私密离线聊天新体验!llama-gpt聊天机器人:极速、安全、搭载Llama 2,尽享Code Llama支持!
汀丶 发表于 2023/10/11 10:58:02 2023/10/11
【摘要】 私密离线聊天新体验!llama-gpt聊天机器人:极速、安全、搭载Llama 2,尽享Code Llama支持!
“私密离线聊天新体验!llama-gpt聊天机器人:极速、安全、搭载Llama 2,尽享Code Llama支持!”
一个自托管的、离线的、类似chatgpt的聊天机器人。由美洲驼提供动力。100%私密,没有数据离开您的设备。
Demo
https://github.com/getumbrel/llama-gpt/assets/10330103/5d1a76b8-ed03-4a51-90bd-12ebfaf1e6cd
1.支持模型
Currently, LlamaGPT supports the following models. Support for running custom models is on the roadmap.
Model name Model size Model download size Memory required
Nous Hermes Llama 2 7B Chat (GGML q4_0) 7B 3.79GB 6.29GB
Nous Hermes Llama 2 13B Chat (GGML q4_0) 13B 7.32GB 9.82GB
Nous Hermes Llama 2 70B Chat (GGML q4_0) 70B 38.87GB 41.37GB
Code Llama 7B Chat (GGUF Q4_K_M) 7B 4.24GB 6.74GB
Code Llama 13B Chat (GGUF Q4_K_M) 13B 8.06GB 10.56GB
Phind Code Llama 34B Chat (GGUF Q4_K_M) 34B 20.22GB 22.72GB
1.1 安装LlamaGPT 在 umbrelOS
Running LlamaGPT on an umbrelOS home server is one click. Simply install it from the Umbrel App Store.
LlamaGPT on Umbrel App Store
1.2 安装LlamaGPT on M1/M2 Mac
Make sure your have Docker and Xcode installed.
Then, clone this repo and cd into it:
git clone https://github.com/getumbrel/llama-gpt.git
cd llama-gpt
Run LlamaGPT with the following command:
./run-mac.sh --model 7b
You can access LlamaGPT at http://localhost:3000.
To run 13B or 70B chat models, replace 7b with 13b or 70b respectively.
To run 7B, 13B or 34B Code Llama models, replace 7b with code-7b, code-13b or code-34b respectively.
To stop LlamaGPT, do Ctrl + C in Terminal.
1.3 在 Docker上安装
You can run LlamaGPT on any x86 or arm64 system. Make sure you have Docker installed.
cd llama-gpt
./run.sh --model 7b
Or if you have an Nvidia GPU, you can run LlamaGPT with CUDA support using the --with-cuda flag, like:
./run.sh --model 7b --with-cuda
To run Code Llama 7B, 13B or 34B models, replace 7b with code-7b, code-13b or code-34b respectively.
Note: On the first run, it may take a while for the model to be downloaded to the /models directory. You may also see lots of output like this for a few minutes, which is normal:
llama-gpt-llama-gpt-ui-1       | [INFO  wait] Host [llama-gpt-api-13b:8000] not yet available...
After the model has been automatically downloaded and loaded, and the API server is running, you’ll see an output like:
llama-gpt-ui_1   | ready - started server on 0.0.0.0:3000, url: http://localhost:3000
You can then access LlamaGPT at http://localhost:3000.
1.4 在Kubernetes安装
First, make sure you have a running Kubernetes cluster and kubectl is configured to interact with it.
Then, clone this repo and cd into it.
To deploy to Kubernetes first create a namespace:
kubectl create ns llama
Then apply the manifests under the /deploy/kubernetes directory with
kubectl apply -k deploy/kubernetes/. -n llama
Expose your service however you would normally do that.
2.OpenAI兼容API
Thanks to llama-cpp-python, a drop-in replacement for OpenAI API is available at http://localhost:3001. Open http://localhost:3001/docs to see the API documentation.
  • 基线
We’ve tested LlamaGPT models on the following hardware with the default system prompt, and user prompt: “How does the universe expand?” at temperature 0 to guarantee deterministic results. Generation speed is averaged over the first 10 generations.
Feel free to add your own benchmarks to this table by opening a pull request.
2.1 Nous Hermes Llama 2 7B Chat (GGML q4_0)
Device Generation speed
M1 Max MacBook Pro (64GB RAM) 54 tokens/sec
GCP c2-standard-16 vCPU (64 GB RAM) 16.7 tokens/sec
Ryzen 5700G 4.4GHz 4c (16 GB RAM) 11.50 tokens/sec
GCP c2-standard-4 vCPU (16 GB RAM) 4.3 tokens/sec
Umbrel Home (16GB RAM) 2.7 tokens/sec
Raspberry Pi 4 (8GB RAM) 0.9 tokens/sec
2.2 Nous Hermes Llama 2 13B Chat (GGML q4_0)
M1 Max MacBook Pro (64GB RAM) 20 tokens/sec
GCP c2-standard-16 vCPU (64 GB RAM) 8.6 tokens/sec
GCP c2-standard-4 vCPU (16 GB RAM) 2.2 tokens/sec
Umbrel Home (16GB RAM) 1.5 tokens/sec
2.3 Nous Hermes Llama 2 70B Chat (GGML q4_0)
M1 Max MacBook Pro (64GB RAM) 4.8 tokens/sec
GCP e2-standard-16 vCPU (64 GB RAM) 1.75 tokens/sec
GCP c2-standard-16 vCPU (64 GB RAM) 1.62 tokens/sec
2.4 Code Llama 7B Chat (GGUF Q4_K_M)
M1 Max MacBook Pro (64GB RAM) 41 tokens/sec
2.5 Code Llama 13B Chat (GGUF Q4_K_M)
M1 Max MacBook Pro (64GB RAM) 25 tokens/sec
2.6 Phind Code Llama 34B Chat (GGUF Q4_K_M)
M1 Max MacBook Pro (64GB RAM) 10.26 tokens/sec
更多优质内容请关注公号:汀丶人工智能;会提供一些相关的资源和优质文章,免费获取阅读。
