c++ goto实现generator
lessIsBetter 发表于 2023/09/28 11:20:52 2023/09/28
【摘要】 generator的主要的效果就是产生一个输出后,停在原地,直到再次被调用。python自身就带有generator,是一个重要特性,带来了很多便捷。但是c++本身不直接支持generator。如果一定要用的话,利用goto在循环中停止,是可行的。虽然goto普遍被大家诟病,但由于c++基本语法与基础库的局限性,在产生器这种场景,也许goto还不错。#include <iostream>cl...
#include <iostream>
class Generator {
public:
    const std::string &Yield()
        if (isFuncYieldCalled) {
            goto POS_CONTINUE;
        isFuncYieldCalled = true;
        for (i = 0; i < 2; ++i) {
            for (j = 0; j < 3; ++j) {
                value = "i=" + std::to_string(i) + ",j=" + std::to_string(j);
                return value;
                POS_CONTINUE:
                continue;
        value = "";
        return value;
    int i = 0;
    int j = 0;
    bool isFuncYieldCalled = false;
    std::string value;
int main()
    std::cout << "Hello, World!" << std::endl;
    Generator generator;
    for (auto value = generator.Yield(); !value.empty(); value = generator.Yield()) {
        std::cout << value << std::endl;
    return 0;
输出为:
Hello, World!
i=0,j=0
i=0,j=1
i=0,j=2
i=1,j=0
i=1,j=1
i=1,j=2
Process finished with exit code 0
评论(0
