverters.add(new AllEncompassingFormHttpMessageConverter());
             if (romePresent) {
                 messageConverters.add(new AtomFeedHttpMessageConverter());
                 messageConverters.add(new RssChannelHttpMessageConverter());
             if (jackson2XmlPresent) {
                 Jackson2ObjectMapperBuilder builder = Jackson2ObjectMapperBuilder.xml();
                 if (this.applicationContext != null) {
                     builder.applicationContext(this.applicationContext);
                 messageConverters.add(new MappingJackson2XmlHttpMessageConverter(builder.build()));
             else if (jaxb2Present) {
                 messageConverters.add(new Jaxb2RootElementHttpMessageConverter());
if (jackson2Present) {                 Jackson2ObjectMapperBuilder builder = Jackson2ObjectMapperBuilder.json();
                 //解析我们返回值的转换器就是在这里生成的
                 messageConverters.add(new MappingJackson2HttpMessageConverter(builder.build()));
             else if (gsonPresent) {
                 messageConverters.add(new GsonHttpMessageConverter());
             else if (jsonbPresent) {
                 messageConverters.add(new JsonbHttpMessageConverter());
             if (jackson2SmilePresent) {
                 Jackson2ObjectMapperBuilder builder = Jackson2ObjectMapperBuilder.smile();
                 messageConverters.add(new MappingJackson2SmileHttpMessageConverter(builder.build()));
             if (jackson2CborPresent) {
                 Jackson2ObjectMapperBuilder builder = Jackson2ObjectMapperBuilder.cbor();
                 messageConverters.add(new MappingJackson2CborHttpMessageConverter(builder.build()));
我们的MappingJackson2HttpMessageConverter类就是这里初始化的,初始化的时候默认的_nullSerializer也会被初始化,大家肯定说这已经初始化完了,该咋办,大家应该看到了extendMessageConverters(this.messageConverters);这个方法就是用来重写实现的了,这回知道我们继承WebMvcConfigurationSupport后,为什么要重写extendMessageConverters,我们的配置类遍历已经获取到的convert,然后对我们想要的转换器进行修改添加,那修改完了,是在哪里起作用的呢,我们再来看一看源码:
在序列化之前有一些方法是可以进行修改操作的,在调用writeWithMessageConverters方法的时候:
 protected <T> void writeWithMessageConverters(@Nullable T value, MethodParameter returnType,
                                                        ServletServerHttpRequest inputMessage, ServletServerHttpResponse outputMessage)
                  throws IOException, HttpMediaTypeNotAcceptableException, HttpMessageNotWritableException {
              MediaType selectedMediaType = null;
              MediaType contentType = outputMessage.getHeaders().getContentType();
             boolean isContentTypePreset = contentType != null && contentType.isConcrete();
             if (isContentTypePreset) {
                 if (logger.isDebugEnabled()) {
                     logger.debug("Found 'Content-Type:" + contentType + "' in response");
                 selectedMediaType = contentType;
             else {
                 HttpServletRequest request = inputMessage.getServletRequest();
                 List<MediaType> acceptableTypes = getAcceptableMediaTypes(request);
                 //这里进行自定义操作修改MappingJackson2HttpMessageConverter
                 List<MediaType> producibleTypes = getProducibleMediaTypes(request, valueType, targetType);
             if (selectedMediaType != null) {
                 selectedMediaType = selectedMediaType.removeQualityValue();
                 //这这里进行选择我们的MappingJackson2HttpMessageConverter去自定义序列化
                 for (HttpMessageConverter<?> converter : this.messageConverters) {
                     GenericHttpMessageConverter genericConverter = (converter instanceof GenericHttpMessageConverter ?
                             (GenericHttpMessageConverter<?>) converter : null);
                     if (genericConverter != null ?
                             ((GenericHttpMessageConverter) converter).canWrite(targetType, valueType, selectedMediaType) :
                             converter.canWrite(valueType, selectedMediaType)) {
                         body = getAdvice().beforeBodyWrite(body, returnType, selectedMediaType,
                                 (Class<? extends HttpMessageConverter<?>>) converter.getClass(),
                                 inputMessage, outputMessage);
                         if (body != null) {
                             Object theBody = body;
                             LogFormatUtils.traceDebug(logger, traceOn ->
                                     "Writing [" + LogFormatUtils.formatValue(theBody, !traceOn) + "]");
                             addContentDispositionHeader(inputMessage, outputMessage);
                             if (genericConverter != null) {
                                 genericConverter.write(body, targetType, selectedMediaType, outputMessage);
                             else {
                                 ((HttpMessageConverter) converter).write(body, selectedMediaType, outputMessage);
                         else {
                                 logger.debug("Nothing to write: null body");
                         return;
             if (body != null) {
                 Set<MediaType> producibleMediaTypes =
                         (Set<MediaType>) inputMessage.getServletRequest()
                                 .getAttribute(HandlerMapping.PRODUCIBLE_MEDIA_TYPES_ATTRIBUTE);
                 if (isContentTypePreset || !CollectionUtils.isEmpty(producibleMediaTypes)) {
                     throw new HttpMessageNotWritableException(
                             "No converter for [" + valueType + "] with preset Content-Type '" + contentType + "'");
                 throw new HttpMediaTypeNotAcceptableException(this.allSupportedMediaTypes);
我们一直追踪getProducibleMediaTypes后,最终发现会调用BeanSerializerFactory的constructBeanOrAddOnSerializer,就是这里进行修改操作的。
protected JsonSerializer<Object> constructBeanOrAddOnSerializer(SerializerProvider prov,
            JavaType type, BeanDescription beanDesc, boolean staticTyping)
        throws JsonMappingException
        // 13-Oct-2010, tatu: quick sanity check: never try to create bean serializer for plain Object
        // 05-Jul-2012, tatu: ... but we should be able to just return "unknown type" serializer, right?
        if (beanDesc.getBeanClass() == Object.class) {
            return prov.getUnknownTypeSerializer(Object.class);
//            throw new IllegalArgumentException("Cannot create bean serializer for Object.class");
        final SerializationConfig config = prov.getConfig();
        BeanSerializerBuilder builder = constructBeanSerializerBuilder(beanDesc);
        builder.setConfig(config);
        // First: any detectable (auto-detect, annotations) properties to serialize?
        List<BeanPropertyWriter> props = findBeanProperties(prov, beanDesc, builder);
        if (props == null) {
            props = new ArrayList<BeanPropertyWriter>();
            props = removeOverlappingTypeIds(prov, beanDesc, builder, props);
        // [databind#638]: Allow injection of "virtual" properties:
        prov.getAnnotationIntrospector().findAndAddVirtualProperties(config, beanDesc.getClassInfo(), props);
        // [JACKSON-440] Need to allow modification bean properties to serialize:
        if (_factoryConfig.hasSerializerModifiers()) {
            for (BeanSerializerModifier mod : _factoryConfig.serializerModifiers()) {
                props = mod.changeProperties(config, beanDesc, props);
.......//此处省略
大家看一下props = mod.changeProperties(config, beanDesc, props);我们在配置类里面可是为我们的MappingJackson2HttpMessageConverter配置了 withSerializerModifier方法,并且设置了我们的MyBeanSerializerModifier并且继承BeanSerializerModifier重写了 changeProperties,所以会调用我们的changeProperties方法,进行修改null值的序列化类,我们也返回了一个list类型的BeanPropertyWriter,所以知道为什么那个BeanPropertyWriter在解析时,会是个数组类型的了吧,因为不同字段解析是不一样的。
剩下的解释一下为什么单独配置并设置实例化@bean的MappingJackson2HttpMessageConverter也是好使的呢,大家可以看一下JacksonHttpMessageConvertersConfiguration类的源码,里面明确写了@ConditionalOnMissingBean注解,如果我们自己进行配置了,这个注入后就是一个备胎,以我们的为准,这个不多说
我们再来解析一下第二个问题:为什么继承WebMvcConfigurationSupport后,再去生成@Bean的MappingJackson2HttpMessageConverter,却不生效,这需要跟第三个问题一起解决:为什么不继承WebMvcConfigurationSupport时,生成@Bean的MappingJackson2HttpMessageConverter是生效的。
我们知道当我们继承WebMvcConfigurationSupport后,有一个配置会自动失效,就是自动注入的一个mvc配置,可以看看@SpringBootApplication注解里面有个@EnableAutoConfiguration注解,会引入一个AutoConfigurationImportSelector类。这个类就会扫描org.springframework.boot:spring-boot-autoconfigure下的spring.factories文件,这里面有一个我们默认的mvn配置也是继承了WebMvcConfigurationSupport,叫WebMvcAutoConfiguration,我们来看一下源码:
@Configuration(proxyBeanMethods = false)
@ConditionalOnWebApplication(type = Type.SERVLET)
@ConditionalOnClass({ Servlet.class, DispatcherServlet.class, WebMvcConfigurer.class })
//注意此处有一个ConditionalOnMissingBean注解,所以如果我们自己继承后,就相当于已经存在WebMvcConfigurationSupport类,
//就会走我们自己的配置类,此配置会失效
@ConditionalOnMissingBean(WebMvcConfigurationSupport.class)
@AutoConfigureOrder(Ordered.HIGHEST_PRECEDENCE + 10)
@AutoConfigureAfter({ DispatcherServletAutoConfiguration.class, TaskExecutionAutoConfiguration.class,
        ValidationAutoConfiguration.class })
public class WebMvcAutoConfiguration {
    public static class EnableWebMvcConfiguration extends DelegatingWebMvcConfiguration implements ResourceLoaderAware {
        private final ResourceProperties resourceProperties;
        private final WebMvcProperties mvcProperties;
        private final ListableBeanFactory beanFactory;
        private final WebMvcRegistrations mvcRegistrations;
        private ResourceLoader resourceLoader;
        public EnableWebMvcConfiguration(ResourceProperties resourceProperties,
                ObjectProvider<WebMvcProperties> mvcPropertiesProvider,
                ObjectProvider<WebMvcRegistrations> mvcRegistrationsProvider, ListableBeanFactory beanFactory) {
            this.resourceProperties = resourceProperties;
            this.mvcProperties = mvcPropertiesProvider.getIfAvailable();
            this.mvcRegistrations = mvcRegistrationsProvider.getIfUnique();
            this.beanFactory = beanFactory;
        //如果我们不继承的话,处理请求的RequestMappingHandlerAdapter就会在这里生成
        //会调用DelegatingWebMvcConfiguration里面的 requestMappingHandlerAdapter方法,
        @Bean
        @Override
            RequestMappingHandlerAdapter adapter = super.requestMappingHandlerAdapter(contentNegotiationManager,
                    conversionService, validator);
            adapter.setIgnoreDefaultModelOnRedirect(
                    this.mvcProperties == null || this.mvcProperties.isIgnoreDefaultModelOnRedirect());
            return adapter;
不知道大家是否还记得getMessageConverters()方法里面添加默认messageConverters的时候之前,会调用一个configureMessageConverters(this.messageConverters);方法,我们的DelegatingWebMvcConfiguration 就已经重写了这个方法,所以我们如果不继承WebMvcConfigurationSupport,将会把我们的@bean形式存在的MappingJackson2HttpMessageConverter将会被扫描到
@Override
    protected void configureMessageConverters(List<HttpMessageConverter<?>> converters) {
        this.configurers.configureMessageConverters(converters);
//会添加我们的convert
@Override
    public void configureMessageConverters(List<HttpMessageConverter<?>> converters) {
        for (WebMvcConfigurer delegate : this.delegates) {
            delegate.configureMessageConverters(converters);
现在我们配置的自定义jackson序列化已经生效了,但是,你仔细看我的流程图会发现,其实调用序列化的时候走的是RequestResponseBodyMethodProcessor的handleReturnValue方法
@Override
    public void handleReturnValue(@Nullable Object returnValue, MethodParameter returnType,
            ModelAndViewContainer mavContainer, NativeWebRequest webRequest)
        mavContainer.setRequestHandled(true);
        ServletServerHttpRequest inputMessage = createInputMessage(webRequest);
        ServletServerHttpResponse outputMessage = createOutputMessage(webRequest);
        // Try even with null return value. ResponseBodyAdvice could get involved.
        //这里进入序列化流程
        writeWithMessageConverters(returnValue, returnType, inputMessage, outputMessage);
最后在序列化的时候也是从这个类或则父类里面的一个属性:messageConverters
public abstract class AbstractMessageConverterMethodArgumentResolver implements HandlerMethodArgumentResolver {
    private static final Set<HttpMethod> SUPPORTED_METHODS =
            EnumSet.of(HttpMethod.POST, HttpMethod.PUT, HttpMethod.PATCH);
    private static final Object NO_VALUE = new Object();
    protected final Log logger = LogFactory.getLog(getClass());
    //这个属性取值的
    protected final List<HttpMessageConverter<?>> messageConverters;
    protected final List<MediaType> allSupportedMediaTypes;
    private final RequestResponseBodyAdviceChain advice;
于是,小伙伴们就疑惑了,这我们自定义的在RequestMappingHandlerAdapter里面呢,跟这个类也没关系啊,属性是咋设置进来的呢?我们再看看RequestMappingHandlerAdapter的源码,你会发现,RequestMappingHandlerAdapter这个类实现了InitializingBean类,也就说明,创建RequestMappingHandlerAdapter的时候会调用afterPropertiesSet方法,至于为啥,看源码吧:(不是主要流程)
 //在createBean的时候会调用这个方法,看看是否实现了InitializingBean
  protected void invokeInitMethods(String beanName, final Object bean, @Nullable RootBeanDefinition mbd)
              throws Throwable {
          boolean isInitializingBean = (bean instanceof InitializingBean);
          if (isInitializingBean && (mbd == null || !mbd.isExternallyManagedInitMethod("afterPropertiesSet"))) {
              if (logger.isTraceEnabled()) {
                  logger.trace("Invoking afterPropertiesSet() on bean with name '" + beanName + "'");
             if (System.getSecurityManager() != null) {
                 try {
                     AccessController.doPrivileged((PrivilegedExceptionAction<Object>) () -> {
                         ((InitializingBean) bean).afterPropertiesSet();
                         return null;
                     }, getAccessControlContext());
                 catch (PrivilegedActionException pae) {
                     throw pae.getException();
             else {
                 //在这里进行调用的,
         if (mbd != null && bean.getClass() != NullBean.class) {
             String initMethodName = mbd.getInitMethodName();
             if (StringUtils.hasLength(initMethodName) &&
                     !(isInitializingBean && "afterPropertiesSet".equals(initMethodName)) &&
                     !mbd.isExternallyManagedInitMethod(initMethodName)) {
                 invokeCustomInitMethod(beanName, bean, mbd);
那我们看看RequestMappingHandlerAdapter的afterPropertiesSet方法都干了些啥吧。
@Override
    public void afterPropertiesSet() {
        // Do this first, it may add ResponseBody advice beans
        initControllerAdviceCache();
        if (this.argumentResolvers == null) {
            List<HandlerMethodArgumentResolver> resolvers = getDefaultArgumentResolvers();
            this.argumentResolvers = new HandlerMethodArgumentResolverComposite().addResolvers(resolvers);
        if (this.initBinderArgumentResolvers == null) {
            List<HandlerMethodArgumentResolver> resolvers = getDefaultInitBinderArgumentResolvers();
            this.initBinderArgumentResolvers = new HandlerMethodArgumentResolverComposite().addResolvers(resolvers);
        if (this.returnValueHandlers == null) {
            //是在这里生成的类
            List<HandlerMethodReturnValueHandler> handlers = getDefaultReturnValueHandlers();
            this.returnValueHandlers = new HandlerMethodReturnValueHandlerComposite().addHandlers(handlers);
private List<HandlerMethodReturnValueHandler> getDefaultReturnValueHandlers() {
        List<HandlerMethodReturnValueHandler> handlers = new ArrayList<>();
        // Single-purpose return value types
        handlers.add(new ModelAndViewMethodReturnValueHandler());
        handlers.add(new ModelMethodProcessor());
        handlers.add(new ViewMethodReturnValueHandler());
        handlers.add(new ResponseBodyEmitterReturnValueHandler(getMessageConverters(),
                this.reactiveAdapterRegistry, this.taskExecutor, this.contentNegotiationManager));
        handlers.add(new StreamingResponseBodyReturnValueHandler());
        handlers.add(new HttpEntityMethodProcessor(getMessageConverters(),
                this.contentNegotiationManager, this.requestResponseBodyAdvice));
        handlers.add(new HttpHeadersReturnValueHandler());
        handlers.add(new CallableMethodReturnValueHandler());
        handlers.add(new DeferredResultMethodReturnValueHandler());
        handlers.add(new AsyncTaskMethodReturnValueHandler(this.beanFactory));
        // Annotation-based return value types
        handlers.add(new ModelAttributeMethodProcessor(false));
        //看到这个类了吗?生成的时候将RequestMappingHandlerAdapter里面的转换器设置进去了
        handlers.add(new RequestResponseBodyMethodProcessor(getMessageConverters(),
        // Multi-purpose return value types
        handlers.add(new ViewNameMethodReturnValueHandler());
        handlers.add(new MapMethodProcessor());
        // Custom return value types
        if (getCustomReturnValueHandlers() != null) {
            handlers.addAll(getCustomReturnValueHandlers());
        // Catch-all
        if (!CollectionUtils.isEmpty(getModelAndViewResolvers())) {
            handlers.add(new ModelAndViewResolverMethodReturnValueHandler(getModelAndViewResolvers()));
        else {
            handlers.add(new ModelAttributeMethodProcessor(true));
        return handlers;
讲到这里,不知道大家理解了多少,这些都是博主遇到需求后,自己问自己的问题,自己通过源码回答问题的,也希望大家能理解源码。还有一篇源码文章在路上:为什么我们的项目里出现两个配置类继承WebMvcConfigurationSupport时,只有一个会生效。我在网上找了半天都是说结果的,没有人分析源码到底是为啥,博主准备讲解一下,希望可以帮到大家!
