java指标统计方案及代码
张俭 发表于 2023/12/11 10:37:01 2023/12/11
【摘要】 java 根据线程统计CPU 设计思路java的ThreadMXBean可以获取每个线程CPU执行的nanoTime,那么可以以这个为基础,除以中间系统经过的纳秒数,就获得了该线程的CPU占比 编码首先,我们定义一个结构体,用来存放一个线程上次统计时的纳秒数和当时的系统纳秒数import lombok.Data;@Datapublic class ThreadMetricsAux { ...
java 根据线程统计CPU
设计思路
编码
import lombok.Data;
@Data
    private long usedNanoTime;
    private long lastNanoTime;
    public ThreadMetricsAux() {
    public ThreadMetricsAux(long usedNanoTime, long lastNanoTime) {
        this.usedNanoTime = usedNanoTime;
        this.lastNanoTime = lastNanoTime;
然后我们在SpringBoot中定义一个定时任务,它将定时地统计计算每个线程的CPU信息,并输出到MeterRegistry,当你调用SpringActuator的接口时,你将能获取到这个指标。
import com.google.common.util.concurrent.AtomicDouble;
import io.micrometer.core.instrument.Meter;
import io.micrometer.core.instrument.MeterRegistry;
import io.micrometer.core.instrument.Tags;
import lombok.extern.slf4j.Slf4j;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.scheduling.annotation.Scheduled;
import org.springframework.stereotype.Service;
import java.lang.management.ManagementFactory;
import java.lang.management.ThreadInfo;
import java.lang.management.ThreadMXBean;
import java.util.HashMap;
@Slf4j
@Service
public class ThreadMetricService {
    @Autowired
    private MeterRegistry meterRegistry;
    private final ThreadMXBean threadBean = ManagementFactory.getThreadMXBean();
    private final HashMap<Long, ThreadMetricsAux> map = new HashMap<>();
    private final HashMap<Meter.Id, AtomicDouble> dynamicGauges = new HashMap<>();
     * one minutes
    @Scheduled(cron = "0 * * * * ?")
    public void schedule() {
        final long[] allThreadIds = threadBean.getAllThreadIds();
        for (long threadId : allThreadIds) {
            final ThreadInfo threadInfo = threadBean.getThreadInfo(threadId);
            if (threadInfo == null) {
                continue;
            final long threadNanoTime = getThreadCPUTime(threadId);
            if (threadNanoTime == 0) {
                // 如果threadNanoTime为0,则识别为异常数据,不处理,并清理历史数据
                map.remove(threadId);
            final long nanoTime = System.nanoTime();
            ThreadMetricsAux oldMetrics = map.get(threadId);
            // 判断是否有历史的metrics信息
            if (oldMetrics != null) {
                // 如果有,则计算CPU信息并上报
                double percent = (double) (threadNanoTime - oldMetrics.getUsedNanoTime()) / (double) (nanoTime - oldMetrics.getLastNanoTime());
                handleDynamicGauge("jvm.threads.cpu", "threadName", threadInfo.getThreadName(), percent);
            map.put(threadId, new ThreadMetricsAux(threadNanoTime, nanoTime));
    // meter Gauge相关代码
    private void handleDynamicGauge(String meterName, String labelKey, String labelValue, double snapshot) {
        Meter.Id id = new Meter.Id(meterName, Tags.of(labelKey, labelValue), null, null, Meter.Type.GAUGE);
        dynamicGauges.compute(id, (key, current) -> {
            if (current == null) {
                AtomicDouble initialValue = new AtomicDouble(snapshot);
                meterRegistry.gauge(key.getName(), key.getTags(), initialValue);
                return initialValue;
                current.set(snapshot);
                return current;
    long getThreadCPUTime(long threadId) {
        long time = threadBean.getThreadCpuTime(threadId);
        /* thread of the specified ID is not alive or does not exist */
        return time == -1 ? 0 : time;
其他配置
依赖配置
pom文件中
        <dependency>
            <artifactId>spring-boot-starter-actuator</artifactId>
        </dependency>
        <dependency>
            <groupId>io.micrometer</groupId>
            <artifactId>micrometer-registry-prometheus</artifactId>
        </dependency>
Prometheus接口配置
application.yaml中
management:
  endpoints:
    web:
      exposure:
        include: health,info,prometheus
效果
通过curl命令调用curl localhost:20001/actuator/prometheus|grep cpu
jvm_threads_cpu{threadName="RMI Scheduler(0)",} 0.0
jvm_threads_cpu{threadName="http-nio-20001-exec-10",} 0.0
jvm_threads_cpu{threadName="Signal Dispatcher",} 0.0
jvm_threads_cpu{threadName="Common-Cleaner",} 3.1664628758074733E-7
jvm_threads_cpu{threadName="http-nio-20001-Poller",} 7.772143763853949E-5
jvm_threads_cpu{threadName="http-nio-20001-Acceptor",} 8.586978352515361E-5
jvm_threads_cpu{threadName="DestroyJavaVM",} 0.0
jvm_threads_cpu{threadName="Monitor Ctrl-Break",} 0.0
jvm_threads_cpu{threadName="AsyncHttpClient-timer-8-1",} 2.524386571545477E-4
jvm_threads_cpu{threadName="Attach Listener",} 0.0
jvm_threads_cpu{threadName="scheduling-1",} 1.2269694160981585E-4
jvm_threads_cpu{threadName="container-0",} 1.999795692406262E-6
jvm_threads_cpu{threadName="http-nio-20001-exec-9",} 0.0
jvm_threads_cpu{threadName="http-nio-20001-exec-7",} 0.0
jvm_threads_cpu{threadName="http-nio-20001-exec-8",} 0.0
jvm_threads_cpu{threadName="http-nio-20001-exec-5",} 0.0
jvm_threads_cpu{threadName="Notification Thread",} 0.0
jvm_threads_cpu{threadName="http-nio-20001-exec-6",} 0.0
jvm_threads_cpu{threadName="http-nio-20001-exec-3",} 0.0
jvm_threads_cpu{threadName="http-nio-20001-exec-4",} 0.0
jvm_threads_cpu{threadName="Reference Handler",} 0.0
jvm_threads_cpu{threadName="http-nio-20001-exec-1",} 0.0012674719289349648
jvm_threads_cpu{threadName="http-nio-20001-exec-2",} 6.542541277148053E-5
jvm_threads_cpu{threadName="RMI TCP Connection(idle)",} 1.3998786340454562E-6
jvm_threads_cpu{threadName="Finalizer",} 0.0
jvm_threads_cpu{threadName="Catalina-utility-2",} 7.920883054498174E-5
jvm_threads_cpu{threadName="RMI TCP Accept-0",} 0.0
jvm_threads_cpu{threadName="Catalina-utility-1",} 6.80101662787773E-5
Java计算磁盘使用率
https://support.huaweicloud.cn/bestpractice-bms/bms_bp_2009.html
华为云文档上的材料值得学习。
翻阅资料
https://www.kernel.org/doc/Documentation/ABI/testing/procfs-diskstats
13 - time spent doing I/Os (ms)
这就意味着如果我想统计一个磁盘在一定周期内的利用率,只需要对这两个数字做差,除以统计的间隔,即就是这段时间内磁盘的利用率
cat /proc/diskstats
 253       0 vda 24046 771 2042174 180187 20689748 21411881 527517532 18028256 0 14610513 18201352
 253       1 vda1 23959 771 2038022 180153 20683957 21411881 527517532 18028066 0 14610312 18201129
样例代码
package com.github.shoothzj.demo.metrics;
import com.github.shoothzj.demo.base.module.ShellResult;
import com.github.shoothzj.demo.base.util.LogUtil;
import com.github.shoothzj.demo.base.util.ShellUtil;
import com.github.shoothzj.demo.base.util.StringUtil;
import java.util.concurrent.Executors;
import java.util.concurrent.ScheduledExecutorService;
import java.util.concurrent.TimeUnit;
 * @author hezhangjian
@Slf4j
public class DiskUtilizationMetrics {
    private static final ScheduledExecutorService scheduledExecutor = Executors.newSingleThreadScheduledExecutor();
    private static long lastTime = -1;
        LogUtil.configureLog();
        String diskName = "vda1";
        scheduledExecutor.scheduleAtFixedRate(() -> metrics(diskName), 0, 10, TimeUnit.SECONDS);
    private static void metrics(String diskName) {
        //假设统计vda磁盘
        String[] cmd = {
                "/bin/bash",
                "-c",
                "cat /proc/diskstats |grep " + diskName + "|awk '{print $13}'"
        ShellResult shellResult = ShellUtil.executeCmd(cmd);
        String timeStr = shellResult.getInputContent().substring(0, shellResult.getInputContent().length() - 1);
        long time = Long.parseLong(timeStr);
        if (lastTime == -1) {
            log.info("first time cal, usage time is [{}]", time);
            double usage = (time - lastTime) / (double) 10_000;
            log.info("usage time is [{}]", usage);
        lastTime = time;
打印CPU使用
private static void printCpuUsage() {
        final com.sun.management.OperatingSystemMXBean platformMXBean = ManagementFactory.getPlatformMXBean(com.sun.management.OperatingSystemMXBean.class);
        double cpuLoad = platformMXBean.getProcessCpuLoad();
        System.out.println(cpuLoad);
打印线程堆栈
private static void printThreadDump() {
        final StringBuilder dump = new StringBuilder();
        final ThreadMXBean threadMXBean = ManagementFactory.getThreadMXBean();
        // 100代表线程堆栈的层级
        final ThreadInfo[] threadInfos = threadMXBean.getThreadInfo(threadMXBean.getAllThreadIds(), 100);
        for (ThreadInfo threadInfo : threadInfos) {
            dump.append('"');
            dump.append(threadInfo.getThreadName());
            dump.append("\" ");
            final Thread.State state = threadInfo.getThreadState();
            dump.append("\n   java.lang.Thread.State: ");
            dump.append(state);
            final StackTraceElement[] stackTraceElements = threadInfo.getStackTrace();
            for (final StackTraceElement stackTraceElement : stackTraceElements) {
                dump.append("\n        at ");
                dump.append(stackTraceElement);
            dump.append("\n\n");
        System.out.println(dump);
打印内存统计信息
引入依赖
 <dependency>
            <groupId>com.jerolba</groupId>
            <artifactId>jmnemohistosyne</artifactId>
            <version>0.2.3</version>
        </dependency>
 private static void printClassHisto() {
        Histogramer histogramer = new Histogramer();
        MemoryHistogram histogram = histogramer.createHistogram();
        HistogramEntry arrayList = histogram.get("java.util.ArrayList");
        System.out.println(arrayList.getInstances());
        System.out.println(arrayList.getSize());
        for (HistogramEntry entry : histogram) {
            System.out.println(entry);
打印死锁
javadoc中指出,这是一个开销较大的操作
 private static void printDeadLock() {
        final long[] deadlockedThreads = threadMXBean.findDeadlockedThreads();
        for (long deadlockedThread : deadlockedThreads) {
            final ThreadInfo threadInfo = threadMXBean.getThreadInfo(deadlockedThread);
            System.out.println(threadInfo + "deadLocked");
