手搭手Ajax经典基础案例省市联动
QGS 发表于 2023/10/23 22:26:16 2023/10/23
【摘要】 手搭手Ajax经典基础案例省市联动
环境介绍
技术栈
springboot+mybatis-plus+mysql
软件
版本
mysql
8
IDEA
IntelliJ IDEA 2022.2.1
JDK
1.8
Spring Boot
2.7.13
mybatis-plus
3.5.3.2
pom.xml
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 https://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <parent>
        <artifactId>spring-boot-starter-parent</artifactId>
        <version>2.7.15</version>
        <relativePath/> <!-- lookup parent from repository -->
    </parent>
    <groupId>com.example</groupId>
    <artifactId>ajaxDemo01</artifactId>
    <version>0.0.1-SNAPSHOT</version>
    <name>ajaxDemo01</name>
    <description>ajaxDemo01</description>
    <properties>
        <java.version>1.8</java.version>
    </properties>
    <dependencies>
        <dependency>
            <artifactId>spring-boot-starter-web</artifactId>
        </dependency>
        <dependency>
            <groupId>com.alibaba</groupId>
            <artifactId>fastjson</artifactId>
            <version>2.0.32</version>
        </dependency>
        <dependency>
            <groupId>com.baomidou</groupId>
            <artifactId>mybatis-plus-boot-starter</artifactId>
            <version>3.5.3.2</version>
        </dependency>
        <dependency>
            <groupId>p6spy</groupId>
            <artifactId>p6spy</artifactId>
            <version>3.9.1</version>
        </dependency>
        <dependency>
            <groupId>com.mysql</groupId>
            <artifactId>mysql-connector-j</artifactId>
            <scope>runtime</scope>
        </dependency>
        <dependency>
            <artifactId>druid</artifactId>
            <version>1.2.15</version>
        </dependency>
        <dependency>
            <artifactId>dynamic-datasource-spring-boot-starter</artifactId>
            <version>3.5.0</version>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-test</artifactId>
            <scope>test</scope>
        </dependency>
        <dependency>
            <groupId>org.projectlombok</groupId>
            <artifactId>lombok</artifactId>
            <version>1.18.24</version>
        </dependency>
    </dependencies>
    <build>
        <plugins>
            <plugin>
                <artifactId>spring-boot-maven-plugin</artifactId>
            </plugin>
        </plugins>
    </build>
</project>
application.yml配置文件
spring:
  datasource:
#    username: root
#    password: 111111
#    url: jdbc:p6spy:mysql://xxx.xxx.xxx.136:3306/sys?serverTimezone=Asia/Shanghai&useUnicode=true&characterEncoding=UTF-8
#    driver-class-name: com.p6spy.engine.spy.P6SpyDriver
    dynamic:
      primary: sys #设置默认的数据源或者数据源组,默认值即为master
      strict: false #严格匹配数据源,默认false. true未匹配到指定数据源时抛异常,false使用默认数据源
      datasource:
        sys:
          username: root
          password: 111111
#          driver-class-name: com.mysql.jdbc.Driver
        wms:
          url: jdbc:p6spy:mysql://xxx.xxx.xxx.136:3306/Wms?useUnicode=true&characterEncoding=UTF-8
          username: root
          password: 111111
        sys2:
          username: root
          password: 111111
          url: jdbc:p6spy:mysql://127.0.0.1:3306/sys?serverTimezone=Asia/Shanghai&useUnicode=true&characterEncoding=UTF-8
server:
  port: 8083
mybatis-plus:
  configuration:
    #输出日志
    log-impl: org.apache.ibatis.logging.stdout.StdOutImpl
    #配置映射规则
    map-underscore-to-camel-case: true #表示支持下划线到驼蜂的映射
    #隐藏mybatis图标
  global-config:
    banner: false
    db-config:
      logic-delete-field: status
      logic-not-delete-value: 1
      logic-delete-value: 0
#mybatis:
#  mapper-locations=classpath: com/example/dao/*.xml
数据库表
MybatisX逆向工程
逆向工程:通过数据库表接口,逆向生成java工程结构
实体类、mapper接口、mapper映射文件、Service接口、service实现类
domain(pojo)实体类
@Data
public class TArea implements Serializable {
    private Integer id;
    private String code;
    private String name;
    private String parentcode;
    private static final long serialVersionUID = 1L;
mapper(dao)接口
@Mapper
public interface TAreaMapper extends BaseMapper<TArea> {
    List<TArea> getALLParentcodeIsNull();
    List<TArea> getByParentcode(@Param("parentcode") String parentcode);
mapper.xml映射文件
<!DOCTYPE mapper
        PUBLIC "-//mybatis.org//DTD Mapper 3.0//EN"
        "http://mybatis.org/dtd/mybatis-3-mapper.dtd">
<mapper namespace="com.example.mapper.TAreaMapper">
    <resultMap id="BaseResultMap" type="com.example.domain.TArea">
            <id property="id" column="id" jdbcType="INTEGER"/>
            <result property="code" column="code" jdbcType="VARCHAR"/>
            <result property="name" column="name" jdbcType="VARCHAR"/>
            <result property="parentcode" column="ParentCode" jdbcType="VARCHAR"/>
    </resultMap>
    <sql id="Base_Column_List">
        id,code,name,
        ParentCode
    </sql>
    <select id="getALLParentcodeIsNull" resultType="com.example.domain.TArea">
        select * from t_area where ISNULL(ParentCode)
    </select>
    <select id="getByParentcode" resultType="com.example.domain.TArea">
        select * from t_area where ParentCode =#{parentcode}
    </select>
</mapper>
service接口
public interface TAreaService extends IService<TArea> {
    List<TArea> getALLProvince();
    List<TArea> getByParentcode(String parentcode);
service实现类
@Service
@DS("sys2")
public class TAreaServiceImpl extends ServiceImpl<TAreaMapper, TArea>
    implements TAreaService{
    @Autowired
    private TAreaMapper tAreaMapper;
    @Override
    public List<TArea> getALLProvince() {
        return tAreaMapper.getALLParentcodeIsNull();
    @Override
    public List<TArea> getByParentcode(String parentcode) {
        return tAreaMapper.getByParentcode(parentcode);
test测试类
@Test
void area(){
    //tAreaService.list();
    //tAreaService.getALLProvince();
    tAreaService.getByParentcode("001");
area.html前端页面
<!DOCTYPE html>
<html lang="en" xmlns:th="http://www.thymeleaf.org">
<head>
    <meta charset="UTF-8">
    <title>Title</title>
</head>
<body>
<script type="text/javascript" src="../js/jquery-3.4.1.js"></script>
<select id="province">
    <option value="">选择省份</option>
</select>
<select id="city">
    <option value="">选择城市</option>
</select>
<script type="text/javascript">
    $(document).ready(function () {
        $.ajax({
            type : "get",
            url :"/Area",
            dataType : "json",
            async :"false",//默认true ,异步
            success : function(data){
            for (var i=0; i<data.length;i++){
                let tr ="<option value='"+data[i].code+"'>"+data[i].name+"</option>";
                console.log(tr)
                $("#province").append(tr);
    $("#province").change(function () {
        let  b=this.value;
        console.log(b)
        $.ajax({
            type : "GET",
            url :"/"+b+"/Area2",
            dataType : "json",
              //清空原来的数据
                $("#city").empty();
                    console.log(tr)
                    $("#city").append(tr);
</script>
</body>
</html>
controller控制层
@RequestMapping("/Area")
@ResponseBody
public List<TArea> Areademo() {
    List<TArea> allProvince = tAreaService.getALLProvince();
    return allProvince;
@RequestMapping("/{code}/Area2")
@ResponseBody
public List<TArea> Areademo2(@PathVariable("code") String code) {
    List<TArea> allProvince = tAreaService.getByParentcode(code);
    return allProvince;
以下为原理基础,可略
Ajax即Asynchronous Javascript And XML(异步JavaScript和XML)在 2005年被Jesse James Garrett提出的新术语,用来描述一种使用现有技术集合的‘新’方法,包括: HTML 或 XHTML, CSS, JavaScript, DOM, XML, XSLT, 以及最重要的XMLHttpRequest。使用Ajax技术网页应用能够快速地将增量更新呈现在用户界面上,而不需要重载(刷新)整个页面,这使得程序能够更快地回应用户的操作。
ajax基础
Xmlhttprequest对象是AJAX的核心对象,发送请求以及接收服务器数据的返回。
Xmlhttprequest对象,现代浏览器都是支持的,都内置了该对象。直接用即可。
XmlHttpRequest对象基本方法:
abort():停止发送当前请求
getAllResponseHeader():获取服务器的全部响应头
getResponseHeader("headerLabel”):根据响应头的名字,获取对应的响应头
open(“method”,”URL”,”[,asycFlag[,”userName”[,password]]]”):建立与服务器URL的连接,并设置请求的方法,以及是否使用异步请求。如果远程服务需要用户名、密 码,则 提供对应的信息。
send(content):发送请求。其中content是请求参数
setRequestHeader(“label”,”value”):在发送请求之前,先设置请求头
XMLHttpRequest对象的简单的属性:
onreadystatechange:该属性用于指定XMLHttpRequest对象状态改变时的事件处理函数。
readyState:该属性用于获取XMLHttpRequest对象处理状态
responseText:该属性用于获取服务器响应的XML文档对象
status:该属性是服务器返回的状态码,只有当服务器的响应已经完成时,才会有该状态码
statusText:该属性是服务器返回的状态文本信息,只有当服务器的响应已经完成时,才会有该状态文本信息。
XMLHttpRequest对象的readyState属性对应的状态值
0:请求未初始化
1:服务器连接已建立
2:请求已收到
3:正在处理请求
4:请求已完成且响应已就绪
<!DOCTYPE html>
<head>
</head>
<body>
<div id="mydiv"></div>
<input type="button" value="hello ajax" id="helloAjax">
  window.onload = function (){
    document.getElementById("helloAjax").onclick =function (){
        // console.log("发送ajax请求")
        //1、创建ajax黑心对象XMLHttpRequest
        var xhr =new XMLHttpRequest();
        //2、注册回调函数
        //该函数在XMLHttpRequestState状态值发生改变时被调用
        xhr.onreadystatechange = function () {
            //readyState是Ajax状态码
             * XMLHttpRequest对象的readyState属性对应的状态值
             * 0:请求未初始化
             * 1:服务器连接已建立
             * 2:请求已收到
             * 3:正在处理请求
             * 4:请求已完成且响应已就绪
            console.log(xhr.readyState)
            // if (this.readyState == 4){
            //     console.log("响应结束")
            //status是http协议状态码
            console.log("http响应状态码"+this.status)
            if (this.status==404){
                alert("访问资源不存在")
            if (this.status ==200){
                //将响应信息放到div图层中,渲染
                //innerHTML是javascript的元素属性,和ajax的XMLHttpRequest对象无关,innerText也是javascript的元素属性
                //innerHTML可以设置元素内部的HTML代码。
                document.getElementById("mydiv").innerHTML =this.responseText;
                document.getElementById("mydiv").innerText =this.responseText;
        //3、开启通道
        //open(method,url,async,user,psw)
        //method:请求方式,get,post
        //url:请求路径
        //async:true或false,true表示异步请求,false表示同步请求
        //user用户名
        //psw密码
        xhr.open("GET","/test01",true)
        //4、
        xhr.send()
</script>
</body>
</html>
