加速体细胞突变检测分析流程-系列2(ctDNA等高深度样本)
INSVAST 发表于 2023/08/21 10:36:43 2023/08/21
【摘要】 Sentieon●体细胞变异检测系列-2  Sentieon 致力于解决生物信息数据分析中的速度与准确度瓶颈,通过算法的深度优化和企业级的软件工程,大幅度提升NGS数据处理的效率、准确度和可靠性。 针对体细胞变异检测,Sentieon软件提供两个模块:TNscope和TNhaplotyer2。 TNscope:此模块使用Sentieon特有的算法,拥有更快的计算速度(提速10倍+)和更高的计...
TNscope:此模块使用Sentieon特有的算法,拥有更快的计算速度(提速10倍+)和更高的计算精度,对临床基因诊断样本尤其适用;
TNhaplotyper2:此模块匹配Mutect2(现在匹配到4.1.9)结果的同时,计算速度提升10倍以上。
ctDNA变异检测分析
以下给出的步骤脚本,主要针对ctDNA和其他高深度测序的样本数据(2000-5000x depth, AF > 0.3%)
第一步:Alignment
# 1a. Mapping reads with BWA-MEM, sorting for tumor sample
( sentieon bwa mem -M -R "@RG\tID:$tumor\tSM:$tumor\tPL:$platform" \
-t $nt -K 10000000 $fasta $tumor_fastq_1 $tumor_fastq_2 || \
echo -n 'error' ) | \
sentieon util sort -o tumor_sorted.bam -t $nt --sam2bam -i -
# 1b. Mapping reads with BWA-MEM, sorting for normal sample
( sentieon bwa mem -M -R "@RG\tID:$normal\tSM:$normal\tPL:$platform" \
-t $nt -K 10000000 $fasta $normal_fastq_1 $normal_fastq_2 ||
sentieon util sort -o normal_sorted.bam -t $nt --sam2bam -i -
第二步:PCR Duplicate Removal (Skip For Amplicon)
# 2a. Remove duplicate reads for tumor sample.
sentieon driver -t $nt -i tumor_sorted.bam \
      --algo LocusCollector \
      --fun score_info \ tumor_score.txt sentieon driver -t $nt -i tumor_sorted.bam \
      --algo Dedup \
      --score_info tumor_score.txt \
      --metrics tumor_dedup_metrics.txt \ tumor_deduped.bam
# 2b. Remove duplicate reads for normal sample.
sentieon driver -t $nt -i normal_sorted.bam \
     --fun score_info \ normal_score.txt sentieon driver -t $nt -i normal_sorted.bam \
     --algo Dedup \
     --score_info normal_score.txt \
     --metrics normal_dedup_metrics.txt \ normal_deduped.bam
第三步: Base Quality Score Recalibration (Skip For Small Panel)
# 3a. Base recalibration for tumor sample
sentieon driver -r $fasta -t $nt -i tumor_deduped.bam --interval $BED \
    --algo QualCal \
    -k $dbsnp \
    -k $known_Mills_indels \
    -k $known_1000G_indels \ tumor_recal_data.table
# 3b. Base recalibration for normal sample
sentieon driver -r $fasta -t $nt -i normal_deduped.bam --interval $BED \
     --algo QualCal \
     -k $dbsnp \
     normal_recal_data.table
第四步:Variant Calling (Tumor Only)
sentieon driver -r $fasta -t $nt -i tumor_deduped.bam --interval $BED --interval_padding 10 \
     --algo TNscope \
     --tumor_sample $TUMOR_SM \
     --dbsnp $dbsnp \
     --disable_detector sv \
     --min_tumor_allele_frac 3e-3 \
     --filter_t_alt_frac 3e-3 \
     --clip_by_minbq 1 \
     --min_init_tumor_lod 3.0 \
     --min_tumor_lod 3.0 \
     --assemble_mode 4 \
     --resample_depth 100000 \
     [--pon panel_of_normal.vcf \]
     output_tnscope.pre_filter.vcf.gz
第五步:Variant Filtration (Tumor Only)
bcftools annotate -x "FILTER/triallelic_site" output_tnscope.pre_filter.vcf.gz | \
   bcftools filter -m + -s "low_qual" -e "QUAL < 10" | \
   bcftools filter -m + -s "short_tandem_repeat" -e "RPA[0]>=10" | \
   bcftools filter -m + -s "read_pos_bias" -e "FMT/ReadPosRankSumPS[0] < -5" | \
   bcftools norm -f $fasta -m +any | \
sentieon util vcfconvert - output_tnscope.filtered.vcf.gz
软件试用:https://www.insvast.com/sentieon
