Kali ettercap DNS欺骗
Superman can't fly 发表于 2023/11/01 20:56:41 2023/11/01
【摘要】 Kali ettercap DNS欺骗实验环境Kali IP:192.168.195.128 gateway 192.168.195.2Winser2008R2 IP:192.168.195.129 gateway:192.168.195.2网络互通:Winser2008R2 ping kali网络互通:kali ping Winser2008R2实验步骤修改ettercap解析文件 vim...
Kali ettercap DNS欺骗
实验环境
实验步骤
修改ettercap解析文件
 vim /etc/ettercap/etter.dns
apache服务
 启动apache服务
 ┌──(root💀kali)-[/var/www/html]
 └─# systemctl start apache2
 查看apache服务
 └─# systemctl status apache2
 ● apache2.service - The Apache HTTP Server
      Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor p>
      Active: active (running) since Wed 2023-11-01 14:12:51 CST; 36min ago
        Docs: https://httpd.apache.org/docs/2.4/
     Process: 1772 ExecStart=/usr/sbin/apachectl start (code=exited, status=>
    Main PID: 1783 (apache2)
       Tasks: 6 (limit: 4915)
      Memory: 15.1M
      CGroup: /system.slice/apache2.service
              ├─1783 /usr/sbin/apache2 -k start
              ├─1785 /usr/sbin/apache2 -k start
              ├─1786 /usr/sbin/apache2 -k start
              ├─1787 /usr/sbin/apache2 -k start
              ├─1788 /usr/sbin/apache2 -k start
              └─1789 /usr/sbin/apache2 -k start
 11月 01 14:12:51 kali systemd[1]: Starting The Apache HTTP Server...
 11月 01 14:12:51 kali apachectl[1782]: AH00558: apache2: Could not reliably>
 11月 01 14:12:51 kali systemd[1]: Started The Apache HTTP Server.
ettercap
 图形化启动ettercap
 └─# ettercap -G
选择ARP攻击
选择DNS欺骗攻击插件
验证
打开Winser2008R2,在IE中搜索http://www.baidu.com
发现百度的页面变为Apache的默认页面,DNS欺骗成功
