app
zxcasdqwe987 发表于 2023/12/16 00:13:10 2023/12/16
【摘要】 1. 容器集群创建基于在Huawei Cloud API的云容器引擎CCE Python模块,使用以下信息,在/root目录下手动编写cce_cluser.yaml文件。云服务器的/root/目录下编写cce_cluster_manager.py 文件,编码实现读取cce_cluser.yaml,创建“按需计费”的CCE容器引擎集群(Cluster),创建后根据名称查询该集群(Cluster...
1. 容器集群创建
云服务器的/root/目录下编写cce_cluster_manager.py 文件,编码实现读取cce_cluser.yaml,创建“按需计费”的CCE容器引擎集群(Cluster),创建后根据名称查询该集群(Cluster)的详细信息,通过控制台以Json格式输出该集群的信息。
创建CCE集群的信息如下,其他必要信息不限。
  • CCE名称:chinaskillscce2022。
  • 按需计费:集群版本为v1.21。
  • 集群规模:节点数50。
  • 网络模式:VPC网络。
编写cce_cluster_manager.py文件如下:
# Copyright Jiangsu One Cloud Technology Development Co. LTD. All Rights Reserved.
# 版权: 江苏一道云科技发展有限公司,版权所有!
import time
from huaweicloudsdkcce.v3 import *
#CCE 3.0
from huaweicloudsdkcore.auth.credentials import BasicCredentials
from huaweicloudsdkcce.v3.region.cce_region import CceRegion
from huaweicloudsdkcore.exceptions import exceptions
def get_aksk_v3_cce_token():
    ak = "DQVNQ7NHZCRS9XFCJAME"
    sk = "jGYmdH66dfittUCEnlr4s9gJjb6xxN4P3tuyPl4j"
    # EZA2ZDBZANMYYEHUHYBD
    # GMK5KA5qYRmQiuaIpTyFay6QbZ1pohYGPBmAGklY
    token = BasicCredentials(ak, sk)
    client = CceClient.new_builder() \
        .with_credentials(token) \
        .with_region(CceRegion.value_of("cn-north-4")) \
        .build()
    return client
class Cluster_Manager:
    def __init__(self,client):
        self.client = client
    def delete_same_cluster(self,name):
        client = self.client
        req = ListClustersRequest()
        resp = client.list_clusters(req)
        for cluster in resp.items:
            if cluster.metadata.name == name:
                clusterId = cluster.metadata.uid
                delete_req = DeleteClusterRequest()
                delete_req.cluster_id = clusterId
                delete_req.delete_efs = "true"
                delete_req.delete_evs = "true"
                delete_req.delete_net = "true"
                delete_req.delete_obs = "true"
                delete_req.delete_sfs = "true"
                delete_resp = client.delete_cluster(delete_req)
                print(f"删除集群成功:{delete_resp}")
            return ""
    def create_cluster(self):
        req = CreateClusterRequest()
        metadataBody = ClusterMetadata(
            name="test-cluster"
        hostNetwork = HostNetwork(
            vpc="178938e4-fb8b-4491-831b-440e3f8d24fa",
            subnet="8c9a2894-acc8-4e41-a451-fe11b84e2b9f",
        Cidrs = [
            ContainerCIDR(
                cidr="10.0.0.0/16"
        containetNetwork = ContainerNetwork(
            mode="vpc-router",
            cidrs=Cidrs,
        SpecBody = ClusterSpec(
            category="CCE",
            type="VirtualMachine",
            flavor="cce.s1.small",
            version="v1.21",
            host_network=hostNetwork,
            container_network=containetNetwork,
            kube_proxy_mode="iptables",
        req.body = Cluster(
            kind="Cluster",
            api_version="v3",
            metadata=metadataBody,
            spec=SpecBody,
        result = client.create_cluster(req)
        print(f"创建的集群信息为:{result}")
    def list_cluster(self):
        req.detail = "true"
        req.status = "Available"
        req.type = "VirtualMachine"
        req.version = "v1.21"
        result = client.list_clusters(req)
        print(f"获取到当前项目下的集群信息为:{result}")
    def get_clusterId_by_name(self,name):
                print(f"集群的ID为:{clusterId}")
            return ""
    def show_cluster(self,clusterId):
        req = ShowClusterRequest()
        req.detail = "true"
        result = client.show_cluster(req)
        print(f"展示当前集群的信息为:{result}")
if __name__ == "__main__":
    cluster_m = Cluster_Manager(get_aksk_v3_cce_token())
    # delete_same = cluster_m.delete_same_cluster("test-cluster")
    # time.sleep(60) #执行删除操作后,睡眠1分钟,因为需要1分钟的时间来将集群彻底删除。
    # create_cluster = cluster_m.create_cluster()
    # time.sleep(480) #睡眠8分钟,这段时间,在创建集群。需要等集群创建完成之后,才能获取到信息。
    list_cluster = cluster_m.list_cluster()
    clusterId = cluster_m.get_clusterId_by_name("chinaskillscce2022")
show_cluster = cluster_m.show_cluster(clusterId)
------------------------------------------执行结果---------------------------------
python3 cce_cluster_manager.py
创建的集群信息为:{"kind": "Cluster", "apiVersion": "v3", "metadata": {"name": "test-cluster", "uid": "3134ac35-492b-11ed-94b1-0255ac1002cd", "annotations": {"jobid": "31557172-492b-11ed-94b1-0255ac1002cd", "resourceJobId": "31367b5c-492b-11ed-94b1-0255ac1002cd"}, "creationTimestamp": "2022-10-11 06:08:57.631041168 +0000 UTC", "updateTimestamp": "2022-10-11 06:08:57.63104138 +0000 UTC"}, "spec": {"category": "CCE", "type": "VirtualMachine", "flavor": "cce.s1.small", "version": "v1.21", "platformVersion": "cce.4.10", "hostNetwork": {"vpc": "600b8e93-fbaa-4119-87c2-87f0678dd189", "subnet": "2bfaefa7-bf01-4798-9c5c-a29fe989a24b"}, "containerNetwork": {"mode": "vpc-router", "cidr": "10.0.0.0/16", "cidrs": [{"cidr": "10.0.0.0/16"}]}, "eniNetwork": {}, "authentication": {"mode": "rbac", "authenticatingProxy": {}}, "billingMode": 0, "kubernetesSvcIpRange": "10.247.0.0/16", "kubeProxyMode": "iptables", "extendParam": {"orderID": ""}}, "status": {"phase": "Creating", "jobID": "31557172-492b-11ed-94b1-0255ac1002cd"}}
获取到当前项目下的集群信息为:{"kind": "Cluster", "apiVersion": "v3", "items": [{"kind": "Cluster", "apiVersion": "v3", "metadata": {"name": "test-cluster", "uid": "3134ac35-492b-11ed-94b1-0255ac1002cd", "annotations": {"activeNodesNumber": "0", "faultNodesNumber": "0", "installedAddonInstances": "[{\"addonTemplateName\":\"everest\",\"version\":\"1.3.17\",\"status\":\"installing\"},{\"addonTemplateName\":\"coredns\",\"version\":\"1.23.1\",\"status\":\"installing\"}]", "totalNodesCPU": "0", "totalNodesMemory": "0", "totalNodesNumber": "0"}, "labels": {"FeatureGates": "elbv3,"}, "creationTimestamp": "2022-10-11 06:08:57.631041 +0000 UTC", "updateTimestamp": "2022-10-11 06:14:01.876433 +0000 UTC"}, "spec": {"category": "CCE", "type": "VirtualMachine", "flavor": "cce.s1.small", "version": "v1.21", "platformVersion": "cce.4.10", "hostNetwork": {"vpc": "600b8e93-fbaa-4119-87c2-87f0678dd189", "subnet": "2bfaefa7-bf01-4798-9c5c-a29fe989a24b", "SecurityGroup": "a1ccd90a-c622-4060-a243-c6b59035bec0"}, "containerNetwork": {"mode": "vpc-router", "cidr": "10.0.0.0/16"}, "eniNetwork": {}, "authentication": {"mode": "rbac", "authenticatingProxy": {}}, "billingMode": 0, "masters": [{"availabilityZone": "cn-east-3a"}], "kubernetesSvcIpRange": "10.247.0.0/16", "kubeProxyMode": "iptables", "az": "cn-east-3a", "extendParam": {"alpha.cce/fixPoolMask": "", "kubernetes.io/cpuManagerPolicy": "", "upgradefrom": ""}, "supportIstio": true}, "status": {"phase": "Available", "endpoints": [{"url": "https://192.168.0.4:5443", "type": "Internal"}]}}]}
cce.cluster.yaml:
#https://apiexplorer.developer.huaweicloud.cn/apiexplorer/doc
kind: Cluster
apiVersion: v3
metadata:
  annotations:
    cluster.install.addons.external/install: '[{"addonTemplateName":"icagent"}]'
spec:
  category: CCE
  flavor: cce.s2.small
  version: v1.21
  hostNetWork:
    vpc: eb35f318-0cdb-4632-a068-414c2285a409
    subnet: 0b51072e-0225-4f30-934e-106f684ca67a
  containerNetWork:
    mode: vpc-router
    cidr: 10.10.0.0/16
  kubernetesSvcIpRange: 10.247.0.0/16
  description: ''
  billingMode: 0
  extendParam:
    kubeProxyMode: iptables
    alpha.cce/fixPoolMask: '25'
  authentication:
    mode: rbac
  ipv6enable: false
2. ECS云主机管理的命令行工具开发
使用已建好的运维开发环境,在/root/目录下创建ecs_manager.py脚本,完成ECS云主机管理,ecs_manager.py程序支持命令行参数执行。
提示说明:华为云主机支持安装所需Python库,需安装所开发程序所依赖的Python库。
(1)程序支持根据命令行参数,创建1个云主机。
创建待成功,再返回查询该云主机的信息,结果以Json格式输出到控制台。
参考执行实例如下:
python3 ecs_manager.py create --input '{ "name": " chinaskill001", "imagename": "CentOS 7.9 64bit"}'
  • 位置参数“create”,表示创建;
  • 参数“-i或–input”,格式为Json格式文本的云主机的名称、镜像名称2个信息。其他参数同上述开发环境云主机一致。
(2)支持查询给定具体名称的ECS云主机查询。
参考执行实例如下:
python3 ecs_manager.py get --name chinaskill001-o chinaskill001.json
  • 位置参数“get”,表示查询ECS;
  • 参数“-n或–name”支持指定名称ECS查询,类型为string。
  • 参数“-o或–output”支持查询该ECS信息输出到文件,格式为Json格式。
(3)程序支持查询目前区域账号下所有的ECS云主机。
参考执行实例如下:
python3 ecs_manager.py getall -o huawei_all_ecs.yaml
  • 位置参数“getall”,表示查询所有ECS云主机;
  • 参数“-o 或–output”支持输出到文件,格式为yaml格式。
(4)支持删除指定的名称的云主机。
参考执行实例如下:
python3 ecs_manager.py delete --name chinaskill001
  • 位置参数“delete”,表示删除一个ECS云主机;返回response,通过控制台输出。
  • 参数“-n或–name”支持指定名称查询,类型为string。
ces_create.py:
# coding: utf-8
from http import client
import json
from pydoc import cli
from huaweicloudsdkecs.v2.region.ecs_region import EcsRegion
from huaweicloudsdkecs.v2 import *
import time
from huawei_ecs_server import get_server_id
#Token
def get_aksk_v3_ecs_token():
    ak = "8MJITOJBPKNUTADFGCUA"
    sk = "yehuP3rojiH0ucj1pnCev3VawVd4VwxDr1mCWLRh"
    token = BasicCredentials(ak,sk)
    client = EcsClient.new_builder().\
        with_credentials(token).\
        with_region(EcsRegion.value_of("cn-east-3")).build()
    return client
class server_manager:
    def create_server(self,name,imagename):
        request = CreateServersRequest()
        listPrePaidServerSecurityGroupSecurityGroupsServer = [
            PrePaidServerSecurityGroup(
                id="b46f7f8c-5e1d-4e85-91c6-1ee43ce7c9a5"
        listPrePaidServerDataVolumeDataVolumesServer = [
            PrePaidServerDataVolume(
                volumetype="SSD",
                size=50
        rootVolumePrePaidServerRootVolume = PrePaidServerRootVolume(
            volumetype="SSD",
            size=100
        bandwidthPrePaidServerEipBandwidth = PrePaidServerEipBandwidth(
            size=10,
            sharetype="PER"
        eipPrePaidServerEip = PrePaidServerEip(
            iptype="5_bgp",
            bandwidth=bandwidthPrePaidServerEipBandwidth
        publicipPrePaidServerPublicip = PrePaidServerPublicip(
            eip=eipPrePaidServerEip,
            delete_on_termination=True
        listPrePaidServerNicNicsServer = [
            PrePaidServerNic(
                subnet_id="2bfaefa7-bf01-4798-9c5c-a29fe989a24b"
        serverPrePaidServer = PrePaidServer(
            image_ref=imagename,
            flavor_ref="c7.xlarge.2",
            name=name,
            vpcid="600b8e93-fbaa-4119-87c2-87f0678dd189",
            nics=listPrePaidServerNicNicsServer,
            publicip=publicipPrePaidServerPublicip,
            root_volume=rootVolumePrePaidServerRootVolume,
            data_volumes=listPrePaidServerDataVolumeDataVolumesServer,
            security_groups=listPrePaidServerSecurityGroupSecurityGroupsServer,
        request.body = CreateServersRequestBody(
            server=serverPrePaidServer
        response = client.create_servers(request)
        # time.sleep(10)
        print(f"创建的云服务器信息为:{response}")
        return response
    def get_server_id(self,name):
        req = ListServersDetailsRequest()
        resp = client.list_servers_details(req)
        for server in resp.servers:
            if server.name == name:
                return server.id
    def get_server_detail(self,name):
        strins = str(resp)
        return strins
    def getall_ecs(self):
        strings = str(resp)
        return strings
    def get_server(self,id):
        req = ShowServerRequest()
        req.server_id = id
        resp = client.show_server(req)
        print(f"获取到的云服务器信息为:{resp}")
        return resp
    def delete_server(self,name):
        request = DeleteServersRequest()
        listServersbody = [
            ServerId(
                id=get_server_id(name)
        request.body = DeleteServersRequestBody(
            servers=listServersbody
        response = client.delete_servers(request)
        return response
    server_m = server_manager(get_aksk_v3_ecs_token())
    # create
    # create_servers = server_m.create_server("chinaskill","f025bf3e-3173-4f2a-8f59-34aca5bd853d")
    #detail
    # list_details = server_m.get_server_detail("chinaskill001","chinaskill001.json")
    # id
    # id = server_m.get_server_id("chinaskill")
    # print(f"云服务器的ID为:{id}")
    # time.sleep(15)
    # get
    # show_server = server_m.get_server(id)
    # time.sleep(20)
    # delete
    delete_servers = server_m.delete_server("chinaskill")
ecs_manager.py:
#encoding:utf-8
# coding: utf-8
#encoding:utf-8
import argparse
from ast import arg
from cgi import print_arguments
from cgitb import reset
import json,yaml
import ces_create
# get all user
print("-----------begin-----------------")
ecs_m = ces_create.server_manager(ces_create.get_aksk_v3_ecs_token())
def define_args(parser):
    定义程序支持的args
    :return:
    # parser = argparse.ArgumentParser()
    #增加控制命令(postion 位置参数,必须)
    parser.add_argument('command',
                        help='Resource command name',
                        type=str)
    # parser.add_argument('delete',
    #                     help='delete a resource',
    #                     type=str)
    #可选参数(可有可无)
    parser.add_argument('-n', '--name',  # 可选参数,删除的名称
                        help='The Name of the resource',  # 输入-h展示
                        type=str)
    parser.add_argument('-i', '--input',  # 可选参数,删除的名称
                        help='The input json format text ',  # 输入-h展示
                        type=str)
    parser.add_argument('-o', '--output',  # 可选参数,删除的名称
                        help='The output file path ',  # 输入-h展示
                        type=str)
def parse_args(parser):
    args = parser.parse_args()
    # print(args)
    # print('Provided name value is %r.' % args.command)
    # print('Provided name value is %r.' % args.name)
    if args.command:
        if args.command == "create":
            print("create Cloud ECSserver")
            create_ecs(args)
        elif args.command == "getall":
            print("Get All ECSserver")
            getall_ecs(args)
        elif args.command == "get":
            print("Get ECSserver")
            get_ecs(args)
        elif args.command == "delete":
            print("Delete ECSserver")
            delete_ecs(args)
        else:
            print("Note support command name!")
def create_ecs(args):
    print('Provided command value is %r.' % args.command)
    print('Provided input value is %r.' % args.input)
    # print('Provided output value is %r.' % args.output)\
    ecs_dict = json.loads(args.input)
    print(ecs_dict)
    res = ecs_m.create_server(ecs_dict["name"],ecs_dict["imagename"])
    print(res)
def get_ecs(args):
    result = ecs_m.get_server_detail(args.name)
    output_file = args.output
    with open(output_file, 'w') as jsonfile:
        json.dump(result, jsonfile, indent=4)
    print(result)
def getall_ecs(args):
    result = ecs_m.getall_ecs()
    print(result)
    configuration = json.loads(result)
    with open(output_file,"w")as yamlfile:
        yaml.dump(configuration,yamlfile)
    print(result)
def delete_ecs(args):
    result = ecs_m.delete_server()
    print(result)
if __name__ == '__main__':
    define_args(parser)
    parse_args(parser)
3. ECS云主机管理与监控的Restful APIs HTTP服务封装
云服务器的/root/目录下编写huawei_ecs_server.py文件编写Python程序,实现华为ECS云主机管理与云主机操作系统性能远程监控。所有的资源申请区域为“华北-北京四”,所有服务封装成Restful APIs方式,host为127.0.0.1,端口8888,供外部检测。
提示说明:华为云主机支持安装所需Python库,需安装程序所依赖的Python库。
具体要求:
(1)POST /ecs/server 创建云主机,需要等待成功该云主机后,返回查询该云主机信息。request传输的数据为application/json,Json包含2个必备信息,名称、镜像名称。
Json数据格式案例如下:
{ "name": " cloud001", "imagename": "CentOS 7.9 64bit"}
  • 其他必备参数与开发环境云主机一致。Response的Body以Json格式,返回所创建成功的主机详细信息。
(2)GET /ecs/server/{name}查询云主机;Response的Body以yaml格式。
GET /ecs/server/{name}/os查询所指定ID云主机的操作系统信息;Response的Json格式返回。返回格式要求如下:
  • os_release:操作系统的版本系统。
  • cpu_util:CPU使用率%。
  • mem_util:内存使用率%。
  • disk_util:磁盘使用率%。
(3)DELETE /ecs/server/{name}删除云主机;Response的Body以Json格式。
os_remote_monitor.py:
import os
import paramiko
# coding: utf-8
# uname、hostname、cpu_util、mem_util、ip_address;
def create_remote_client(ip, port, name, pwd, timeout=30):
    client = paramiko.SSHClient()
    client.set_missing_host_key_policy(paramiko.AutoAddPolicy())
    # 连接
    try:
        client.connect(ip, port, name, pwd)
        print('----------连接成功-----------------')
    except:
        print("----------连接失败-----------------")
    return client
# 实时读取
def run_ssh_command(ssh_client, cmd):
    try:
        stdin, stdout, stderr = ssh_client.exec_command(cmd, get_pty=True)
        #strip \n\r
        return stdout.read().decode()
    except Exception as e:
        print("execute command %s error, error message is %s" % (cmd, e))
def getos_uname(client):
    return run_ssh_command(client, "cat /etc/redhat-release").strip()
# return run_ssh_command(client, "cat /etc/redhat-release")
def getos_hostname(client):
    return run_ssh_command(client, "hostname").strip()
def getos_cpu_util(client):
    command_name = "vmstat 1 1|sed '1d'|sed '1d'|awk '{print $15}'"
    # https: // blog.csdn.net / qq_37275405 / article / details / 119210527
    result = run_ssh_command(client, command_name).strip()
    return result + '%'
    # 3次平均值
    # cpu = "vmstat 1 3|sed '1d'|sed '1d'|awk '{print $15}'"
    #  stdin, stdout, stderr = ssh.exec_command(cpu)
    #  cpu = stdout.readlines()
    #  cpu_usage = str(round((100 - (int(cpu[0]) + int(cpu[1]) + int(cpu[2])) / 3), 2)) + '%‘
import pstats
def getos_mem_util(client):
    # free | sed -n '2,2p'| awk '{print $2}' line and collumn
    command = "cat /proc/meminfo|sed -n '1,4p'|awk '{print $2}'"
    # [root @ ecs - 1049 ~]  # cat /proc/meminfo|sed -n '1,4p'|awk '{print $2}'
    # MemTotal: 3754864
    # MemFree: 3136028
    # MemAvailable: 3326468
    # Buffers: 28172
    # 3754864
    # 3135860
    # 3326272
    # 28140
    result = run_ssh_command(client, command)
    mem = result.split("\r\n")
    mem_total = round(int(mem[0]) / 1024)
    mem_total_free = round(int(mem[1]) / 1024)
    mem_usage = str(round(((mem_total - mem_total_free) / mem_total) * 100, 2)) + "%"
    return mem_usage
def getos_ip_address(client):
    result = run_ssh_command(client, "hostname -I")
    return result.strip()
def getos_disk_util(client):
    result = run_ssh_command(client, "df -h / | sed -n '2,2p' | awk '{print $5}'")
def getos_info(client):
    uname = getos_uname(client)
    hostname = getos_hostname(client)
    cpu_util = getos_cpu_util(client)
    mem_util = getos_mem_util(client)
    ip_addr = getos_ip_address(client)
    disk_util = getos_disk_util(client)
    osinfo = {
        "os_release": uname,
        "hostname": hostname,
        "cpu_util": cpu_util,
        "mem_util": mem_util,
        "ip_addr": ip_addr,
        "disk_util": disk_util
    import json
    json_str = json.dumps(osinfo, indent=4)
    return json_str
def get_remote_server_os_info(ip, port, user, password):
    client = create_remote_client(ip, port, user, password)
    os_info = getos_info(client)
    return os_info
    os_info = get_remote_server_os_info("124.71.205.227",22,"root","Abc@1234")
    print(os_info)
# 3.linux查看版本当前操作系统发行信息 cat /etc/issue 或 cat /etc/centos-release
# https://blog.csdn.net/qq_37275405/article/details/119210527
# [root@ecs-1049 ~]# df -h /
# Filesystem      Size  Used Avail Use% Mounted on
# /dev/sda1        40G  2.2G   36G   6% /
# command = "df -h / | sed -n "2,2p" | awk '{print $5}'"
# [root@ecs-1049 ~]# df -h / | sed -n "2,2p" | awk '{print $5}'
# 6%
# ----------连接成功-----------------
#     "os_release": "CentOS Linux release 7.9.2009 (Core)",
#     "hostname": "ecs-1049",
#     "cpu_util": "99%",
#     "mem_util": "10.91%",
#     "ip_addr": "192.168.0.238",
#     "disk_util": "6%"
# Process finished with exit code 0
huawei_ecs_server.py:
import json
import flask
from flask import request, jsonify, Response
import requests
# careful not to mix flask's request with requests!
import threading
import yaml
# create flask
PORT = 8888
app = flask.Flask(__name__)
@app.route('/ecs/server', methods=['POST'])
def create_server():
    args = request.args
    print(request.method)
    content = request.get_data(as_text=True)
    print(content)
    return Response(yaml.dump(content), mimetype='application/yaml')
def show_server(id):
    credentials = BasicCredentials(ak, sk)
    client = EcsClient.new_builder().with_credentials(credentials)\
        .with_region(EcsRegion.value_of("cn-north-4")).build()
    try:
        request = ShowServerRequest()
        request.server_id = id
        response = client.show_server(request)
        return response
    except exceptions.ClientRequestException as e:
        print(e.status_code)
        print(e.request_id)
        print(e.error_code)
        print(e.error_msg)
def get_ipaddress(id):
    credentials = BasicCredentials(ak, sk) \
    client = EcsClient.new_builder() \
        .with_credentials(credentials) \
        .with_region(EcsRegion.value_of("cn-north-4")) \
        .build()
    try:
        request = ListServerInterfacesRequest()
        response = client.list_server_interfaces(request)
        print(response)
        print(e.request_id)
        print(e.error_code)
        print(e.error_msg)
def get_server_id(name):
        .build()
    try:
        request = ListServersDetailsRequest()
        response = client.list_servers_details(request)
        print(response.servers)
        for server in response.servers:
                return server.id
        print(e.request_id)
        print(e.error_code)
        print(e.error_msg)
# 路由                 方法
@app.route('/ecs/server/<name>', methods=['GET'])
def get_server(name):
    print(name)
    id = get_server_id(name)
    print(id)
    if id:
        # id = "523d290d-42fa-42cd-9cfc-cafde8707ce5"
        data = show_server(id)
        # print(data)
        #json数据直接返回
        return json.loads(str(data))
        #如果yaml返回
        # return Response(yaml.dump(data), mimetype='application/yaml')
    else:
        return "Not Exist!"
@app.route('/ecs/server/<name>', methods=['DELETE'])
def delete_server(name):
    if name:
def delete_server(id_info):
        .build()
    try:
        listServersbody = [
            ServerId(
                id=id_info
        print(response)
        print(e.request_id)
        print(e.error_code)
        print(e.error_msg)
import os_remote_monitor
@app.route('/ecs/server/<name>/os', methods=['GET'])
def get_server_os(name):
    if name:
        if id:
            ip = get_server_ip(id)
            return os_remote_monitor.get_remote_server_os_info(ip,22,"root","Cloud2022")
    else:
        return {}
# coding: utf-8
def get_server_ip(id):
        .build()
    try:
        #list
        ips = list(response.server.addresses.values())[0]
        for ip in ips:
            if ip.os_ext_ip_stype == "floating":
                return ip.addr
        print(e.request_id)
        print(e.error_code)
        print(e.error_msg)
app.run(host='localhost', port='8888' , debug=True, use_reloader=True)
---------------------------------执行结果-----------------------------------------
[{"status": "ACTIVE", "updated": "2022-10-11T07:22:43Z", "auto_terminate_time": "", "hostId": "02165bdab1b973b122477b3a2312960a69ec9c2a8705f0537fbd581b", "OS-EXT-SRV-ATTR:host": "2165bdab1b973b122477b3a2312960a69ec9c2a8705f0537fbd581b", "addresses": {"600b8e93-fbaa-4119-87c2-87f0678dd189": [{"version": "4", "addr": "192.168.0.121", "OS-EXT-IPS:type": "fixed", "OS-EXT-IPS-MAC:mac_addr": "fa:16:3e:39:90:0a", "OS-EXT-IPS:port_id": "094b325b-6e0a-4161-937f-f6bb3f60bee3"}, {"version": "4", "addr": "124.71.205.227", "OS-EXT-IPS:type": "floating", "OS-EXT-IPS-MAC:mac_addr": "fa:16:3e:39:90:0a", "OS-EXT-IPS:port_id": "094b325b-6e0a-4161-937f-f6bb3f60bee3"}]}, "image": {"id": "f025bf3e-3173-4f2a-8f59-34aca5bd853d"}, "OS-EXT-STS:vm_state": "active", "OS-EXT-SRV-ATTR:instance_name": "instance-00da7649", "OS-EXT-SRV-ATTR:hypervisor_hostname": "2165bdab1b973b122477b3a2312960a69ec9c2a8705f0537fbd581b", "flavor": {"id": "c7.large.2", "name": "c7.large.2", "disk": "0", "vcpus": "2", "ram": "4096"}, "id": "d7747398-377b-4292-8529-20f62df56d82", "security_groups": [{"name": "Sys-FullAccess", "id": "b46f7f8c-5e1d-4e85-91c6-1ee43ce7c9a5"}], "OS-EXT-AZ:availability_zone": "cn-east-3a", "user_id": "e93823c6ea3d45429b3173aea1acdc8b", "name": "ecs-e364", "created": "2022-10-11T07:22:04Z", "tenant_id": "1ac80630a2494ca7bb05a7e0ebd82862", "OS-DCF:diskConfig": "MANUAL", "accessIPv4": "", "accessIPv6": "", "progress": 0, "OS-EXT-STS:power_state": 1, "config_drive": "", "metadata": {"image_name": "CentOS 7.9 64bit", "metering.resourcespeccode": "c7.large.2.linux", "charging_mode": "0", "vpc_id": "600b8e93-fbaa-4119-87c2-87f0678dd189", "os_type": "Linux", "metering.resourcetype": "1", "metering.image_id": "f025bf3e-3173-4f2a-8f59-34aca5bd853d", "os_bit": "64", "__support_agent_list": "hss,ces", "cascaded.instance_extrainfo": "pcibridge:1", "metering.imagetype": "gold"}, "OS-SRV-USG:launched_at": "2022-10-11T07:22:20.000000", "os-extended-volumes:volumes_attached": [{"id": "a2dc099c-1bc9-44bf-9496-6027a75f8091", "delete_on_termination": "true", "bootIndex": "0", "device": "/dev/sda"}], "description": "", "host_status": "UP", "OS-EXT-SRV-ATTR:hostname": "ecs-e364", "OS-EXT-SRV-ATTR:reservation_id": "r-flhxwpqc", "OS-EXT-SRV-ATTR:launch_index": 0, "OS-EXT-SRV-ATTR:kernel_id": "", "OS-EXT-SRV-ATTR:ramdisk_id": "", "OS-EXT-SRV-ATTR:root_device_name": "/dev/sda", "OS-EXT-SRV-ATTR:user_data": "IyEvYmluL2Jhc2gKZWNobyAncm9vdDokNiRQQ3pDUUVaNSRJUzFIbE5JbFBJN2VEUGg2WEpNNjJKTHcuclFpOG0uL1EvWUdNQUdKVjhsR2c3VmZ5VWhKTTRpcXpXVXI1MTBUVzROSnZoT2ZnRHlva0suMTdQZTNlLycgfCBjaHBhc3N3ZCAtZTs=", "locked": false, "tags": [], "os:scheduler_hints": {}, "enterprise_project_id": "0", "sys_tags": [{"key": "_sys_enterprise_project_id", "value": "0"}], "cpu_options": {}}]
{"server": {"status": "ACTIVE", "updated": "2022-10-11T07:22:43Z", "auto_terminate_time": "", "hostId": "02165bdab1b973b122477b3a2312960a69ec9c2a8705f0537fbd581b", "OS-EXT-SRV-ATTR:host": "2165bdab1b973b122477b3a2312960a69ec9c2a8705f0537fbd581b", "addresses": {"600b8e93-fbaa-4119-87c2-87f0678dd189": [{"version": "4", "addr": "192.168.0.121", "OS-EXT-IPS:type": "fixed", "OS-EXT-IPS-MAC:mac_addr": "fa:16:3e:39:90:0a", "OS-EXT-IPS:port_id": "094b325b-6e0a-4161-937f-f6bb3f60bee3"}, {"version": "4", "addr": "124.71.205.227", "OS-EXT-IPS:type": "floating", "OS-EXT-IPS-MAC:mac_addr": "fa:16:3e:39:90:0a", "OS-EXT-IPS:port_id": "094b325b-6e0a-4161-937f-f6bb3f60bee3"}]}, "image": {"id": "f025bf3e-3173-4f2a-8f59-34aca5bd853d"}, "OS-EXT-STS:vm_state": "active", "OS-EXT-SRV-ATTR:instance_name": "instance-00da7649", "OS-EXT-SRV-ATTR:hypervisor_hostname": "2165bdab1b973b122477b3a2312960a69ec9c2a8705f0537fbd581b", "flavor": {"id": "c7.large.2", "name": "c7.large.2", "disk": "0", "vcpus": "2", "ram": "4096"}, "id": "d7747398-377b-4292-8529-20f62df56d82", "security_groups": [{"name": "Sys-FullAccess", "id": "b46f7f8c-5e1d-4e85-91c6-1ee43ce7c9a5"}], "OS-EXT-AZ:availability_zone": "cn-east-3a", "user_id": "e93823c6ea3d45429b3173aea1acdc8b", "name": "ecs-e364", "created": "2022-10-11T07:22:04Z", "tenant_id": "1ac80630a2494ca7bb05a7e0ebd82862", "OS-DCF:diskConfig": "MANUAL", "accessIPv4": "", "accessIPv6": "", "progress": 0, "OS-EXT-STS:power_state": 1, "config_drive": "", "metadata": {"image_name": "CentOS 7.9 64bit", "metering.resourcespeccode": "c7.large.2.linux", "charging_mode": "0", "vpc_id": "600b8e93-fbaa-4119-87c2-87f0678dd189", "os_type": "Linux", "metering.resourcetype": "1", "metering.image_id": "f025bf3e-3173-4f2a-8f59-34aca5bd853d", "os_bit": "64", "__support_agent_list": "hss,ces", "cascaded.instance_extrainfo": "pcibridge:1", "metering.imagetype": "gold"}, "OS-SRV-USG:launched_at": "2022-10-11T07:22:20.000000", "os-extended-volumes:volumes_attached": [{"id": "a2dc099c-1bc9-44bf-9496-6027a75f8091", "delete_on_termination": "true", "bootIndex": "0", "device": "/dev/sda"}], "description": "", "host_status": "UP", "OS-EXT-SRV-ATTR:hostname": "ecs-e364", "OS-EXT-SRV-ATTR:reservation_id": "r-flhxwpqc", "OS-EXT-SRV-ATTR:launch_index": 0, "OS-EXT-SRV-ATTR:kernel_id": "", "OS-EXT-SRV-ATTR:ramdisk_id": "", "OS-EXT-SRV-ATTR:root_device_name": "/dev/sda", "OS-EXT-SRV-ATTR:user_data": "IyEvYmluL2Jhc2gKZWNobyAncm9vdDokNiRQQ3pDUUVaNSRJUzFIbE5JbFBJN2VEUGg2WEpNNjJKTHcuclFpOG0uL1EvWUdNQUdKVjhsR2c3VmZ5VWhKTTRpcXpXVXI1MTBUVzROSnZoT2ZnRHlva0suMTdQZTNlLycgfCBjaHBhc3N3ZCAtZTs=", "locked": false, "tags": [], "os:scheduler_hints": {}, "enterprise_project_id": "0", "sys_tags": [{"key": "_sys_enterprise_project_id", "value": "0"}], "cpu_options": {}}}
