Nougat:结合光学神经网络,引领学术PDF文档的智能解析、挖掘学术论文PDF的价值
汀丶 发表于 2023/12/13 10:50:45 2023/12/13
【摘要】 Nougat:结合光学神经网络,引领学术PDF文档的智能解析、挖掘学术论文PDF的价值
这是Nougat的官方存储库,Nougat是一种学术文档PDF解析器,可以理解LaTeX数学和表格。
Project page: https://facebookresearch.github.io/nougat/
1.安装
From pip:
pip install nougat-ocr
From repository:
pip install git+https://github.com/facebookresearch/nougat
Note, on Windows: If you want to utilize a GPU, make sure you first install the correct PyTorch version. Follow instructions here
如果您想从API调用模型或生成数据集,则会有额外的依赖项。
安装通过
pip install "nougat-ocr[api]" or pip install "nougat-ocr[dataset]"
1.2 获取PDF的预测
1.2.1 CLI
To get predictions for a PDF run
$ nougat path/to/file.pdf -o output_directory
目录或文件的路径(其中每行都是PDF的路径)也可以作为位置参数传递
$ nougat path/to/directory -o output_directory
usage: nougat [-h] [--batchsize BATCHSIZE] [--checkpoint CHECKPOINT] [--model MODEL] [--out OUT]
              [--recompute] [--markdown] [--no-skipping] pdf [pdf ...]
positional arguments:
  pdf                   PDF(s) to process.
options:
  -h, --help            show this help message and exit
  --batchsize BATCHSIZE, -b BATCHSIZE
                        Batch size to use.
  --checkpoint CHECKPOINT, -c CHECKPOINT
                        Path to checkpoint directory.
  --model MODEL_TAG, -m MODEL_TAG
                        Model tag to use.
  --out OUT, -o OUT     Output directory.
  --recompute           Recompute already computed PDF, discarding previous predictions.
  --full-precision      Use float32 instead of bfloat16. Can speed up CPU conversion for some setups.
  --no-markdown         Do not add postprocessing step for markdown compatibility.
  --markdown            Add postprocessing step for markdown compatibility (default).
  --no-skipping         Don't apply failure detection heuristic.
  --pages PAGES, -p PAGES
                        Provide page numbers like '1-4,7' for pages 1 through 4 and page 7. Only works for single PDFs.
The default model tag is 0.1.0-small. If you want to use the base model, use 0.1.0-base.
$ nougat path/to/file.pdf -o output_directory -m 0.1.0-base
In the output directory every PDF will be saved as a .mmd file, the lightweight markup language, mostly compatible with Mathpix Markdown (we make use of the LaTeX tables).
Note: On some devices the failure detection heuristic is not working properly. If you experience a lot of [MISSING_PAGE] responses, try to run with the --no-skipping flag. Related: #11, #67
1.2.2 API
With the extra dependencies you use app.py to start an API. Call
$ nougat_api
通过向http://127.0.0.1:8503/ predict/发出POST请求来获得PDF文件的预测。它还接受参数“start”和“stop”,以限制计算选择页码(包括边界)。
响应是一个带有文档标记文本的字符串。
curl -X 'POST' \
  'http://127.0.0.1:8503/predict/' \
  -H 'accept: application/json' \
  -H 'Content-Type: multipart/form-data' \
  -F 'file=@<PDFFILE.pdf>;type=application/pdf'
To use the limit the conversion to pages 1 to 5, use the start/stop parameters in the request URL: http://127.0.0.1:8503/predict/?start=1&stop=5
2.Dataset
2.1 生成数据集
To generate a dataset you need
  1. A directory containing the PDFs
  2. A directory containing the .html files (processed .tex files by LaTeXML) with the same folder structure
  3. A binary file of pdffigures2 and a corresponding environment variable export PDFFIGURES_PATH="/path/to/binary.jar"
Next run
python -m nougat.dataset.split_htmls_to_pages --html path/html/root --pdfs path/pdf/root --out path/paired/output --figure path/pdffigures/outputs
Additional arguments include
Argument Description
--recompute recompute all splits
--markdown MARKDOWN Markdown output dir
--workers WORKERS How many processes to use
--dpi DPI What resolution the pages will be saved at
--timeout TIMEOUT max time per paper in seconds
--tesseract Tesseract OCR prediction for each page
Finally create a jsonl file that contains all the image paths, markdown text and meta information.
python -m nougat.dataset.create_index --dir path/paired/output --out index.jsonl
For each jsonl file you also need to generate a seek map for faster data loading:
python -m nougat.dataset.gen_seek file.jsonl
The resulting directory structure can look as follows:
root/
├── images
├── train.jsonl
├── train.seek.map
├── test.jsonl
├── test.seek.map
├── validation.jsonl
└── validation.seek.map
Note that the .mmd and .json files in the path/paired/output (here images) are no longer required.
This can be useful for pushing to a S3 bucket by halving the amount of files.
2.2Training
To train or fine tune a Nougat model, run
python train.py --config config/train_nougat.yaml
2.3 Evaluation
Run
python test.py --checkpoint path/to/checkpoint --dataset path/to/test.jsonl --save_path path/to/results.json
To get the results for the different text modalities, run
python -m nougat.metrics path/to/results.json
2.4 FAQ
  • Why am I only getting [MISSING_PAGE]?
    Nougat was trained on scientific papers found on arXiv and PMC. Is the document you’re processing similar to that?
    What language is the document in? Nougat works best with English papers, other Latin-based languages might work. Chinese, Russian, Japanese etc. will not work.
    If these requirements are fulfilled it might be because of false positives in the failure detection, when computing on CPU or older GPUs (#11). Try passing the --no-skipping flag for now.
  • Where can I download the model checkpoint from.
    They are uploaded here on GitHub in the release section. You can also download them during the first execution of the program. Choose the preferred preferred model by passing --model 0.1.0-{base,small}
参考链接:
更多优质内容请关注公号:汀丶人工智能;会提供一些相关的资源和优质文章,免费获取阅读。
