Apache IoTDB开发系统之Writing Data on HDFS
小云悠悠zZ 发表于 2023/09/08 09:19:57 2023/09/08
【摘要】 目前支持将 TSFile(包括 TSFile 和相关数据文件)存储在本地文件系统和 Hadoop分布式文件系统 (HDFS) 中。配置TSFile的存储文件系统非常容易。
共享存储体系结构
系统架构
当您配置将 TSFile 存储在 HDFS 上时,您的数据文件将位于分布式存储中。系统架构如下:
在HDFS上写入数据 - 图1
配置和用法
如果要将 TSFile 和相关数据文件存储在 HDFS 中,步骤如下:
首先,从网站下载源版本或 git 克隆仓库,发布版本的标签是 release/x.x.x
通过以下方式构建服务器和Hadoop模块:mvn clean package -pl server,hadoop -am -Dmaven.test.skip=true
然后,将 Hadoop 模块的目标 jar 复制到服务器目标库文件夹中。hadoop-tsfile-0.10.0-jar-with-dependencies.jar.../server/target/iotdb-server-0.10.0/lib
在 中编辑用户配置。相关配置包括:iotdb-engine.properties
  • tsfile_storage_fs
Name tsfile_storage_fs
Description The storage file system of Tsfile and related data files. Currently LOCAL file system and HDFS are supported.
Type String
Default LOCAL
Effective After restart system
  • core_site_path
Name core_site_path
Description Absolute file path of core-site.xml if Tsfile and related data files are stored in HDFS.
Type String
Default /etc/hadoop/conf/core-site.xml
  • hdfs_site_path
Name hdfs_site_path
Description Absolute file path of hdfs-site.xml if Tsfile and related data files are stored in HDFS.
Type String
Default /etc/hadoop/conf/hdfs-site.xml
  • hdfs_ip
Name hdfs_ip
Description IP of HDFS if Tsfile and related data files are stored in HDFS. If there are more than one hdfs_ip in configuration, Hadoop HA is used.
Type String
Default localhost
  • hdfs_port
Name hdfs_port
Description Port of HDFS if Tsfile and related data files are stored in HDFS
Type String
Default 9000
  • dfs_nameservices
Name hdfs_nameservices
Description Nameservices of HDFS HA if using Hadoop HA
Type String
Default hdfsnamespace
  • dfs_ha_namenodes
Name hdfs_ha_namenodes
Description Namenodes under DFS nameservices of HDFS HA if using Hadoop HA
Type String
Default nn1,nn2
  • dfs_ha_automatic_failover_enabled
Name dfs_ha_automatic_failover_enabled
Description Whether using automatic failover if using Hadoop HA
Type Boolean
Default true
  • dfs_client_failover_proxy_provider
Name dfs_client_failover_proxy_provider
Description Proxy provider if using Hadoop HA and enabling automatic failover
Type String
Default org.apache.hadoop.hdfs.server.namenode.ha.ConfiguredFailoverProxyProvider
  • hdfs_use_kerberos
Name hdfs_use_kerberos
Description Whether use kerberos to authenticate hdfs
Type String
Default false
  • kerberos_keytab_file_path
Name kerberos_keytab_file_path
Description Full path of kerberos keytab file
Type String
Default /path
  • kerberos_principal
Name kerberos_principal
Description Kerberos pricipal
Type String
Default your principal
启动服务器,Tsfile将存储在HDFS上。
如果要将存储文件系统重置为本地,只需将配置编辑为 。在这种情况下,如果已经在HDFS上有一些数据文件,应该将它们下载到本地并移动到你的配置数据文件夹(默认),或者重新启动你的进程并将数据导入到IoTDB。tsfile_storage_fsLOCAL../server/target/iotdb-server-0.10.0/data/data
启动服务器或尝试创建时间序列时,可能会遇到以下错误:
ERROR org.apache.iotdb.tsfile.fileSystem.fsFactory.HDFSFactory:62 - Failed to get Hadoop file system. Please check your dependency of Hadoop module.
1.
构建Hadoop模块:mvn clean package -pl hadoop -am -Dmaven.test.skip=true
