C#中的Byte,String,Int,Hex之间的转换函数
GoodTimeGGB 发表于 2023/10/27 17:27:06 2023/10/27
【摘要】 /// <summary> Convert a string of hex digits (ex: E4 CA B2) to a byte array. </summary> /// <param name="s"> The string containing the hex digits (with or without spaces). </param> ...
        /// <returns> Returns an array of bytes. </returns>
        public byte[] HexStringToByteArray(string s)
            s = s.Replace(" ", "");
            byte[] buffer = new byte[s.Length / 2];
            for (int i = 0; i < s.Length; i += 2)
                buffer[i / 2] = (byte)Convert.ToByte(s.Substring(i, 2), 16);
            return buffer;
        /// <summary> Converts an array of bytes into a formatted string of hex digits (ex: E4 CA B2)</summary>
        /// <param name="data"> The array of bytes to be translated into a string of hex digits. </param>
        /// <returns> Returns a well formatted string of hex digits with spacing. </returns>
        public string ByteArrayToHexString(byte[] data)
            StringBuilder sb = new StringBuilder(data.Length * 3);
            foreach (byte b in data)
                sb.Append(Convert.ToString(b, 16).PadLeft(2, '0').PadRight(3, ' '));
            return sb.ToString().ToUpper();
        /// <summary>
        /// 将一条十六进制字符串转换为ASCII
        /// </summary>
        /// <param name="hexstring">一条十六进制字符串</param>
        /// <returns>返回一条ASCII码</returns>
        public static string HexStringToASCII(string hexstring)
            byte[] bt = HexStringToBinary(hexstring);
            string lin = "";
            for (int i = 0; i < bt.Length; i++)
                lin = lin + bt[i] + " ";
            string[] ss = lin.Trim().Split(new char[] { ' ' });
            char[] c = new char[ss.Length];
            int a;
            for (int i = 0; i < c.Length; i++)
                a = Convert.ToInt32(ss[i]);
                c[i] = Convert.ToChar(a);
            string b = new string(c);
            return b;
       /// <summary>
      /// 16进制字符串转换为二进制数组
      /// </summary>
      /// <param name="hexstring">用空格切割字符串</param>
     /// <returns>返回一个二进制字符串</returns>
    public static byte[] HexStringToBinary(string hexstring)
         string[] tmpary = hexstring.Trim().Split(' ');
         byte[] buff = new byte[tmpary.Length];
         for (int i = 0; i < buff.Length; i++)
             buff[i] = Convert.ToByte(tmpary[i], 16);
       return buff;
        /// <summary>
        /// 将byte型转换为字符串
        /// </summary>
        /// <param name="arrInput">byte型数组</param>
        /// <returns>目标字符串</returns>
        private string ByteArrayToString(byte[] arrInput)
            int i;
            StringBuilder sOutput = new StringBuilder(arrInput.Length);
            for (i = 0; i < arrInput.Length; i++)
                sOutput.Append(arrInput[i].ToString("X2"));
            //将此实例的值转换为System.String
            return sOutput.ToString();
        /// <summary>
        /// 对接收到的数据进行解包(将接收到的byte型数组解包为Unicode字符串)
        /// </summary>
        /// <param name="recbytes">byte型数组</param>
        /// <returns>Unicode编码的字符串</returns>
        public string disPackage(byte[] recbytes)
            string temp = "";
            foreach (byte b in recbytes)
                temp += b.ToString("X2") + " ";//ToString("X2") 为C#中的字符串格式控制符
            return temp;
    * int转byte[]
    * 该方法将一个int类型的数据转换为byte[]形式,因为int为32bit,而byte为8bit所以在进行类型转换时,知会获取低8位,
    * 丢弃高24位。通过位移的方式,将32bit的数据转换成4个8bit的数据。注意 &0xff,在这当中,&0xff简单理解为一把剪刀,
    * 将想要获取的8位数据截取出来。
    * @param i 一个int数字
    * @return byte[]
        public static byte[] int2ByteArray(int i)
            byte[] result = new byte[4];
            result[0] = (byte)((i >> 24) & 0xFF);
            result[1] = (byte)((i >> 16) & 0xFF);
            result[2] = (byte)((i >> 8) & 0xFF);
            result[3] = (byte)(i & 0xFF);
            return result;
         * byte[]转int
         * 利用int2ByteArray方法,将一个int转为byte[],但在解析时,需要将数据还原。同样使用移位的方式,将适当的位数进行还原,
         * 0xFF为16进制的数据,所以在其后每加上一位,就相当于二进制加上4位。同时,使用|=号拼接数据,将其还原成最终的int数据
         * @param bytes byte类型数组
         * @return int数字
        public static int bytes2Int(byte[] bytes)
            int num = bytes[3] & 0xFF;
            num |= ((bytes[2] << 8) & 0xFF00);
            num |= ((bytes[1] << 16) & 0xFF0000);
            num |= ((bytes[0] << 24) & 0xFF0000);
            return num;
        public static string Int2String(int str)
            string S = Convert.ToString(str);
            return S;
        public static int String2Int(string str)
            int a;
            int.TryParse(str, out a);
            int a1 = Convert.ToInt32(str);
            return a1;
        /*将int转为低字节在后,高字节在前的byte数组
b[0] = 11111111(0xff) & 01100001
b[1] = 11111111(0xff) & 00000000
b[2] = 11111111(0xff) & 00000000
b[3] = 11111111(0xff) & 00000000
        public byte[] IntToByteArray2(int value)
            byte[] src = new byte[4];
            src[0] = (byte)((value >> 24) & 0xFF);
            src[1] = (byte)((value >> 16) & 0xFF);
            src[2] = (byte)((value >> 8) & 0xFF);
            src[3] = (byte)(value & 0xFF);
            return src;
        //将高字节在前转为int,低字节在后的byte数组(与IntToByteArray2想对应)
        public int ByteArrayToInt2(byte[] bArr)
            if (bArr.Length != 4)
                return -1;
            return (int)((((bArr[0] & 0xff) << 24)
                       | ((bArr[1] & 0xff) << 16)
                       | ((bArr[2] & 0xff) << 8)
   | ((bArr[3] & 0xff) << 0)));
        public static string StringToHexArray(string input)
            char[] values = input.ToCharArray();
            StringBuilder sb = new StringBuilder(input.Length * 3);
            foreach (char letter in values)
                // Get the integral value of the character.
                int value = Convert.ToInt32(letter);
                // Convert the decimal value to a hexadecimal value in string form.
                string hexOutput = String.Format("{0:X}", value);
                sb.Append(Convert.ToString(value, 16).PadLeft(2, '0').PadRight(3, ' '));
以上就是MySQL 版本号排序的介绍,做此记录,如有帮助,欢迎点赞关注收藏!
