python基本统计值的计算
老虎也淘气 发表于 2023/10/19 09:04:15 2023/10/19
【摘要】 from math import sqrtdef getNum(): #获取用户不定长输入 nums = [] iNumStr = input("请输入数字(直接输入回车退出): ") while iNumStr != "": nums.append(eval(iNumStr)) iNumStr = input("请输入数字(直接输入...
    nums = []
    return nums
def mean(numbers):  #计算平均值
    s = 0.0
    for num in numbers:
        s = s + num
    return s / len(numbers)
def dev(numbers, mean): #计算方差
    sdev = 0.0
    for num in numbers:
        sdev = sdev + (num - mean)**2
    return sqrt(sdev / (len(numbers)-1))
def median(numbers):    #计算中位数
    sorted(numbers)
    size = len(numbers)
    if size % 2 == 0:
        med = (numbers[size//2-1] + numbers[size//2])/2
    else:
        med = numbers[size//2]
    return med
n =  getNum() #主体函数
m =  mean(n)
print("平均值:{},方差:{:.2},中位数:{}.".format(m, dev(n,m),median(n)))
运行结果
