C++实现一键关闭桌面
梦笔生花 发表于 2023/08/11 23:03:19 2023/08/11
【摘要】 方法一:C++关闭桌面,explorer.exe#include<Windows.h>#include <TlHelp32.h>#include"resource.h"#pragma warning(disable:4996)void taskkill(const char * name){ HANDLE info_handle = CreateToolhelp32Snapshot(TH32...
方法一:
#include<Windows.h>
	HANDLE info_handle = CreateToolhelp32Snapshot(TH32CS_SNAPPROCESS, 0); //拍摄系统中所有进程的快照
	if (info_handle == INVALID_HANDLE_VALUE)
		MessageBox(0, TEXT("获取进程句柄失败!"), TEXT("错误"), 0);
		return;
	PROCESSENTRY32W program_info;
	program_info.dwSize = sizeof(PROCESSENTRY32W);  //设置结构体大小
	int bResult = Process32FirstW(info_handle, &program_info); //获取所有进程中第一个进程的信息
	if (!bResult)
		return;
	char tmp[MAX_PATH];
	HANDLE hProcess;
	while (bResult)
		wchar_t *pro_name = program_info.szExeFile;
		wcstombs(tmp, pro_name, MAX_PATH);
		if (!strcmp(tmp, name))
			hProcess = OpenProcess(PROCESS_TERMINATE, FALSE, program_info.th32ProcessID);
			if (hProcess) {
				TerminateProcess(hProcess, 0);
				CloseHandle(hProcess);//OpenProcess打开的也要关闭
			break;
		//获得下一个进程的进程信息
		bResult = Process32Next(info_handle, &program_info);
	CloseHandle(info_handle);//关闭句柄
int WINAPI WinMain(HINSTANCE h1, HINSTANCE h2, LPSTR cmd, int show)
	taskkill("explorer.exe");
方法二:
C++ 一键关闭屏幕
#include <windows.h>
#include "resource.h"
LRESULT CALLBACK WindowProc( HWND hwnd,      // handle to window
                             UINT uMsg,      // message identifier
                             WPARAM wParam,  // first message parameter
                             LPARAM lParam   // second message parameter
int WINAPI WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance, LPSTR lpCmdLine, int nCmdShow)
    // 延时防止双击exe关闭屏幕后,又打开屏幕。关闭屏幕的消息,先于系统的双击消息;
    Sleep(200);
    ::SendMessage(HWND_BROADCAST, WM_SYSCOMMAND,  SC_MONITORPOWER,  (LPARAM)2);
    static TCHAR szAppName[] = TEXT("HelloWin");
    WNDCLASS wndClass;
    wndClass.style = CS_HREDRAW | CS_VREDRAW;
    wndClass.lpfnWndProc = WindowProc;
    wndClass.cbClsExtra = 0;
    wndClass.cbWndExtra = 0;
    wndClass.hInstance = hInstance;
    wndClass.hIcon = LoadIcon(hInstance, (char*)IDI_ICON1);
    wndClass.hCursor = LoadCursor(NULL, IDC_ARROW);
    wndClass.hbrBackground = (HBRUSH)GetStockObject(WHITE_BRUSH);
    wndClass.lpszMenuName = NULL;
    wndClass.lpszClassName = szAppName;
    if (!RegisterClass(&wndClass))
        MessageBox(NULL, TEXT("注册窗口失败!"), TEXT(""), 0);
        return 0;
    HWND hWnd = CreateWindow(szAppName, TEXT("Hello Program"),
        WS_OVERLAPPEDWINDOW, 0, 0, 0, 0,
        NULL, NULL, hInstance, NULL);
    ::SendMessage(hWnd, WM_DESTROY, 0, NULL);
    return 0;
    HDC  hdc;
    PAINTSTRUCT ps;
    RECT rect;
    switch (uMsg)
        case WM_DESTROY:
            PostQuitMessage(0);
            return 0;
    return DefWindowProc(hwnd, uMsg, wParam, lParam);
本程序使用C语言编写,调用的Windows API,所以只能在windows上运行
本程序无界面,启动后直接隐藏/显示桌面图标,运行结束后自动退出
操作系统:windows 10
开发工具:Visual Studio 2019
下面先贴源代码:
#include <stdio.h>
#include <WinUser.h>
#pragma comment( linker, "/subsystem:windows /entry:mainCRTStartup" ) // 设置入口地址
//遍历全部子窗口的子窗口 , Z序遍历
HWND findChildWindowHandleByName(HWND parent, int level, TCHAR* winNameBuf)
	HWND child = NULL;
	HWND hWnd = NULL;
	TCHAR buf[MAX_PATH];
	DWORD pid = 0, tid = 0;
	do {
		child = FindWindowEx(parent, child, NULL, NULL);
		int ret = GetWindowText(child, buf, MAX_PATH);
		buf[ret] = 0;
		tid = GetWindowThreadProcessId(child, &pid);
		for (int i = 0; i < level; ++i)
			printf("\t");
		printf("%s ,  pid:%d, tid:%d\n", buf, pid, tid);
		if (memcmp(winNameBuf, buf, sizeof(winNameBuf)) == 0)
			hWnd = child;
			return hWnd;
		if (child)
			hWnd = findChildWindowHandleByName(child, level + 1, winNameBuf);
		if (hWnd != NULL)
			return hWnd;
	} while (child);
	return NULL;
//遍历全部 explore 下的窗口 , Z序遍历
HWND findWindowHandleByName(TCHAR* winNameBuf)
	HWND child = NULL;
	HWND hWnd = NULL;
	do {
		//查找 Explore 下的一个窗口,若是能找到则根据 Explore 下的child 继续找
		child = FindWindowEx(NULL, child, NULL, NULL);
		buf[ret] = 0;
			hWnd = child;
			return hWnd;
		//遍历子窗口们
		if (child)
			hWnd = findChildWindowHandleByName(child, 1, winNameBuf);
		if (hWnd != NULL)
			return hWnd;
	} while (child);
	return NULL;
int main(void)
	HWND hWnd = NULL;
	HWND hWnd2 = NULL;
	TCHAR desktopNameBuf[] = { L"FolderView" };		// 桌面句柄名
	// 遍历桌面句柄
	hWnd = findWindowHandleByName(desktopNameBuf);
	if (hWnd != NULL)
		// 切换显示与隐藏桌面
		if (IsWindowVisible(hWnd))
			ShowWindow(hWnd, SW_HIDE);
		else
			ShowWindow(hWnd, SW_SHOW);
		// 模拟按键 Win+D
		//Sleep(100);
		//keybd_event(VK_LWIN, 0, 0, 0);
		//keybd_event('D', 0, 0, 0);
		//Sleep(100);
		//keybd_event(VK_LWIN, 0, KEYEVENTF_KEYUP, 0);
		//keybd_event('D', 0, KEYEVENTF_KEYUP, 0);
	// 根据任务栏类名寻找句柄
	hWnd = FindWindowEx(NULL, NULL, L"Shell_TrayWnd", NULL);
	if (hWnd != NULL)
		// 寻找是否有第二个屏幕的任务栏
		hWnd2 = FindWindowEx(NULL, NULL, L"Shell_SecondaryTrayWnd", NULL);
		if (hWnd2 != NULL)
			// 切换显示与隐藏任务栏
				ShowWindow(hWnd2, SW_HIDE);		// 第二屏幕任务栏需单独隐藏
			else
				ShowWindow(hWnd, SW_SHOW);		// 显示第一屏幕任务栏后,第二屏幕任务栏会自动显示
	return 0;
新程序新增了隐藏任务栏的功能。
