机器学习---pySpark案例
前进的蜗牛 发表于 2023/12/08 09:31:31 2023/12/08
【摘要】 ​ 1、统计PV,UV1.if __name__ == '__main__':2. conf = SparkConf()3. conf.setMaster("local")4. conf.setAppName("test")5. sc = SparkContext(conf=conf)6.7. #pv8. sc.textFile("./pvuv").map...
 1、统计PV,UV
6.
7.    #pv
8.    sc.textFile("./pvuv").map(lambda line:(line.split("\t")[4],1)).reduceByKey(lambda v1,v2:v1+v2).sortBy(lambda tp:tp[1],ascending=False).foreach(print)
9.
10.    #uv
11.sc.textFile("./pvuv").map(lambda line:line.split("\t")[1]+"_"+line.split("\t")[4]).distinct().map(lambda one:(one.split("_")[1],1)).reduceByKey(lambda v1,v2:v1+v2).sortBy(lambda tp:tp[1],ascending=False).foreach(print)
2、统计除了某个地区外的UV
6.
7.    #uv
8.    sc.textFile("./pvuv").filter(lambda line:line.split("\t")[3]=='beijing').map(lambda line:line.split("\t")[1]+"_"+line.split("\t")[4]).distinct().map(lambda one:(one.split("_")[1],1)).reduceByKey(lambda v1,v2:v1+v2).sortBy(lambda tp:tp[1],ascending=False).foreach(print)
3、统计每个网站最活跃的top2地区
1.def get_top2_local(one):
2.    site = one[0]
3.    local_iterable = one[1]
4.
5.    local_dic = {}
6.    for local in local_iterable:
7.      if local in local_dic:
8.        local_dic[local] += 1
9.      else:
10.        local_dic[local] = 1
11.
12.    sorted_list = sorted(local_dic.items(),key = lambda x:x[1],reverse= True)
13.    return_list = []
14.    if(len(sorted_list)>=2):
15.      for i in range(0,2):
16.        return_list.append(sorted_list[i])
17.      else:
18.        return_list = sorted_list
19.
20.    return return_list
21.
22.
23.if __name__ == '__main__':
24.    conf = SparkConf()
25.    conf.setMaster("local")
26.    conf.setAppName("test")
27.    sc = SparkContext(conf=conf)
28.
29.    #统计每个网站最活跃的top2地区
30.    lines = sc.textFile("./pvuv")
31.    site_local = lines.map(lambda line:(line.split("\t")[4],line.split("\t")[3]))
32.    site_localIterable = site_local.groupByKey()
33.    sorted_result = site_localIterable.map(lambda one:get_top2_local(one))
34.    sorted_result.foreach(print)
35.
4、统计每个网站最热门的操作
1.def get_hot_operator(one):
2.    site = one[0]
3.    operator_iterable = one[1]
4.
5.    operator_dic = {}
6.    for operator in operator_iterable:
7.      if operator in operator_dic:
8.        operator_dic[operator] += 1
9.      else:
10.        operator_dic[operator] = 1
11.
12.    sorted_list = sorted(operator_dic.items(),key = lambda x:x[1],reverse= True)
15.    for i in range(0,1):
17.    else:
19.
21.
22.
28.
29.    #统计每个网站最热门的操作
31.    site_operator = lines.map(lambda line:(line.split("\t")[4],line.split("\t")[5]))
32.    site_operatorIterable = site_operator.groupByKey()
33.    sorted_result = site_operatorIterable.map(lambda one:get_hot_operator(one))
35.
5、统计每个网站下最活跃的top3用户
1.def get_uid_site_count(one):
2.    uid = one[0]
3.    site_iterable = one[1]
4.
5.    site_dic = {}
6.    for site in site_iterable:
7.      if site in site_dic:
8.        site_dic[site] += 1
9.      else:
10.        site_dic[site] = 1
11.
12.    return_list = []
13.    for site,count in site_dic.items():
14.      return_list.append((site,(uid,count)))
15.    return return_list
16.
17.def get_top3_uid(one):
18.    site = one[0]
19.    uid_count_iterable = one[1]
20.    top3_uid = ['','','']
21.    for tp in uid_count_iterable:
22.      uid = tp[0]
23.      count = tp[1]
24.        for i in range(0,len(top3_uid)):
25.          if(top3_uid[i]==''):
26.            top3_uid[i] = tp
27.            break
28.          elif(count > top3_uid[i][1]):
29.            for j in range(2,i,-1):
30.              top3_uid[j] = top3_uid[j-1]
31.              top3_uid[i] = tp
32.              break
33.
34.       return top3_uid
35.
36.
37.
38.if __name__ == '__main__':
39.    conf = SparkConf()
40.    conf.setMaster("local")
41.    conf.setAppName("test")
42.    sc = SparkContext(conf=conf)
43.
44.    #统计每个网站最活跃的top3用户
45.    lines = sc.textFile("./pvuv")
46.    uid_site = lines.map(lambda line:(line.split("\t")[2],line.split("\t")[4]))
47.    uid_siteIterable = uid_site.groupByKey()
48.    uid_site_count = uid_siteIterable.flatMap(lambda one:get_uid_site_count(one))
49.    top3_uid_info = uid_site_count.groupByKey().map(lambda one:get_top3_uid(one))
50.    top3_uid_info.foreach(print)
