Apache IoTDB开发系统整合之Spark IoTDB Connecter
小云悠悠zZ 发表于 2023/08/31 22:24:30 2023/08/31
【摘要】 以下 TsFile 结构为例: TsFile 架构中有三个度量:状态、温度和硬件。
version
The versions required for Spark and Java are as follow:
Spark Version Scala Version Java Version TsFile
2.4.3 2.11 1.8 0.10.0
install
mvn clean scala:compile compile install.
1. maven dependency
  1. <dependency>
  2. <groupId>org.apache.iotdb</groupId>
  3. <artifactId>spark-iotdb-connector</artifactId>
  4. <version>0.10.0</version>
  5. </dependency>
2. spark-shell user guide
  1. spark-shell --jars spark-iotdb-connector-0.10.0.jar,iotdb-jdbc-0.10.0-jar-with-dependencies.jar
  2. import org.apache.iotdb.spark.db._
  3. val df = spark.read.format("org.apache.iotdb.spark.db").option("url","jdbc:iotdb://127.0.0.1:6667/").option("sql","select * from root").load
  4. df.printSchema()
  5. df.show()
如果要对RDD进行分区,可以执行以下操作
  4. option("lowerBound", [lower bound of time that you want query(include)]).option("upperBound", [upper bound of time that you want query(include)]).
  5. option("numPartition", [the partition number you want]).load
  6. df.printSchema()
  7. df.show()
3. 模式推理
以下 TsFile 结构为例: TsFile 架构中有三个度量:状态、温度和硬件。这三项测量的基本信息如下:
Name Type Encode
status Boolean PLAIN
temperature Float RLE
hardware Text PLAIN
The existing data in the TsFile is as follows:
device:root.ln.wf01.wt01 device:root.ln.wf02.wt02
status temperature hardware status
time value time value time value time value
1 True 1 2.2 2 “aaa” 1 True
3 True 2 2.2 4 “bbb” 2 False
5 False 3 2.1 6 “ccc” 4 True
The wide(default) table form is as follows:
time root.ln.wf02.wt02.temperature root.ln.wf02.wt02.status root.ln.wf02.wt02.hardware root.ln.wf01.wt01.temperature root.ln.wf01.wt01.status root.ln.wf01.wt01.hardware
1 null true null 2.2 true null
2 null false aaa 2.2 null null
3 null null null 2.1 true null
4 null true bbb null null null
5 null null null null false null
6 null null ccc null null null
You can also use narrow table form which as follows: (You can see part 4 about how to use narrow form)
time device_name status hardware temperature
1 root.ln.wf02.wt01 true null 2.2
1 root.ln.wf02.wt02 true null null
2 root.ln.wf02.wt01 null null 2.2
2 root.ln.wf02.wt02 false aaa null
3 root.ln.wf02.wt01 true null 2.1
4 root.ln.wf02.wt02 true bbb null
5 root.ln.wf02.wt01 false null null
6 root.ln.wf02.wt02 null ccc null
4. 宽表和窄表之间的转换
从宽到窄
  1. import org.apache.iotdb.spark.db._
  2. val wide_df = spark.read.format("org.apache.iotdb.spark.db").option("url", "jdbc:iotdb://127.0.0.1:6667/").option("sql", "select * from root where time < 1100 and time > 1000").load
  3. val narrow_df = Transformer.toNarrowForm(spark, wide_df)
从窄到宽
  2. val wide_df = Transformer.toWideForm(spark, narrow_df)
5. Java 用户指南
  1. import org.apache.spark.sql.Dataset;
  2. import org.apache.spark.sql.Row;
  3. import org.apache.spark.sql.SparkSession;
  4. import org.apache.iotdb.spark.db.*
  5. public class Example {
  6. public static void main(String[] args) {
  7. SparkSession spark = SparkSession
  8. .builder()
  9. .appName("Build a DataFrame from Scratch")
  10. .master("local[*]")
  11. .getOrCreate();
  12. Dataset<Row> df = spark.read().format("org.apache.iotdb.spark.db")
  13. .option("url","jdbc:iotdb://127.0.0.1:6667/")
  14. .option("sql","select * from root").load();
  15. df.printSchema();
  16. df.show();
  17. Dataset<Row> narrowTable = Transformer.toNarrowForm(spark, df)
  18. narrowTable.show()
  19. }
  20. }
