手拉手全栈springboot+vue2+Element实现分页
QGS 发表于 2023/12/19 21:32:46 2023/12/19
【摘要】 手拉手全栈springboot+vue2+Element实现分页
环境介绍
技术栈
springboot+mybatis-plus+mysql+vue2+Element
软件
版本
mysql
8
IDEA
IntelliJ IDEA 2022.2.1
JDK
1.8
Spring Boot
2.7.13
mybatis-plus
3.5.3.2
后端
实体类、持久层、服务层使用Mybatis-Plus逆向工程生成
实体类
@TableName(value ="t_address")
@Data
public class TAddress implements Serializable {
    @TableId(type = IdType.AUTO)
    private Integer id;
    private String address;
    @TableField(exist = false)
    private static final long serialVersionUID = 1L;
持久层(mapper)
@Mapper
public interface TAddressMapper extends BaseMapper<TAddress> {
    Integer getTotal();
TAddressMapper.xml
<select id="getTotal">
    SELECT count(*) FROM `t_address`
</select>
服务层
public interface TAddressService extends IService<TAddress> {
    Integer getTotal();
@Service
@DS("sys2")
public class TAddressServiceImpl extends ServiceImpl<TAddressMapper, TAddress>
    implements TAddressService {
    @Autowired
    private   TAddressMapper tAddressMapper;
    @Override
    public Integer getTotal() {
        return tAddressMapper.getTotal();
控制层
@GetMapping("/getpage")
public Map<String,Object> getPageTAddress(@RequestParam(defaultValue = "1") int pageNum,
                                          @RequestParam(defaultValue = "10") int pageSize) {
    PageHelper.startPage(pageNum,pageSize);
    List<TAddress> data = tAddressService.list();
    Integer  total= tAddressService.getTotal();
     HashMap<String, Object> res = new HashMap<>();
     res.put("data",data);
     res.put("total",total);
    return res;
前端
Pagination.vue
<template>
    <div class="block">
        <el-table
    :data="tableData"
    style="width: 100%"
    :row-class-name="tableRowClassName">
    <!-- <el-table-column
      prop="date"
      label="日期"
      width="180">
    </el-table-column> -->
    <el-table-column
      prop="id"
      label="ID"
      width="180">
    </el-table-column>
    <el-table-column
      prop="address"
      label="地址">
    </el-table-column>
  </el-table>
      <el-pagination
        @size-change="handleSizeChange"
        @current-change="handleCurrentChange"
        :current-page="currentPage4"
        :page-sizes="[10,20,30,40]"
        :page-size="pageSize"
        layout="total, sizes, prev, pager, next, jumper"
        :total="total">
      </el-pagination>
    </div>
  </template>
<style>
  .el-table .warning-row {
    background: oldlace;
  .el-table .success-row {
    background: #f0f9eb;
</style>
  <script>
  export default {
    data() {
      return {
        tableData: [],
        total: 0,
        pageNum: 1,
        pageSize: 10
    created() {
      this.load()
    methods: {
      load() {
        this.$add.get("/getpage?"+"pageNum="+this.pageNum+"&pageSize="+this.pageSize).then((response)=>{
          console.log(response)
      this.tableData = response.data.data
      this.total = response.data.total
      handleSizeChange(pageSize) {
        console.log(pageSize)
        this.pageSize = pageSize
        this.load()
      handleCurrentChange(pageNum) {
        console.log(pageNum)
        this.pageNum = pageNum
        this.load()
  </script>
