导出pg_default_acl表的alter default privileges赋权语句的方式
一只小小小小鸟 发表于 2023/09/16 17:20:03 2023/09/16
【摘要】 简介:本文主要介绍如何将pg_default_acl表中的数据转化为原始的赋权语句1、pg_default_acl系统表介绍表含义:此表存储为新建对象设置的初始权限创建三个用户:create user ysw_1 password 'y1234567.';create user ysw_2 password 'y1234567.';create user ysw_3 password ...
创建三个用户:
create user ysw_3  password 'y1234567.';
登陆ysw_1用户,将schema:ysw_1的select权限给用户ysw_2,将schema:ysw_1的insert权限给用户ysw_3
--登陆ysw_1用户
gsql postgres -r -p 25308 -U ysw_1 -W y1234567.
--将schema:ysw_1的select权限给用户ysw_2
ALTER DEFAULT PRIVILEGES FOR USER ysw_1 IN SCHEMA ysw_1 GRANT SELECT ON TABLES TO ysw_2;
--将schema:ysw_1的insert权限给用户ysw_3.
ALTER DEFAULT PRIVILEGES FOR USER ysw_1 IN SCHEMA ysw_1 GRANT INSERT ON TABLES TO ysw_3;
原始查询语句:
select * from pg_default_acl;
经简单处理的查询语句:
SELECT
pg_catalog.pg_get_userbyid(d.defaclrole) AS "Granter",
n.nspname AS "Schema",
CASE d.defaclobjtype WHEN 'r' THEN 'TABLES' WHEN 'S' THEN 'SEQUENCES' WHEN 'f' THEN 'FUNCTIONS' WHEN 'T' THEN 'TYPES' END AS "Type",
pg_catalog.array_to_string(d.defaclacl, E', ') AS "Access privileges"
FROM pg_catalog.pg_default_acl d
LEFT JOIN pg_catalog.pg_namespace n ON n.oid = d.defaclnamespace
ORDER BY 1, 2, 3;
2、建立权限映射表
create table public.permission_mapping
    prototype varchar(1),
    aim varchar(10)
insert into permission_mapping values('r','select');
insert into permission_mapping values('a','insert');
3、创建一个函数进行权限的格式转化
比如将ar转化为:insert,select
create or replace function permission_exchange(varchar)
returns varchar
as
declare
re varchar :='';
tmp varchar := '';
single varchar :='';
i int := 1;
length int := char_length($1);
begin
while i<=length loop
select substring($1,i,1) into single;
select aim into tmp from permission_mapping where prototype = single;
re :=concat(re,tmp);
if i<length
then re :=concat(re,',');
end if;
i :=i+1;
end loop;
return re;
end;
LANGUAGE plpgsql;
4、生成原始赋权语句的sql
示例模板:
alter default privileges for user 授权用户 in schema 模式 grant 拼接权限 on 类型 to 用户;
最终查询sql
with tmp as(
    select defaclrole,defaclnamespace,defaclobjtype,unnest(defaclacl) as defaclacl from pg_catalog.pg_default_acl
SELECT
pg_catalog.pg_get_userbyid(d.defaclrole) AS "granter",
n.nspname AS "schema",
CASE d.defaclobjtype WHEN 'r' THEN 'tables' WHEN 'S' THEN 'sequences' WHEN 'f' THEN 'functions' WHEN 'T' THEN 'types' END AS "Type",
d.defaclacl,
permission_exchange(to_char(regexp_substr(d.defaclacl::text, '(?<=\=).*?(?=\/)'))) as right,
regexp_substr(d.defaclacl::text,'\w+(?=\=)') as to_user
FROM tmp d
ORDER BY 1, 2, 3;
提示:可根据需要按照示例模板拼接赋权的sql语句
