手搭手Mybatis-Plus多数据源迁移至TDSQL
QGS 发表于 2023/10/13 22:20:08 2023/10/13
【摘要】 手搭手Mybatis-Plus多数据源Mysql,Oracle、DM迁移至TDSQL
环境介绍
技术栈
springboot+mybatis-plus+druid+baomidou+mysql+oracle+dm
软件
版本
mysql
8
IDEA
IntelliJ IDEA 2022.2.1
JDK
1.8
Spring Boot
2.7.13
mybatis
2.3.1
Navicat测试连接TDSQL
开启访问外网
pom.xml所需依赖
<dependencies>
    <dependency>
        <artifactId>spring-boot-starter-web</artifactId>
    </dependency>
    <dependency>
        <groupId>com.baomidou</groupId>
        <artifactId>mybatis-plus-boot-starter</artifactId>
        <version>3.5.3.2</version>
    </dependency>
    <dependency>
        <artifactId>dynamic-datasource-spring-boot-starter</artifactId>
        <version>3.5.0</version>
    </dependency>
    <dependency>
        <groupId>com.alibaba</groupId>
        <artifactId>druid-spring-boot-starter</artifactId>
        <version>1.1.14</version>
    </dependency>
    <dependency>
        <groupId>com.mysql</groupId>
        <artifactId>mysql-connector-j</artifactId>
        <scope>runtime</scope>
    </dependency>
    <dependency>
        <artifactId>druid</artifactId>
        <version>1.2.15</version>
    </dependency>
    <dependency>
        <groupId>org.projectlombok</groupId>
        <artifactId>lombok</artifactId>
        <optional>true</optional>
    </dependency>
    <dependency>
        <artifactId>spring-boot-starter-test</artifactId>
        <scope>test</scope>
    </dependency>
    <dependency>
        <groupId>com.dameng</groupId>
        <artifactId>Dm8JdbcDriver18</artifactId>
        <version>8.1.1.49</version>
    </dependency>
    <dependency>
        <groupId>com.oracle.database.jdbc</groupId>
        <artifactId>ojdbc8</artifactId>
    </dependency>
</dependencies>
<build>
    <plugins>
        <plugin>
            <artifactId>spring-boot-maven-plugin</artifactId>
            <configuration>
                <excludes>
                    <exclude>
                    </exclude>
                </excludes>
            </configuration>
        </plugin>
    </plugins>
</build>
application.ym
spring:
  datasource:
    dynamic:
      primary:  #设置默认的数据源或者数据源组,默认值即为master
      strict: false #严格匹配数据源,默认false. true未匹配到指定数据源时抛异常,false使用默认数据源
      datasource:
        mysql1:
          username: root
          password: PWD
          url: jdbc:mysql://IP:3306/mysql?serverTimezone=Asia/Shanghai&useUnicode=true&characterEncoding=UTF-8
          driver-class-name: com.mysql.cj.jdbc.Driver
          #          driver-class-name: com.mysql.jdbc.Driver
        mysql2:
          url: jdbc:mysql://IP:3306/sys?serverTimezone=Asia/Shanghai&useUnicode=true&characterEncoding=UTF-8
          username: root
          password: PWD
        oracle:
          username: system
          password: PWD
          url: jdbc:oracle:thin:@IP:1521:orcl
          driver-class-name: oracle.jdbc.driver.OracleDriver
        dm:
          url: jdbc:dm://127.0.0.1:5236/demo?
          username: SYSDBA
          password: SYSDBA
          driver-class-name: dm.jdbc.driver.DmDriver
        DSQL:
          url: jdbc:mysql://gz-cynosdbmyxxxxxxxxxxxxxxxxxxxxxxx.com:29569/ToDemo
          username: root
          password: pwd
server:
  port: 8089
mybatis-plus:
  configuration:
    #输出日志
    log-impl: org.apache.ibatis.logging.stdout.StdOutImpl
    #配置映射规则
    map-underscore-to-camel-case: true #表示支持下划线到驼蜂的映射
    #隐藏mybatis图标
  global-config:
    banner: false
    db-config:
      logic-delete-field: status
      logic-not-delete-value: 1
      logic-delete-value: 0
spy.properties
#3.2.1以上使用
modulelist=com.baomidou.mybatisplus.extension.p6spy.MybatisPlusLogFactory,com.p6spy.engine.outage.P6OutageFactory
#3.2.1以下使用或者不配置
#modulelist=com.p6spy.engine.logging.P6LogFactory,com.p6spy.engine.outage.P6OutageFactory
# 自定义日志打印
logMessageFormat=com.baomidou.mybatisplus.extension.p6spy.P6SpyLogger
#日志输出到控制台
appender=com.baomidou.mybatisplus.extension.p6spy.StdoutLogger
# 使用日志系统记录 sql
#appender=com.p6spy.engine.spy.appender.Slf4JLogger
# 设置 p6spy driver 代理
deregisterdrivers=true
# 取消JDBC URL前缀
useprefix=true
# 配置记录 Log 例外,可去掉的结果集有error,info,batch,debug,statement,commit,rollback,result,resultset.
excludecategories=info,debug,result,commit,resultset
# 日期格式
dateformat=yyyy-MM-dd HH:mm:ss
# 实际驱动可多个
#driverlist=org.h2.Driver
# 是否开启慢SQL记录
outagedetection=true
# 慢SQL记录标准 2 秒
outagedetectioninterval=2
MybatisX逆向工程
逆向工程:通过数据库表接口,逆向生成java工程结构
实体类、mapper接口、mapper映射文件、Service接口、service实现类
连接上数据库
mapper(dao层)
@Mapper
public interface UserMapper extends BaseMapper<User> {
@Mapper
public interface TUserMapper extends BaseMapper<TUser> {
@Mapper
public interface TestMapper extends BaseMapper<Test> {
    List<Test> selectTestAll();
@Mapper
public interface DmuserMapper extends BaseMapper<Dmuser> {
    List<Dmuser> selectDmUserAll();
    Integer addDmUser(Dmuser dmuser);
@Mapper
​service接口层
public interface UserService extends IService<User> {
public interface TUserService extends IService<TUser> {
public interface TestService extends IService<Test> {
public interface DmuserService extends IService<Dmuser> {
​serviceimpl类
@Service
@DS("mysql2")
public class UserServiceImpl extends ServiceImpl<UserMapper, User>
    implements UserService{
@Service
@DS("mysql1")
public class TUserServiceImpl extends ServiceImpl<TUserMapper, TUser>
    implements TUserService{
@Service
@DS("oracle")
public class TestServiceImpl extends ServiceImpl<TestMapper, Test>
    implements TestService{
    @Autowired
    private TestMapper testMapper;
    @Override
    public List<Test> selectTestAll() {
        return testMapper.selectTestAll();
@Service
@DS("dm")
public class DmuserServiceImpl extends ServiceImpl<DmuserMapper, Dmuser>
    implements DmuserService{
    @Autowired
    private DmuserMapper dmuserMapper;
    @Override
    public List<Dmuser> selectDmUserAll() {
        return dmuserMapper.selectDmUserAll();
    @Override
    public Integer addDmUser(Dmuser dmuser) {
        return dmuserMapper.addDmUser(dmuser);
@Service
@DS("TDSQL")
public class TdUserServiceImpl extends ServiceImpl<TdUserMapper, TdUser>
    implements TdUserService{
测试类
@Autowired
    private TUserService tUserService;
    @Autowired
    private UserService userService;
    @Autowired
    private TestService testService;
    @Autowired
    private DmuserService dmuserService;
    @Autowired
    private TdUserService tdUserService;
@Test
void TDSqlDemo(){
    tdUserService.list();
@Test
void TDSqlDemo(){
迁移测试
Mysql迁移至TDSQL
@Test
        void MysqlToTDsql(){
            List<TUser> mysqls =tUserService.list();
            for (TUser mysql : mysqls) {
                TdUser tdUser =new TdUser();
                tdUser.setId("");
                tdUser.setName(mysql.getName());
                tdUser.setGender(0);
                tdUser.setEmail(mysql.getEmail());
                tdUserService.save(tdUser);
                System.out.println(""+mysql);
​Oracle迁移至TDSQL
@Test
        void OracleToTDsql(){
        List<com.example.domain.Test> oracles =testService.selectTestAll();
        for (com.example.domain.Test oracle : oracles) {
            tdUser.setId(String.valueOf(oracle.getId()));
            tdUser.setName(oracle.getName());
            tdUser.setEmail(String.valueOf(oracle.getClass()));
            System.out.println(""+oracle);
​DM8(达梦)迁移至TDSQL
@Test
void DMtoTDsql(){
     List<Dmuser> dmusers = dmuserService.selectDmUserAll();
    for (Dmuser dmuser : dmusers) {
        tdUser.setId(String.valueOf(dmuser.getId()));
        tdUser.setName(dmuser.getName());
        tdUser.setEmail(dmuser.getAddress());
        System.out.println(tdUser);
