.net core Autofac IOC 容器的简单使用
GoodTimeGGB 发表于 2023/10/31 13:38:26 2023/10/31
【摘要】 书接上回,介绍了.net core 读取配置文件的几种方式,本文学习Autofac的同时再次增加一种读取配置文件的方法。 本文介绍Auofac,一个优秀的.NET IOC框架 源码地址:https://github.com/autofac/Autofac 1、打开NuGet包管理器安装Autofac.Extensions.DependencyInjection包 2、Program.cs ...
请在此添加图片描述
2、Program.cs 启用Autofac
public class Program
    public static void Main(string[] args)
        CreateHostBuilder(args).Build().Run();
    public static IHostBuilder CreateHostBuilder(string[] args) =>
            Host.CreateDefaultBuilder(args)
            .UseServiceProviderFactory(new AutofacServiceProviderFactory()) // 启用Autofac
            .ConfigureWebHostDefaults(webBuilder =>
                webBuilder.UseStartup<Startup>();
3、Startup.cs 新增Autofac并初始化容器
请在此添加图片描述
// 一、autofac 新增
public ILifetimeScope AutofacContainer { get; private set; }
/// <summary>
/// 二、将内容直接注册到AutofacContainerBuilder中
/// </summary>
/// <param name="builder"></param>
public void ConfigureContainer(ContainerBuilder builder)
请在此添加图片描述
// 三、autofac 新增 可选
AutofacContainer = app.ApplicationServices.GetAutofacRoot();
IoCContainer.InitContainer(AutofacContainer);
4、新建Autofac IOC 容器类
/// <summary>
/// Autofac IOC 容器
/// </summary>
public class IoCContainer
	private static ILifetimeScope _container;
	/// <summary>
	/// 初始化容器
	/// </summary>
	/// <param name="services"></param>
	/// <returns></returns>
	public static void InitContainer(ILifetimeScope autofacContainer)
		_container = autofacContainer;
	/// <summary>
	/// 从容器中获取对象 Resolve an instance of the default requested type from the container
	/// </summary>
	/// <typeparam name="T">类型</typeparam>
	public static T Resolve<T>()
		return _container.Resolve<T>();
5、新建读取配置文件工具类
/// <summary>
/// 配置文件读取操作
/// </summary>
public class Configs
	private static readonly IConfiguration configuration;
	static Configs()
		configuration = IoCContainer.Resolve<IConfiguration>();
	/// <summary>
	/// 根据Key获取数配置内容
	/// </summary>
	/// <param name="key"></param>
	public static IConfigurationSection GetSection(string key)
		return configuration.GetSection(key);
	/// <summary>
	/// 根据section和key获取配置内容
	/// </summary>
	/// <param name="section"></param>
	public static string GetConfigurationValue(string section, string key)
		return GetSection(section)?[key];
	/// <summary>
	/// 根据Key获取数据库连接字符串
	/// </summary>
	public static string GetConnectionString(string key)
		return configuration.GetConnectionString(key);
6、新建控制器,使用!读取配置的另一种方式来啦!
[ApiController]
[Route("[controller]")]
public class TestController : ControllerBase
	/// <summary>
	/// 读取内容
	/// </summary>
	[HttpGet, HttpPost]
    public void GetContent()
		var url = Configs.GetSection("Setting:Url").Value; // http://localhost:8080/
		var name = Configs.GetConfigurationValue("Setting", "Name"); // localhost
以上就是.net core AutoFac的简单学习使用 + 读取配置文件的新方式的介绍,做此记录,如有帮助,欢迎点赞关注收藏!
