好未来视频面知识点储备+面后总结
SHQ1874009 发表于 2023/12/18 09:56:31 2023/12/18
【摘要】 一、情景介绍时间:2016.10.12 13:00-地点:宿舍事件:好未来视频面 二、知识点储备 2.1 数据结构 2.1.1 单链表反转public class ListNode { int val; ListNode next = null; ListNode(int val) { this.val = val; }} private static ListNode ReverseL...
一、情景介绍
  • 时间:2016.10.12 13:00-
  • 地点:宿舍
  • 事件:好未来视频面
二、知识点储备
2.1 数据结构
2.1.1 单链表反转
	int val;
	ListNode(int val) {
		this.val = val;
	private static ListNode ReverseList(ListNode head) {
		if (head == null)
			return null;
		ListNode reversedHead = null;
		ListNode current = head;
		ListNode pNext = null;
		ListNode pre = null;
		while (current != null) {
			pNext = current.next;
			current.next = pre;
			if (pNext == null)			// 确定反转后的头结点
				reversedHead = current;
			pre = current;
			current = pNext;
		return reversedHead;
2.2.2 合并两个排序的链表
	 * @param ListNode
	 * 				链表1
	 * @param ListNode
	 * 				链表2
	 * @return ListNode
	 * 				合并后的链表
	private static ListNode Merge(ListNode list1,ListNode list2) {
		// 其中之一为空或均为空
		if(list1 == null || list2 == null){
			return list1 == null?(list2 == null?list1:list2):list1;
		}else{
			ListNode headNode = null;
			if(list1.val < list2.val){
				headNode = list1;
				headNode.next = Merge(list1.next, list2);
			}else{
				headNode = list2;
				headNode.next = Merge(list1, list2.next);
			return headNode;
2.2.3 求两个链表的第一个公共节点问题
private static ListNode FindFirstCommonNode2(ListNode pHead1, ListNode pHead2) {
    	// 第一步首先是特殊输入测试,即为空或长度为0的情况,切记!
    	if(pHead1 == null || pHead2 == null){
    		return null;
    	int len1 = getLength(pHead1);
    	int len2 = getLength(pHead2);
    	int difLen = 0;
    	// pHeadTmp1指向较长链表
    	ListNode pHeadLong = pHead1;
    	// pHeadTmp2指向较短链表
    	ListNode pHeadShort = pHead2;
    	if(len1 > len2){
    		difLen = len1 - len2;
    	}else{
    		pHeadLong = pHead2;
    		pHeadShort = pHead1;
    		difLen = len2 - len1;
    	// 1.先让长的链表走difLen步
    	for(int i = 0; i < difLen; i++){
    		pHeadLong = pHeadLong.next;
    	// 2.对齐后,两个链表同时走
    	while(pHeadLong != null && pHeadShort != null && pHeadLong != pHeadShort){
    		pHeadShort = pHeadShort.next;
		return pHeadLong;
    private static int getLength(ListNode pHead){
    	int len = 0;
    	while(pHead != null){
    		len++;
    		pHead = pHead.next;
    	return len;
三、多线程
3.1 线程与进程的区别
3.2 实现生产者、消费者
package cn.edu.ujn.producer_customer;
// 公共资源类
class PublicResource {
	private static final int MAX_RESOURCE_NUMBER = 10;
    private int number = 0;
     * 增加公共资源
    public synchronized void increace() {
        while (number > MAX_RESOURCE_NUMBER) {
            try {
                wait();
            } catch (InterruptedException e) {
                e.printStackTrace();
        // 添加资源
        number++;
        System.out.println(number);
        // 进行通知
        notify();
     * 减少公共资源
    public synchronized void decreace() {
        while (number == 0) {
            try {
                wait();
        number--;
        notify();
// 生产者线程,负责生产公共资源
class ProducerThread implements Runnable {
    private PublicResource resource;
    public ProducerThread(PublicResource resource) {
        this.resource = resource;
    @Override
    public void run() {
        for (int i = 0; i < 10; i++) {
            try {
                Thread.sleep((long) (Math.random() * 1000));
            resource.increace();
// 消费者线程,负责消费公共资源
class ConsumerThread implements Runnable {
    public ConsumerThread(PublicResource resource) {
    @Override
    public void run() {
            try {
            resource.decreace();
public class ProducerConsumerTest {
    	PublicResource resource = new PublicResource();
        new Thread(new ProducerThread(resource)).start();
        new Thread(new ConsumerThread(resource)).start();
3.3 多线程发短信
四、设计模式
五、排序
六、查找
七、存储
八、算法
  • 克鲁斯卡尔算法
九、J2EE
十、面后总结
  1. 数据库索引(聚集索引、组合、主键、普通、唯一)
  2. select * from db_name where name=’demo’order by age group by age;执行顺序。
  3. 提高数据库查询效率的措施。
  4. 基本数据类型 int、long、short、float、double、char、boolean、byte
  5. float与double的区别:精度不同。
  6. 冒泡排序、快速排序;
数据库这一块自己是完败!自己只是用了mysql,但是对于里面的概念自己真的表示无能为力!其中数据库索引这一块,其实在项目开发中,自己也没有使用到。惭愧无比!但是简历中明明写了熟悉SQL语句、存储过程和函数(从第二道问题中就完全推翻了自己。)。不能使之成为自己的鸡肋!
Mysql语法顺序,即当sql中存在下面的关键字时,它们要保持这样的顺序:
select[distinct]、from、join(如left join)、on、where、group by、having、union、order by、limit
Mysql执行顺序,即在执行时sql按照下面的顺序进行执行:
 from、on、join、where、group by、having、select、distinct、 union、order by
group by要和聚合函数一起使用,例如:
select a.Customer,sum(a.OrderPrice) from orders a where a.Customer='Bush' or a.Customer = 'Adams' group by a.Customer
  • 数据库+Java是自己找工作的双翼。
通过面试,还可以发现的问题就是自己的简历中项目过少,导致面试官关于项目的面试中,所问的问题不会太多(这是面试官反映的)。但是,自己感觉也只有“立马送药”这个项目可以拿得出手,其他的项目只可说是练习项目,例如“鲜花礼品网”、“CTCs监测系统”、“竞彩APP”。
另外,如果视频面的话,最好戴耳麦,否则会很尴尬的。自己当时就没有戴耳麦,结果说话时音调稍不均匀,就会带来很大的噪声与回音,严重影响了面试质量。第一次视频面,姑且作为教训。
最后可以问面试官问题,最恰当的问题莫过于“请评价一下我此次的视频面,还欠缺哪方面的知识储备,面试结果何时可以给出”。
最后,自己给自己的面试评分为55。
