缓存中间技术Redis系列01
人工智能-张晨光 发表于 2023/12/09 09:59:06 2023/12/09
【摘要】 1. jedis实现分布式锁(1) 分布式锁实现原理是使用命令set key ex/px seconds/millins nx。需要注意的是在多线程环境下这个key必须不能变,证明是同一把锁。(2) 实现步骤1 创建maven工程,添加pom依赖<dependencies> <!-- jackson --> <dependency> <groupId>com.fasterxml.jackso...
1. jedis实现分布式锁
(2) 实现步骤
1 创建maven工程,添加pom依赖
<dependencies>
<!-- jackson -->
<dependency>
<groupId>com.fasterxml.jackson.core</groupId>
<artifactId>jackson-databind</artifactId>
<version>2.13.2.2</version>
</dependency>
<dependency>
<groupId>org.projectlombok</groupId>
<artifactId>lombok</artifactId>
<version>1.18.10</version>
</dependency>
<dependency>
<groupId>redis.clients</groupId>
<artifactId>jedis</artifactId>
<version>2.9.3</version>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.12</version>
<scope>test</scope>
</dependency>
</dependencies>
2 编写配置文件redis.properties,使用连接池实现
redis.host=127.0.0.1
redis.port=6379
#最大连接数
redis.maxTotal=30
#最大空闲连接数
redis.maxIdle=10
#获取连接时等待的最大时间:毫秒
redis.maxWaitMillis=5000
3 编写连接池工具类RedisPoolUtil
* redis连接池工具类
public class RedisPoolUtil {
private static JedisPool jedisPool;
static {
try {
InputStream inputStream = RedisPoolUtil.class
.getClassLoader().getResourceAsStream("redis.properties");
Properties properties = new Properties();
properties.load(inputStream);
JedisPoolConfig config = new JedisPoolConfig();
config.setMaxIdle(Integer.valueOf(properties.getProperty("redis.maxIdle")));
config.setMaxWaitMillis(Long.valueOf(properties.getProperty("redis.maxWaitMillis")));
config.setMaxTotal(Integer.valueOf(properties.getProperty("redis.maxTotal")));
String host = properties.getProperty("redis.host");
int port = Integer.valueOf(properties.getProperty("redis.port"));
jedisPool = new JedisPool(config,host,port);
} catch (IOException e) {
e.printStackTrace();
* 获取jedis
* @return
public static Jedis getJedis(){
return jedisPool.getResource();
public static void close(Jedis jedis){
if (jedis!=null)
jedis.close();
4 编写分布式锁工具类RedisLockUtil ,注意要使用lua脚本实现,lua脚本能保证释放的是自己线程的锁,避免因为在释放锁之前分布式锁已经失效,从而导致释放了别的线程的锁。
* redis工具类
public class RedisLockUtil {
//分布式锁相关
private static final Long UNLOCK_SUCCESS = 1L;
private static final String LOCK_SUCCESS = "OK";
* 尝试获取分布式锁
* @param key
* @param val
* @param timeOut 锁的有效时间,单位毫秒
* @return true:获取到了锁 false:没有获取锁
public static boolean lock(Jedis jedis,String key,String val,long timeOut){
String result = jedis.set(key, val, "NX", "PX", timeOut);
if (LOCK_SUCCESS.equals(result))
return true;
else
return false;
* 释放锁
* @param key
* @param val
* @return
public static boolean unlock(Jedis jedis,String key,String val){
* lua这个字符串是个lua脚本,代表的意思是如果根据key拿到的value
* 跟传入的value相同就执行del,否则就返回0,保证安全性;
String lua =
"if redis.call('get', KEYS[1]) == ARGV[1] then return redis.call('del', KEYS[1]) else return 0 end";
* 执行解锁的lua脚本:可以保证释放调的是本线程的锁
* 参数一:lua脚本
* 参数二:keys集合
* 参数三:value集合,保证操作的原子性
Object eval =
jedis.eval(lua, Collections.singletonList(key), Collections.singletonList(val));
if (UNLOCK_SUCCESS.equals(eval)){
return true;
else
return false;
5 自定义线程MyRun ,演示分布式环境下抢票
* 使用分布式锁保证抢票的线程安全
public class MyRun implements Runnable {
public int sockets = 10;
private String key = "tickes";//分布式锁要求key必须一样,证明是同一把锁
@Override
public void run() {
String val = UUID.randomUUID().toString();
ticket(key,val);
* 分布式锁实现抢票安全
public void ticket(String key,String val){
String name = Thread.currentThread().getName();
Jedis jedis = RedisPoolUtil.getJedis();
if (RedisLockUtil.lock(jedis,key,val,1000)){
if (sockets==0){
System.out.println(name+"对不起,票卖完了!");
return;
sockets--;//抢票
System.out.println(name+"--------------------->>>正在抢购第"+(10-sockets)+"张票");
//释放锁
if (RedisLockUtil.unlock(jedis,key,val)){
System.out.println(name+"释放锁成功!");
6 多线程测试
public class MyTest {
public static void main(String[] args) throws InterruptedException {
MyRun myRun = new MyRun();
for (int i = 1; i < 30; i++) {
Thread.sleep(100);//演示真是环境程序执行时间
Thread thread = new Thread(myRun, "第" + i + "个用户");
thread.start();
2. spring整合redis,基于RedisTemplate
(1) pom依赖
<dependencies>
<!-- jackson -->
<dependency>
</dependency>
<!-- 整合redis -->
<dependency>
</dependency>
<dependency>
<groupId>org.springframework.data</groupId>
<artifactId>spring-data-redis</artifactId>
<version>2.1.2.RELEASE</version>
</dependency>
<dependency>
</dependency>
<dependency>
<groupId>commons-logging</groupId>
<artifactId>commons-logging</artifactId>
<version>1.2</version>
</dependency>
<dependency>
</dependency>
<dependency>
<groupId>org.springframework</groupId>
<artifactId>spring-test</artifactId>
<version>5.1.5.RELEASE</version>
<scope>test</scope>
</dependency>
</dependencies>
(2) 创建连接池参数文件redis.properties
redis.port=6379
#最大连接数
redis.maxTotal=30
#最大空闲连接数
redis.maxIdle=10
#获取连接时等待的最大时间:毫秒
(3) 创建实体类User
@Data
@NoArgsConstructor
@AllArgsConstructor
public class User implements Serializable {
private int id;
private String name;
private int age;
(4) 创建spring整合redis配置文件applicationContext-redis.xml
<context:component-scan base-package="cn.yunhe" />
<context:property-placeholder location="classpath:redis.properties" />
<bean id="jedisPoolConfig" class="redis.clients.jedis.JedisPoolConfig">
<property name="maxWaitMillis" value="${redis.maxWaitMillis}" />
<property name="maxTotal" value="${redis.maxTotal}" />
<property name="maxIdle" value="${redis.maxIdle}" />
</bean>
<bean id="connectionFactory" class="org.springframework.data.redis.connection.jedis.JedisConnectionFactory">
<property name="poolConfig" ref="jedisPoolConfig"/>
<property name="hostName" value="${redis.host}"/>
<property name="port" value="${redis.port}" />
</bean>
<bean id="redisTemplate" class="org.springframework.data.redis.core.RedisTemplate">
<property name="connectionFactory" ref="connectionFactory" />
<property name="keySerializer">
<bean class="org.springframework.data.redis.serializer.StringRedisSerializer" />
</property>
<property name="valueSerializer">
<bean class="org.springframework.data.redis.serializer.GenericJackson2JsonRedisSerializer" />
</property>
<property name="hashKeySerializer">
</property>
<property name="hashValueSerializer">
</property>
<!--关闭事务:如果网络闪断,redisTemplate没有释放连接,网络恢复后是无法重新连接的,关闭事务后可自行释放。 -->
<property name="enableTransactionSupport" value="false"></property>
</bean>
(5) 创建工具类分布式锁RedisLockUtil
@Component
@Autowired
private RedisTemplate redisTemplate;
* 分布式锁---上锁
* @param key
* @param val
* @param time 有效时间,单位毫秒
public boolean lock(String key,String val,long time){
return redisTemplate.opsForValue()
.setIfAbsent(key, val, time, TimeUnit.MILLISECONDS);
* 使用lua脚本解锁
* @param key
* @param val
* @return
public boolean unLock(String key,String val){
String lua =
DefaultRedisScript<Long> redisScript =
new DefaultRedisScript<>(lua, Long.class);
Object result =
redisTemplate.execute(redisScript,Collections.singletonList(key), val);
if (UNLOCK_SUCCESS.equals(result))
return true;
else
return false;
(6) 自定义线程MyRun,模拟抢票
private static RedisLockUtil redisLockUtil;
static {
ApplicationContext applicationContext =
new ClassPathXmlApplicationContext("spring.xml");
redisLockUtil =
applicationContext.getBean("redisLockUtil",RedisLockUtil.class);
private int tickets = 10;
private String key = "tickets"; //同一把锁
@Override
public void run() {
ticket();
public void ticket(){
if (redisLockUtil.lock(key,val,1000)){
if (tickets<=0){
System.out.println(name+"对不起,票已售完!");
return;
tickets--;
System.out.println(name+"抢到了第"+(10-tickets)+"张票!");
if (redisLockUtil.unLock(key,val)){
}else{
System.out.println(name+"正在占用锁");
(7) 一般测试
@RunWith(SpringRunner.class)
@ContextConfiguration(locations = "classpath:spring.xml")
@Autowired
//操作字符串
@Test
public void t1(){
redisTemplate.opsForValue().set("name","张三");
System.out.println( redisTemplate.opsForValue().get("name"));
//操作对象
@Test
public void t2(){
User user = new User(1, "张三", 20);
redisTemplate.opsForValue().set("user:1001",user);
User myUser = (User) redisTemplate.opsForValue().get("user:1001");
System.out.println(myUser);
//操作list列表
@Test
public void t3(){
redisTemplate.opsForList().leftPush("userlist",user);
User user2 = new User(2, "李四", 21);
User user3 = new User(3, "小芳", 18);
User user4 = new User(4, "小红", 19);
redisTemplate.opsForList().leftPushAll("userlist",user2,user3,user4);
List<User> userlist = redisTemplate.opsForList().range("userlist",0,-1);
System.out.println(userlist);
//string类型操作list集合
@Test
public void t4(){
List<User> list = new ArrayList<>();
list.add(user);
list.add(user2);
list.add(user3);
list.add(user4);
redisTemplate.opsForValue().set("userList",list);
List<User> userList = (List<User>) redisTemplate.opsForValue().get("userList");
System.out.println(userList);
(8) 分布式锁测试
public class MyTest2 {
for (int i = 1; i <= 30; i++) {
Thread.sleep(300);
thread.start();
3. SpringBoot整合RedisTemplate
(1) 依赖
<dependencies>
<dependency>
<artifactId>spring-boot-starter-web</artifactId>
</dependency>
<dependency>
<artifactId>spring-boot-starter-data-redis</artifactId>
</dependency>
<dependency>
<artifactId>spring-boot-starter-test</artifactId>
</dependency>
</dependencies>
(2) application.yml
spring:
redis:
host: 127.0.0.1
port: 6379
timeout: 1000ms
(3) 添加配置类
package cn.yunhe.config;
import com.fasterxml.jackson.annotation.JsonAutoDetect;
import com.fasterxml.jackson.annotation.PropertyAccessor;
import com.fasterxml.jackson.databind.ObjectMapper;
import org.springframework.context.annotation.Bean;
import org.springframework.context.annotation.Configuration;
import org.springframework.data.redis.connection.RedisConnectionFactory;
import org.springframework.data.redis.core.RedisTemplate;
import org.springframework.data.redis.serializer.Jackson2JsonRedisSerializer;
import org.springframework.data.redis.serializer.StringRedisSerializer;
* 整合RedisTemplate
@Configuration
public class RedisConfig {
@Bean
public RedisTemplate redisTemplate(RedisConnectionFactory factory){
RedisTemplate<Object, Object> redisTemplate = new RedisTemplate<>();
redisTemplate.setConnectionFactory(factory);
//使用jackson进行序列化
Jackson2JsonRedisSerializer jsonRedisSerializer =
new Jackson2JsonRedisSerializer(Object.class);
//规定序列化规则
ObjectMapper objectMapper = new ObjectMapper();
* 第一个参数指的是序列化的域,ALL指的是字段、get和set方法、构造方法
* 第二个参数指的是序列化哪些访问修饰符,默认是public,ANY指任何访问修饰符
objectMapper.setVisibility(PropertyAccessor.ALL,JsonAutoDetect.Visibility.ANY);
//指定序列化输入的类型,类必须是非final修饰的类
objectMapper.enableDefaultTyping(ObjectMapper.DefaultTyping.NON_FINAL);
jsonRedisSerializer.setObjectMapper(objectMapper);
//序列化key value
redisTemplate.setKeySerializer(new StringRedisSerializer());
redisTemplate.setValueSerializer(jsonRedisSerializer);
redisTemplate.setHashKeySerializer(new StringRedisSerializer());
redisTemplate.setHashValueSerializer(jsonRedisSerializer);
redisTemplate.afterPropertiesSet();
return redisTemplate;
4. springboot整合redis和spring cache
(1) pom依赖
<dependency>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-cache</artifactId>
        </dependency>
(2) 配置文件
server:
port: 8100
spring:
redis:
host: 127.0.0.1
port: 6349
timeout: 5000ms #连接超时时间
lettuce:
pool:
max-active: -1 #最大连接数,使用-1表示没有限制
max-idle: 10 #最大空闲连接数
max-wait: 5000ms #连接池最大阻塞等待时间
min-idle: 5 #连接池最小空闲连接数
(3) 添加配置类
自定义key的话也可以使用cache注解规定。
* spring cache整合redis缓存配置类
@Configuration
@EnableCaching
* 自定义生成缓存key的规则,可以不设置
/*@Bean
public KeyGenerator keyGenerator(){
return new KeyGenerator(){
@Override
public Object generate(Object target, Method method, Object... params) {
StringBuilder builder = new StringBuilder();
builder.append(target.getClass().getName());//拼接目标对象的类名
builder.append(method.getName());//拼接方法的名称
for (Object param : params) {
builder.append(param.toString());//拼接方法中的参数
return builder.toString();
@Bean
//使用jackson进行序列化
//规定序列化规则
//序列化key value
* 设置CacheManager缓存管理器
@Bean
public CacheManager cacheManager(RedisConnectionFactory factory) {
RedisSerializer<String> redisSerializer = new StringRedisSerializer();
Jackson2JsonRedisSerializer jackson2JsonRedisSerializer =
//解决查询缓存转换异常的问题
ObjectMapper om = new ObjectMapper();
om.setVisibility(PropertyAccessor.ALL, JsonAutoDetect.Visibility.ANY);
om.enableDefaultTyping(ObjectMapper.DefaultTyping.NON_FINAL);
jackson2JsonRedisSerializer.setObjectMapper(om);
// 配置序列化(解决乱码的问题),过期时间600秒,如果不设置过期时间则永不过期
RedisCacheConfiguration config = RedisCacheConfiguration.defaultCacheConfig()
.entryTtl(Duration.ofSeconds(600))
.serializeKeysWith(RedisSerializationContext.SerializationPair.fromSerializer(redisSerializer))
.serializeValuesWith(RedisSerializationContext.SerializationPair.fromSerializer(jackson2JsonRedisSerializer))
.disableCachingNullValues();
RedisCacheManager cacheManager = RedisCacheManager.builder(factory)
.cacheDefaults(config)
.build();
return cacheManager;
(4) Spring Cache注解介绍
参考:
详解Spring缓存注解的使用.mhtml
@Cacheable
@Cacheable 的作用 主要针对方法配置,能够根据方法的请求参数对其结果进行缓存
@Cacheable 作用和配置方法
参数
解释
example
value
缓存的名称,在 spring 配置文件中定义,必须指定至少一个
例如:
@Cacheable(value=”mycache”)
@Cacheable(value={”cache1”,”cache2”}
key
缓存的 key,可以为空,如果指定要按照 SpEL 表达式编写,如果不指定,则缺省按照方法的所有参数进行组合
@Cacheable(value=”testcache”,key=”#userName”)
condition
缓存的条件,可以为空,使用 SpEL 编写,返回 true 或者 false,只有为 true 才进行缓存
@Cacheable(value=”testcache”,condition=”#userName.length()>2”)
@CachePut
@CachePut 的作用 主要针对方法配置,能够根据方法的请求参数对其结果进行缓存,和 @Cacheable 不同的是,它每次都会触发真实方法的调用
参数
解释
example
value
@CachePut(value=”my cache”)
key
@CachePut(value=”testcache”,key=”#userName”)
condition
@CachePut(value=”testcache”,condition=”#userName.length()>2”)
@CacheEvict
@CachEvict 的作用 主要针对方法配置,能够根据一定的条件对缓存进行清空
参数
解释
example
value
@CacheEvict(value=”my cache”)
key
@CacheEvict(value=”testcache”,key=”#userName”)
condition
@CacheEvict(value=”testcache”,condition=”#userName.length()>2”)
allEntries
是否清空所有缓存内容,缺省为 false,如果指定为 true,则方法调用后将立即清空所有缓存
@CachEvict(value=”testcache”,allEntries=true)
beforeInvocation
是否在方法执行前就清空,缺省为 false,如果指定为 true,则在方法还没有执行的时候就清空缓存,缺省情况下,如果方法执行抛出异常,则不会清空缓存
@CachEvict(value=”testcache”,beforeInvocation=true)
@Caching
有时候我们可能组合多个Cache注解使用;比如用户成功后,我们要添加id–>user;username—>user;email—>user的缓存;此时就需要@Caching组合多个注解标签了。
1
2
3
4
5
6
@Caching (put = {
@CachePut (value = "user" , key = "#user.id" ),
@CachePut (value = "user" , key = "#user.username" ),
@CachePut (value = "user" , key = "#user.email" )
public User save(User user) {
删除多个也可以使用@Caching和@CacheEvict结合
(5) Spring Cache注解中key属性的使用详解
key中常见属性:
#root:获取缓存对象。
#root.method.name:获取方法名作为key
#root.参数名.属性名:获取方法参数名作为key
#参数名:直接使用参数名作为key
注意:如果要使用自定义的字符串作为key,则要使用单引号:
常见使用方式:
名称
位置
描述
示例
methodName
root对象
当前被调用的方法名
root.methodName
method
root对象
当前被调用的方法
root.method.name
target
root对象
当前被调用的目标对象
root.target
targetClass
root对象
当前被调用的目标对象类
root.targetClass
args
root对象
当前被调用的方法的参数列表
root.args[0]
caches
root对象
当前方法调用使用的缓存列表(如@Cacheable(value={“cache1”, “cache2”})),则有两个cache
root.caches[0].name
argument name
执行上下文
当前被调用的方法的参数,如findById(Long id),我们可以通过#id拿到参数
user.id
result
执行上下文
方法执行后的返回值(仅当方法执行之后的判断有效,如‘unless','cache evict'的beforeInvocation=false)
result
案例:使用类名.方法名的方式作为key
使用参数作为key:
其他案例:
