利用ICSharpCode.SharpZipLib.dll解析 出错:“Wrong Local header signature
GoodTimeGGB 发表于 2023/10/31 10:08:43 2023/10/31
【摘要】 分析原因利用ICSharpCode.SharpZipLib.dll解析APK时,进入APK的AndroidXml获取时出现报错 出错代码using (ICSharpCode.SharpZipLib.Zip.ZipInputStream zip = new ICSharpCode.SharpZipLib.Zip.ZipInputStream(File.OpenRead(path))) { u...
分析原因
出错代码
	using (var filestream = new FileStream(path, FileMode.Open, FileAccess.Read))
		ICSharpCode.SharpZipLib.Zip.ZipFile zipfile = new ICSharpCode.SharpZipLib.Zip.ZipFile(filestream);
		ICSharpCode.SharpZipLib.Zip.ZipEntry item;
        // 出错部分
		while ((item = zip.GetNextEntry()) != null)
			if (item.Name.ToLower() == "androidmanifest.xml")
				manifestData = new byte[50 * 1024];
				using (Stream strm = zipfile.GetInputStream(item))
					strm.Read(manifestData, 0, manifestData.Length);
			if (item.Name.ToLower() == "resources.arsc")
					using (BinaryReader s = new BinaryReader(strm))
						resourcesData = s.ReadBytes((int)s.BaseStream.Length);
解决方法
经过查阅资料,解决方法如下
using (ZipInputStream zip = new ZipInputStream(File.OpenRead(path)))
		System.Text.Encoding.RegisterProvider(System.Text.CodePagesEncodingProvider.Instance);
		ZipFile zipfile = new ZipFile(filestream);
        // 代码更换部分
		foreach (ZipEntry entry in zipfile)
			if (entry != null)
				if (entry.Name.ToLower() == "androidmanifest.xml")
					Stream strm = zipfile.GetInputStream(entry);
				if (entry.Name.ToLower() == "resources.arsc")
						resourcesData = s.ReadBytes((int)entry.Size);
参考链接
Wrong Local header signature: 0xFF8
以上就是利用ICSharpCode.SharpZipLib.dll解析 出错:“Wrong Local header signature: 0xFF8”的介绍,做此记录,如有帮助,欢迎点赞关注收藏!
