【调优实践】COUNT()OVER()改写优化
门前一棵葡萄树 发表于 2023/12/22 15:54:13 2023/12/22
【摘要】 1. 问题描述XX局点大量使用API获取报表数据进行分页展示,分页展示时需要同时获取到总条数,因此会在SQL中大量使用COUNT(1)OVER()窗口函数。写法如下:SELECT *,COUNT(1)OVER() FROM 表/子查询 LIMIT XX OFFSET XX; 目前DWS执行逻辑中,会将所有语句GATHER到CN,并在CN上开窗计算,导致性能瓶颈。如下SQL:EXPLAIN P...
1. 问题描述
如下SQL:
EXPLAIN PERFORMANCE
select cust_key,cust_acct,cust_id,count(1)over() from DMISC.DM_DIM_CBG_CUSTOMER_INFO_D limit 100 offset 0;
执行计划如下:
 id |                            operation                            |      A-time      |  A-rows  |  E-rows  | E-distinct | Peak Memory | E-memory | A-width | E-width |  E-costs
  1 | ->  Row Adapter                                                 | 1967.272         |      100 |      100 |            | 39KB        |          |         |      26 | 5.14
  2 |    ->  Vector Limit                                             | 1967.263         |      100 |      100 |            | 8KB         |          |         |      26 | 5.14
  3 |       ->  Vector WindowAgg                                      | 1967.259         |     1000 | 13372944 |            | 1753687KB   |          |         |      26 | 152384.64
  4 |          ->  Vector Streaming (type: GATHER)                    | 424.184          | 13372949 | 13372949 |            | 200KB       |          |         |      26 | 148902.10
  5 |             ->  CStore Scan on dmisc.dm_dim_cbg_customer_info_d | [14.669, 39.213] | 13372949 | 13372949 |            | [6MB, 6MB]  | 1MB      |         |      26 | 148583.60
2. SQL优化改写
如上所属计划,CN会GATHER所有数据到CN开窗计算,SQL执行将近2s。改写思路可以尝试减少CN GATHER数据量,将SQL改写成明细和汇总数据的关联,同时按照LIMIT OFFSET减少明细数据,改写如下:
EXPLAIN PERFORMANCE
SELECT t1.*,t2.cnt FROM
(select cust_key,cust_acct,cust_id from DMISC.DM_DIM_CBG_CUSTOMER_INFO_D limit 100 offset 0) t1
LEFT JOIN (SELECT COUNT(1) AS cnt FROM DMISC.DM_DIM_CBG_CUSTOMER_INFO_D) t2 ON 1=1;
改写后查询计划如下:
  1 | ->  Row Adapter                                                          | 16.352           |      100 |      100 |            | 39KB           |          |         |      34 | 149289.98
  2 |    ->  Vector Streaming (type: GATHER)                                   | 16.335           |      100 |      100 |            | 136KB          |          |         |      34 | 149289.98
  3 |       ->  Vector Nest Loop Left Join (4, 8)                              | [11.786, 11.786] |      100 |      100 |            | [248KB, 248KB] | 1MB      |         |      34 | 149283.73
  4 |          ->  Vector Limit                                                | [0.093, 0.093]   |      100 |      100 |            | [8KB, 8KB]     | 1MB      |         |      26 | 2.38
  5 |             ->  Vector Streaming(type: BROADCAST)                        | [0.091, 0.091]   |      100 |     4800 |            | [536KB, 536KB] | 2MB      |         |      26 | 114.27
  6 |                ->  Vector Limit                                          | [0.156, 0.237]   |     4800 |     4800 |            | [16KB, 16KB]   | 1MB      |         |      26 | 53.33
  7 |                   ->  CStore Scan on dmisc.dm_dim_cbg_customer_info_d    | [0.107, 0.167]   |    48000 | 13372949 |            | [6MB, 6MB]     | 1MB      |         |      26 | 148583.60
  8 |          ->  Vector Materialize                                          | [11.553, 11.553] |      101 |       48 |            | [272KB, 272KB] | 16MB     | [9,9]   |       8 | 149280.32
  9 |             ->  Vector Aggregate                                         | [11.422, 11.422] |        1 |       48 |            | [272KB, 272KB] | 1MB      |         |       8 | 149280.31
 10 |                ->  Vector Streaming(type: BROADCAST)                     | [11.342, 11.342] |       48 |       48 |            | [520KB, 520KB] | 2MB      |         |       8 | 149280.31
 11 |                   ->  Vector Aggregate                                   | [4.441, 9.265]   |       48 |       48 |            | [272KB, 272KB] | 1MB      |         |       8 | 149280.12
 12 |                      ->  CStore Scan on dmisc.dm_dim_cbg_customer_info_d | [3.653, 8.151]   | 13372949 | 13372949 |            | [6MB, 6MB]     | 1MB      |         |       0 | 148583.60
查询执行时间由2000ms优化至17ms,优化优化110多倍,性能优化效果明显。
3. 非相关子查询
上述优化改写方案大部分场景下性能提升效果明显,但是在个别场景下,因为nest loop存在,性能可能还不达标。那有什么办法可以消除NESTLOOP吗?答案是有的。
我们知道COUNT其实是个常量,那能不能先把COUNT求出来,然后让它作为查询的一个字段呢?
求出COUNT:SELECT COUNT(1) AS cnt FROM DMISC.DM_DIM_CBG_CUSTOMER_INFO_D
COUNT作为查询一个字段,改写如下:
EXPLAIN PERFORMANCE
select cust_key,cust_acct,cust_id,(SELECT COUNT(1) AS cnt FROM DMISC.DM_DIM_CBG_CUSTOMER_INFO_D)
改写后计划如下:
  1 | ->  Row Adapter                                                       | 12.777         |      100 |      100 |            | 39KB           |          |         |      26 | 149288.53
  2 |    ->  Vector Limit                                                   | 12.758         |      100 |      100 |            | 8KB            |          |         |      26 | 149288.53
  3 |       ->  Vector Streaming (type: GATHER)                             | 12.755         |      100 |     4800 |            | 136KB          |          |         |      26 | 206.46
  4 |          ->  Vector Limit                                             | [6.456, 7.579] |     4800 |     4800 |            | [16KB, 16KB]   | 1MB      |         |      26 | 53.33
  5 |             ->  CStore Scan on dmisc.dm_dim_cbg_customer_info_d       | [6.433, 7.563] |    48000 | 13372949 |            | [6MB, 6MB]     | 1MB      |         |      26 | 148583.60
  6 |       ->  Row Adapter  [5, InitPlan 1 (returns $0)]                   | [6.242, 7.424] |       48 |       48 |            | [24KB, 24KB]   | 1MB      |         |       8 | 149280.31
  7 |          ->  Vector Aggregate                                         | [6.237, 7.419] |       48 |       48 |            | [272KB, 272KB] | 1MB      |         |       8 | 149280.31
  8 |             ->  Vector Streaming(type: BROADCAST)                     | [6.086, 7.310] |     2304 |     2304 |            | [520KB, 520KB] | 2MB      |         |       8 | 149280.31
  9 |                ->  Vector Aggregate                                   | [4.458, 5.056] |       48 |       48 |            | [272KB, 272KB] | 1MB      |         |       8 | 149280.12
 10 |                   ->  CStore Scan on dmisc.dm_dim_cbg_customer_info_d | [3.647, 4.153] | 13372949 | 13372949 |            | [6MB, 6MB]     | 1MB      |         |       0 | 148583.60
由上述执行计划可以看出,NESTLOOP已经消除。性能与第二种优化方法性能接近,在某些场景下该方法更具优势。
细心的读者可能已经发现,这种改法不就是非相关子查询嘛!是的,对于类似SQL都可以使用非相关子查询的方法进行改写优化。
比如以下SQL:
WITH TMP AS(
  SELECT
    case
      when length('[“202309“]') = 6 then '[“202309“]' || '01'
      WHEN length('[“202309“]') <> 8 THEN TO_CHAR(CURRENT_DATE, 'YYYYMMDD')
    END AS V_DATE
  from
    DUAL
SELECT
  BG_CODE,
  BG_CN_NAME,
  V_DATE
FROM
FROM
DMSALESW.DM_SALE_BUSI_DSCT_SUM_F C
LEFT JOIN TMP T ON 1 = 1;
TMP输出为一个常数,这种写法会导致NESTLOOP,按照非相关子查询改法如下:
SELECT
BG_CODE,
BG_CN_NAME,
	SELECT
	case
	END AS V_DATE
	from
	DUAL
) AS V_DATE
FROM
FROM
