你的JoinHint为什么不生效【绽放吧!GaussDB(DWS)云原生数仓】
你是猴子请来的救兵吗 发表于 2023/10/15 10:13:56 2023/10/15
【摘要】 提起数据库的Hint,几乎每个DBA都知道这一强大功能。在GaussDB(DWS)中,Hint可以被用来干预SQL的执行计划,但是在日常工作中,很多开发人员对Hint的缺乏深入了解,经常遇到Hint失效的情况却又束手无策。现在一起来看看,你的JoinHint为什么不生效?
引言
本次针对JoinHint从案例着手深入解析JoinHint不生效的原因,以便读者能“知其所以然”。(本文不讨论Hint的基础语法问题)。
问题案例
内核版本 GaussDB 8.1.3
问题描述 两表关联查询,使用hashjoin hint干预join方式,但hint不生效
问题用例
CREATE TABLE workitem (
    language character varying(10),
    userid character varying(240),
    opiontype character varying(240),
    processinstid character varying(240),
    workitemid character varying(240),
    type_name character varying(240),
    type_code character varying(240),
    createtime timestamp without time zone,
    endtime timestamp without time zone,
    notrejecttotal numeric,
    dws_created_time timestamp without time zone
WITH (orientation=column, compression=low, colversion=2.0, enable_delta=false)
DISTRIBUTE BY HASH(workitemid);
CREATE  TABLE workday (
    mm timestamp with time zone,
    rn numeric
DISTRIBUTE BY HASH(mm);
explain
SELECT /*+ hashjoin(c d) */
    c.userid,c.type_name,c.type_code,count(1) num
FROM workitem c INNER JOIN workday d ON c.createtime = d.mm
    WHERE c.createtime >= '2023-09-01' AND c.endtime < '2023-10-01'
    GROUP BY c.userid,c.type_name,c.type_code;
WARNING:  unused hint: HashJoin(c d)
        QUERY PLAN
  id |                      operation                       | E-rows | E-memory | E-width | E-costs
   1 | ->  Row Adapter                                      |      2 |          |    1502 | 33.12
   2 |    ->  Vector Sonic Hash Aggregate                   |      2 |          |    1502 | 33.12
   3 |       ->  Vector Streaming (type: GATHER)            |      4 |          |    1502 | 33.12
   4 |          ->  Vector Sonic Hash Aggregate             |      4 | 16MB     |    1502 | 27.12
   5 |             ->  Vector Nest Loop (6,8)               |      5 | 1MB      |    1494 | 27.08
   6 |                ->  Vector Streaming(type: BROADCAST) |     14 | 2MB      |       8 | 13.68
   7 |                   ->  CStore Scan on workday d       |      7 | 1MB      |       8 | 13.05
   8 |                ->  Vector Materialize                |      5 | 16MB     |    1502 | 13.09
   9 |                   ->  CStore Scan on workitem c      |      5 | 1MB      |    1502 | 13.08
         RunTime Analyze Information
         "public.workitem" runtime: 25.794ms
         "public.workday" runtime: 18.098ms
                                                               Predicate Information (identified by plan id)
   5 --Vector Nest Loop (6,8)
         Join Filter: (c.createtime = d.mm)
   7 --CStore Scan on workday d
         Filter: (mm >= '2023-09-01 00:00:00'::timestamp without time zone)
         Pushdown Predicate Filter: (mm >= '2023-09-01 00:00:00'::timestamp without time zone)
   9 --CStore Scan on workitem c
         Filter: ((createtime >= '2023-09-01 00:00:00'::timestamp without time zone) AND (endtime < '2023-10-01 00:00:00'::timestamp without time zone))
         Pushdown Predicate Filter: ((createtime >= '2023-09-01 00:00:00'::timestamp without time zone) AND (endtime < '2023-10-01 00:00:00'::timestamp without time zone))
   ====== Query Summary =====
 System available mem: 4710400KB
 Query Max mem: 4710400KB
 Query estimated mem: 5271KB
(33 rows)
问题定位
  1. 尝试关闭nestloop路径,来验证是否可以生成hash计划
    set enable_nestloop = off;
    set enable_mergejoin = off;
    set enable_hashjoin = on;
        QUERY PLAN
(28 rows)
  1. 关闭nestloop路径后,仍然生成nestloop计划,且E-costs代价中未添加惩罚代价,说明该场景语句本身不支持hashjoin。
  2. 检查关联表达式 (c.createtime = d.mm),确认是否支持hashjoin。
  • 关联表达式为字段关联,不存在函数嵌套
  • 关联表达式两边数据类型为 timestamp without time zone 和 timestamp with time zone,通过系统表pg_operator确认是否支持hashjoin。
postgres=# select * from pg_operator where oprname = '=' and oprleft = 'timestamp'::regtype and oprright = 'timestamptz'::regtype;
-[ RECORD 1 ]+-------------------------
oprname      | =
oprnamespace | 11
oprowner     | 10
oprkind      | b
oprcanmerge  | t
oprcanhash   | f
oprleft      | 1114
oprright     | 1184
oprresult    | 16
oprcom       | 2542
oprnegate    | 2539
oprcode      | timestamp_eq_timestamptz
oprrest      | eqsel
oprjoin      | eqjoinsel
  • 通过结果确认oprcanhash为false,代表该操作符不支持hash连接;原因是,左边数据不带时区,右边数据带,在比较时要先处理时区问题,不能直接拿存储值进行判断。
改善办法
  1. 通过系统表确认timestamp类型的等值关联和timestamptz的等值关联均支持hash连接。
postgres=# select * from pg_operator where oprname = '=' and oprleft = oprright and oprleft in('timestamp'::regtype,'timestamptz'::regtype);
oprname      | =
oprnamespace | 11
oprowner     | 10
oprkind      | b
oprcanmerge  | t
oprcanhash   | t
oprleft      | 1184
oprright     | 1184
oprresult    | 16
oprcom       | 1320
oprnegate    | 1321
oprcode      | timestamptz_eq
oprrest      | eqsel
oprjoin      | eqjoinsel
-[ RECORD 2 ]+---------------
oprname      | =
oprnamespace | 11
oprowner     | 10
oprkind      | b
oprcanmerge  | t
oprcanhash   | t
oprleft      | 1114
oprright     | 1114
oprresult    | 16
oprcom       | 2060
oprnegate    | 2061
oprrest      | eqsel
oprjoin      | eqjoinsel
  1. 在关联条件上添加类型转换,保证两边类型一致,即 (c.createtime::timestamptz = d.mm) 或 (c.createtime = d.mm::timestamp)。
postgres=# explain
postgres-# SELECT /*+ hashjoin(c d) */
postgres-#     c.userid,c.type_name,c.type_code,count(1) num
postgres-# FROM workitem c INNER JOIN workday d ON c.createtime::timestamptz = d.mm
postgres-#     WHERE c.createtime >= '2023-09-01' AND c.endtime < '2023-10-01'
postgres-#     GROUP BY c.userid,c.type_name,c.type_code;
        QUERY PLAN
   1 | ->  Row Adapter                                      |      2 |          |    1502 | 34.29
   2 |    ->  Vector Sonic Hash Aggregate                   |      2 |          |    1502 | 34.29
   3 |       ->  Vector Streaming (type: GATHER)            |      4 |          |    1502 | 34.29
   4 |          ->  Vector Sonic Hash Aggregate             |      4 | 16MB     |    1502 | 28.29
   5 |             ->  Vector Sonic Hash Join (6,8)         |      5 | 16MB     |    1494 | 28.25
   6 |                ->  Vector Streaming(type: BROADCAST) |     40 | 2MB      |       8 | 15.06
   7 |                   ->  CStore Scan on workday d       |     20 | 1MB      |       8 | 13.01
   8 |                ->  CStore Scan on workitem c         |      5 | 1MB      |    1502 | 13.08
   5 --Vector Sonic Hash Join (6,8)
         Hash Cond: (d.mm = (c.createtime)::timestamp with time zone)
   8 --CStore Scan on workitem c
 Query estimated mem: 5530KB
(24 rows)
postgres=# explain
FROM workitem c INNER JOIN workday d ON c.createtime = d.mm::timestamp
        QUERY PLAN
   1 | ->  Row Adapter                                      |      2 |          |    1502 | 32.91
   2 |    ->  Vector Sonic Hash Aggregate                   |      2 |          |    1502 | 32.91
   3 |       ->  Vector Streaming (type: GATHER)            |      4 |          |    1502 | 32.91
   4 |          ->  Vector Sonic Hash Aggregate             |      4 | 16MB     |    1502 | 26.91
   5 |             ->  Vector Sonic Hash Join (6,8)         |      5 | 16MB     |    1494 | 26.87
   6 |                ->  Vector Streaming(type: BROADCAST) |     14 | 2MB      |       8 | 13.71
   7 |                   ->  CStore Scan on workday d       |      7 | 1MB      |       8 | 13.08
         Hash Cond: ((d.mm)::timestamp without time zone = c.createtime)
         Filter: ((mm)::timestamp without time zone >= '2023-09-01 00:00:00'::timestamp without time zone)
(26 rows)
知识小结
实际使用过程中导致hint生效的原因很多,这里总结排查hashjoin hint步骤以供参考:
  1. 检查hint中的表名是否正确、是否存在重名、是否在当前层可见,此类场景通常在explain中会给出提示,自行排查即可。
  2. 判断关联hint中的表名是否被提升导致表名不存在,此类场景通常在explain中会给出提示
postgres=# explain
FROM workitem c INNER JOIN (select * from workday where mm >= '2023-09-01') d ON c.createtime = d.mm::timestamp
WARNING:  Error hint: HashJoin(c d), relation name "d" is not found.
        QUERY PLAN
   1 | ->  Row Adapter                                      |      2 |          |    1502 | 32.78
   2 |    ->  Vector Sonic Hash Aggregate                   |      2 |          |    1502 | 32.78
   3 |       ->  Vector Streaming (type: GATHER)            |      4 |          |    1502 | 32.78
   4 |          ->  Vector Sonic Hash Aggregate             |      4 | 16MB     |    1502 | 26.78
   5 |             ->  Vector Sonic Hash Join (6,8)         |      5 | 16MB     |    1494 | 26.74
   6 |                ->  Vector Streaming(type: BROADCAST) |     10 | 2MB      |       8 | 13.58
   7 |                   ->  CStore Scan on workday         |      5 | 1MB      |       8 | 13.11
         Hash Cond: ((workday.mm)::timestamp without time zone = c.createtime)
         Filter: ((mm >= '2023-09-01 00:00:00+08'::timestamp with time zone) AND ((mm)::timestamp without time zone >= '2023-09-01 00:00:00'::timestamp without time zone))
         Pushdown Predicate Filter: (mm >= '2023-09-01 00:00:00+08'::timestamp with time zone)
(27 rows)
针对此种情况,8.2.0及以上版本可以通过添加no merge hint来禁用子查询提升从而规避hint失效问题。
  1. 通过join路径参数验证目标路径是否可生效。
--如通过关闭其他路径参数来验证某一路径是否可达
  1. 检查关联条件中是否存在volatile函数。
postgres=# create or replace function gettimediff(timestamp) returns interval language sql as 'select $1-timeofday()::timestamp' volatile;
CREATE FUNCTION
postgres=# explain
FROM workitem c INNER JOIN workday d ON gettimediff(c.createtime) = gettimediff(d.mm::timestamp)
        QUERY PLAN
  id |                          operation                          | E-rows | E-width | E-costs
   1 | ->  HashAggregate                                           |      5 |    1502 | 3.10
   2 |    ->  Nested Loop (3,4)                                    |      5 |    1494 | 3.00
   3 |       ->  Data Node Scan on workitem "_REMOTE_TABLE_QUERY_" |      5 |    1502 | 0.00
   4 |       ->  Data Node Scan on workday "_REMOTE_TABLE_QUERY_"  |     20 |       8 | 0.00
   2 --Nested Loop (3,4)
         Join Filter: ((c.createtime - (timeofday())::timestamp without time zone) = ((d.mm)::timestamp without time zone - (timeofday())::timestamp without time zone))
(11 rows)
  1. 检查关联条件中两表字段是否在等号两侧,若不是则进行调整。
postgres=# explain
FROM workitem c INNER JOIN workday d ON ifnull(c.createtime,d.mm) = now()
        QUERY PLAN
   1 | ->  Row Adapter                                      |      1 |          |    1502 | 35.37
   2 |    ->  Vector Sonic Hash Aggregate                   |      1 |          |    1502 | 35.37
   3 |       ->  Vector Streaming (type: GATHER)            |      2 |          |    1502 | 35.37
   4 |          ->  Vector Sonic Hash Aggregate             |      2 | 16MB     |    1502 | 29.37
   5 |             ->  Vector Nest Loop (6,8)               |      2 | 1MB      |    1494 | 29.35
         Join Filter: (COALESCE((c.createtime)::timestamp with time zone, d.mm) = now())
 Query estimated mem: 5275KB
(25 rows)
  1. 检查关联条件是否为等值关联,若不是则进行调整。
postgres=# explain
FROM workitem c INNER JOIN workday d ON c.createtime::timestamptz > d.mm
        QUERY PLAN
   1 | ->  Row Adapter                                      |      5 |          |    1502 | 35.41
   2 |    ->  Vector Sonic Hash Aggregate                   |      5 |          |    1502 | 35.41
   3 |       ->  Vector Streaming (type: GATHER)            |     10 |          |    1502 | 35.41
   4 |          ->  Vector Sonic Hash Aggregate             |     10 | 16MB     |    1502 | 29.41
   5 |             ->  Vector Nest Loop (6,8)               |     33 | 1MB      |    1494 | 29.20
         Join Filter: ((c.createtime)::timestamp with time zone > d.mm)
 Query estimated mem: 5281KB
(25 rows)
  1. 检查关联关系两侧的数据类型,并通过pg_operator.oprcanhash确认是否支持hash连接,若不支持则需改写为支持的操作符。
oprname      | =
oprnamespace | 11
oprowner     | 10
oprkind      | b
oprcanmerge  | t
oprcanhash   | f
oprleft      | 1114
oprright     | 1184
oprresult    | 16
oprcom       | 2542
oprnegate    | 2539
oprrest      | eqsel
oprjoin      | eqjoinsel
  1. 如果是指定join顺序的hint,如leading(c e),会存在逻辑本身冲突导致hint失败的情况。
postgres=# explain SELECT /*+ leading(c e) */
FROM workitem c LEFT JOIN workday d ON c.createtime = d.mm LEFT JOIN workday e ON d.mm = e.mm
WARNING:  unused hint: Leading(c e)
        QUERY PLAN
   1 | ->  Row Adapter                                         |      2 |          |    1502 | 47.97
   2 |    ->  Vector Sonic Hash Aggregate                      |      2 |          |    1502 | 47.97
   3 |       ->  Vector Streaming (type: GATHER)               |      4 |          |    1502 | 47.97
   4 |          ->  Vector Sonic Hash Aggregate                |      4 | 16MB     |    1502 | 41.97
   5 |             ->  Vector Nest Loop Left Join (6, 7)       |      5 | 1MB      |    1494 | 41.93
   6 |                ->  CStore Scan on workitem c            |      5 | 1MB      |    1502 | 13.08
   7 |                ->  Vector Materialize                   |     40 | 16MB     |       8 | 28.00
   8 |                   ->  Vector Streaming(type: BROADCAST) |     40 | 2MB      |       8 | 27.90
   9 |                      ->  Vector Hash Left Join (10, 11) |     20 | 16MB     |       8 | 26.32
  10 |                         ->  CStore Scan on workday d    |     20 | 1MB      |       8 | 13.01
  11 |                         ->  CStore Scan on workday e    |     20 | 1MB      |       8 | 13.01
   5 --Vector Nest Loop Left Join (6, 7)
   6 --CStore Scan on workitem c
   9 --Vector Hash Left Join (10, 11)
         Hash Cond: (d.mm = e.mm)
 Query estimated mem: 5274KB
(29 rows)
  1. 检查查询语句中,from表数量是否超出from_collapse_limit,以及join表数量是否超出join_collapse_limit。超出时存在一定概率使hint无法生效。
    比默认值小的数值将降低规划时间,但是可能生成差的执行计划。
postgres=# show from_collapse_limit;
 from_collapse_limit
 8
(1 row)
postgres=# show join_collapse_limit;
 join_collapse_limit
 8
(1 row)
  1. 检查查询语句中,from表数量是否超出geqo_threshold(geqo开启的前提下),如果超出会使用基因查询优化来生成计划,存在很大概率使hint无法生效。
    对于简单的查询,通常用详尽搜索方法,当涉及多个表的查询的时候,用GEQO可以更好的管理查询。
postgres=# show geqo_threshold;
 geqo_threshold
 12
(1 row)
我正在参加【有奖征文 第27期】绽放吧!GaussDB(DWS)云原生数仓!
