配置 Sublime Text4为 C++ 编辑器的方法
梦笔生花 发表于 2023/07/31 21:13:58 2023/07/31
【摘要】 概述涉及以下插件的安装和配置Package Control Terminus LSP LSP-clangd clang-format LSP-pyright LSP-json配置sublime安装Package Control以进行包管理。Terminus安装Terminus以实现sublime text4内的terminal。绑定快捷键:[ { "keys": [ "ctrl+shi...
概述
配置sublime
Terminus
绑定快捷键:
		"keys": [
			"ctrl+shift+t"
		"command": "terminus_open",
		"args": {
            // 打开时要执行的命令
            // "cmd": "fish",
			"cwd": "${file_path:${folder}}"
自定义在Terminus的终端中编译运行cpp文件:
在Tools->Build System->New Build System中新建编译文件,保存为CppTerminus.sublime-build,替换内容为:
	// MacOS
	"cmd": [
		"zsh",
		"-c",
		"clang++ '${file}' -std=c++17 -stdlib=libc++ -o '${file_path}/../bin/${file_base_name}' && ${file_path}/../bin/${file_base_name}"
	"file_regex": "^(..{FNXX==XXFN}*):([0-9]+):?([0-9]+)?:? (.*)$",
	"working_dir": "${file_path}",
	"encoding": "utf-8",
	"selector": "source.c, source.c++",
	"variants": [
			"name": "Run In Terminus",
			"target": "terminus_exec",
			"cancel": "terminus_cancel_build",
			"cmd": [
				"zsh",
				"-c",
			"name": "Create Input File",
			"cmd": [
				"zsh",
				"-c",
				"touch ${file_path}/../in_out/${file_base_name}.in && open -a Sublime\\ Text ${file_path}/../in_out/${file_base_name}.in"
			"name": "Run In Terminal",
			"cmd": [
				"zsh",
				"-c",
				"clang++ '${file}' -std=c++17 -stdlib=libc++ -o '${file_path}/../bin/${file_base_name}' && open -a Terminal.app '${file_path}/../bin/${file_base_name}'"
注意要保证源文件和bin文件夹、in_out文件夹在同一目录下。
配置LSP + LSP-clangd
安装这两个插件,windows和linux需要手动安装clangd并添加到path。
mac下安装clangd
我的mac已经自带了clangd,安装好这两个插件即可实现语法提示; 如果没有安装clangd,通过以下命令安装:
brew install llvm
echo 'export PATH="/usr/local/opt/llvm/bin:$PATH"' >> ~/.zshrc
echo 'export LDFLAGS="-L/usr/local/opt/llvm/lib"' >> ~/.zshrc
echo 'export CPPFLAGS="-I/usr/local/opt/llvm/include"' >> ~/.zshrc
Debian(testing)安装clangd和clang
sudo apt install clangd, sudo apt install llvm, sudo apt install clang
windows下安装llvm
借助scoop, scoop install llvm 然后安装Visual Stdudio Build Tools,鉴于windows上clang默认的c++库就是msvc,所以就用这个吧,别折腾mingw了.
配置LSP-clangd
到Preferences->Package Settings->LSP->Settings,写入这样几行
    // 在主页面只显示error红色下划线
    //"show_diagnostics_severity_level": 1,
    // 代码提示显示灯泡图标
    "show_code_actions": "bulb",
    // 保存时自动格式化
    "lsp_format_on_save": true,
再到Preferences->Package Settings->LSP->Servers->LSP-clangd中,写入以下几行
// Settings in here override those in "LSP-clangd/LSP-clangd.sublime-settings"
    "initializationOptions": {
        // 启用clang-tidy代码检查,可能启用后warning会比较多,自己看着办吧
        "clangd.clang-tidy": true,
        // 美化clangd输出的JSON
        "clangd.pretty": true,
再到project/code(源文件所在目录)下新建.clang-tidy文件,写入:
Checks: "bugprone-*,\
google-*,\
misc-*,\
modernize-*,\
performance-*,\
readability-*,\
portability-*,\
HeaderFilterRegex: 'Source/cm[^/]*\.(h|hxx|cxx)$'
CheckOptions:
  - key:   modernize-use-default-member-init.UseAssignment
    value: '1'
  - key:   modernize-use-equals-default.IgnoreMacros
    value: '0'
  - key:   modernize-use-auto.MinTypeNameLength
    value: '80'
LSP-clangd默认是使用c++98来检查代码的,要修改为c++17,需要在项目根目录下新建.clangd文件,文件内容如下:
CompileFlags:
	Add: [-std=c++17]
推荐方式为利用cmake生成compile_commands.json, CMakeLists.txt的内容如下:
cmake_minimum_required(VERSION 3.22)
# Enable C++11
set(CMAKE_CXX_STANDARD 17)
# 设置项目名
project(LeetCpp)
# 源文件
aux_source_directory(. SOURCES)
# 头文件
include_directories(.)
add_executable(${PROJECT_NAME} ${SOURCES})
通过cmake .. -DCMAKE_EXPORT_COMPILE_COMMANDS=1生成compile_commands.json文件,注意要在build目录下,且build的上级目录存在CMakelists.txt。
安装好clang-format插件之后,只需在project/code下新建.clang-format文件,写入以下内容
# 语言: None, Cpp, Java, JavaScript, ObjC, Proto, TableGen, TextProto
Language: Cpp
# BasedOnStyle: LLVM
# 访问说明符(public、private等)的偏移
AccessModifierOffset: -2
# 开括号(开圆括号、开尖括号、开方括号)后的对齐: Align, DontAlign, AlwaysBreak(总是在开括号后换行)
AlignAfterOpenBracket: Align
# 连续赋值时,对齐所有等号
AlignConsecutiveAssignments: false
# 连续声明时,对齐所有声明的变量名
AlignConsecutiveDeclarations: false
# 右对齐逃脱换行(使用反斜杠换行)的反斜杠
AlignEscapedNewlines: Right
# 水平对齐二元和三元表达式的操作数
AlignOperands: true
# 对齐连续的尾随的注释
AlignTrailingComments: true
# 不允许函数声明的所有参数在放在下一行
AllowAllParametersOfDeclarationOnNextLine: false
# 不允许短的块放在同一行
AllowShortBlocksOnASingleLine: true
# 允许短的case标签放在同一行
AllowShortCaseLabelsOnASingleLine: true
# 允许短的函数放在同一行: None, InlineOnly(定义在类中), Empty(空函数), Inline(定义在类中,空函数), All
AllowShortFunctionsOnASingleLine: None
# 允许短的if语句保持在同一行
AllowShortIfStatementsOnASingleLine: true
# 允许短的循环保持在同一行
AllowShortLoopsOnASingleLine: true
# 总是在返回类型后换行: None, All, TopLevel(顶级函数,不包括在类中的函数),
# AllDefinitions(所有的定义,不包括声明), TopLevelDefinitions(所有的顶级函数的定义)
AlwaysBreakAfterReturnType: None
# 总是在多行string字面量前换行
AlwaysBreakBeforeMultilineStrings: false
# 总是在template声明后换行
AlwaysBreakTemplateDeclarations: true
# false表示函数实参要么都在同一行,要么都各自一行
BinPackArguments: true
# false表示所有形参要么都在同一行,要么都各自一行
BinPackParameters: true
# 大括号换行,只有当BreakBeforeBraces设置为Custom时才有效
BraceWrapping:
  # class定义后面
  AfterClass: false
  # 控制语句后面
  AfterControlStatement: false
  # enum定义后面
  AfterEnum: false
  # 函数定义后面
  AfterFunction: false
  # 命名空间定义后面
  AfterNamespace: false
  # struct定义后面
  AfterStruct: false
  # union定义后面
  AfterUnion: false
  # extern之后
  AfterExternBlock: false
  # catch之前
  BeforeCatch: false
  # else之前
  BeforeElse: false
  # 缩进大括号
  IndentBraces: false
  # 分离空函数
  SplitEmptyFunction: false
  # 分离空语句
  SplitEmptyRecord: false
  # 分离空命名空间
  SplitEmptyNamespace: false
# 在二元运算符前换行: None(在操作符后换行), NonAssignment(在非赋值的操作符前换行), All(在操作符前换行)
BreakBeforeBinaryOperators: NonAssignment
# 在大括号前换行: Attach(始终将大括号附加到周围的上下文), Linux(除函数、命名空间和类定义,与Attach类似),
#   Mozilla(除枚举、函数、记录定义,与Attach类似), Stroustrup(除函数定义、catch、else,与Attach类似),
#   Allman(总是在大括号前换行), GNU(总是在大括号前换行,并对于控制语句的大括号增加额外的缩进), WebKit(在函数前换行), Custom
#   注:这里认为语句块也属于函数
BreakBeforeBraces: Custom
# 在三元运算符前换行
BreakBeforeTernaryOperators: false
# 在构造函数的初始化列表的冒号后换行
BreakConstructorInitializers: AfterColon
#BreakInheritanceList: AfterColon
BreakStringLiterals: false
# 每行字符的限制,0表示没有限制
ColumnLimit: 0
CompactNamespaces: true
# 构造函数的初始化列表要么都在同一行,要么都各自一行
ConstructorInitializerAllOnOneLineOrOnePerLine: false
# 构造函数的初始化列表的缩进宽度
ConstructorInitializerIndentWidth: 4
# 延续的行的缩进宽度
ContinuationIndentWidth: 4
# 去除C++11的列表初始化的大括号{后和}前的空格
Cpp11BracedListStyle: true
# 继承最常用的指针和引用的对齐方式
DerivePointerAlignment: false
# 固定命名空间注释
FixNamespaceComments: true
# 缩进case标签
IndentCaseLabels: false
IndentPPDirectives: None
# 缩进宽度
IndentWidth: 4
# 函数返回类型换行时,缩进函数声明或函数定义的函数名
IndentWrappedFunctionNames: false
# 保留在块开始处的空行
KeepEmptyLinesAtTheStartOfBlocks: false
# 连续空行的最大数量
MaxEmptyLinesToKeep: 1
# 命名空间的缩进: None, Inner(缩进嵌套的命名空间中的内容), All
NamespaceIndentation: None
# 指针和引用的对齐: Left, Right, Middle
PointerAlignment: Right
# 允许重新排版注释
ReflowComments: true
# 允许排序#include
SortIncludes: false
# 允许排序 using 声明
SortUsingDeclarations: false
# 在C风格类型转换后添加空格
SpaceAfterCStyleCast: false
# 在Template 关键字后面添加空格
SpaceAfterTemplateKeyword: true
# 在赋值运算符之前添加空格
SpaceBeforeAssignmentOperators: true
# SpaceBeforeCpp11BracedList: true
# SpaceBeforeCtorInitializerColon: true
# SpaceBeforeInheritanceColon: true
# 开圆括号之前添加一个空格: Never, ControlStatements, Always
SpaceBeforeParens: ControlStatements
# SpaceBeforeRangeBasedForLoopColon: true
# 在空的圆括号中添加空格
SpaceInEmptyParentheses: false
# 在尾随的评论前添加的空格数(只适用于//)
SpacesBeforeTrailingComments: 1
# 在尖括号的<后和>前添加空格
SpacesInAngles: false
# 在C风格类型转换的括号中添加空格
SpacesInCStyleCastParentheses: false
# 在容器(ObjC和JavaScript的数组和字典等)字面量中添加空格
SpacesInContainerLiterals: true
# 在圆括号的(后和)前添加空格
SpacesInParentheses: false
# 在方括号的[后和]前添加空格,lamda表达式和未指明大小的数组的声明不受影响
SpacesInSquareBrackets: false
# 标准: Cpp03, Cpp11, Auto
Standard: Cpp11
# tab宽度
TabWidth: 4
# 使用tab字符: Never, ForIndentation, ForContinuationAndIndentation, Always
UseTab: Never
命令行使用sublime text4打开文件
mac下添加软连接: ln /Applications/Sublime\ Text.app/Contents/SharedSupport/bin/subl /usr/local/bin/subl
debian下执行sudo ln -s /opt/sublime_text/sublime_text /usr/local/bin/subl
之后就能用subl test.cpp命令来调用sublime text4打开test.cpp了。
leetcode相关配置
安装leetgo: brew install j178/tap/leetgo
在预期的leetcode项目目录下执行leetgo init,然后配置leetgo.yaml
# leetgo project level config, global config is at /Users/zwy/.config/leetgo/config.yaml
# for more details, please refer to https://github.com/j178/leetgo
# author
author: zwyyy456
language: en
code:
  lang: cpp
leetcode:
  site: https://leetcode.com
#  credentials:
#    from: browser
editor:
  use: custom
  command: "subl"
  # use: vscode
