【K8S专题】三、Harbor 私有镜像仓库安装配置
全栈程序猿 发表于 2023/07/28 16:48:26 2023/07/28
【摘要】 首先需要按照前面的步骤,在环境上安装 Docker,才能安装 Harbor, 重新设置一台服务器 172.16.20.175,不要放在 K8S 的主从服务器上。 1、选择合适的版本进行下载,下载地址:https://github.com/goharbor/harbor/releases 2、解压tar -zxf harbor-offline-installer-v2.2.4.tgz 3、配置...
1、选择合适的版本进行下载,下载地址:
2、解压
3、配置
cd harbor
mv harbor.yml.tmpl harbor.yml
vi harbor.yml
4、将 hostname 改为当前服务器地址,注释掉 https 配置。
# The IP address or hostname to access admin UI and registry service.
# DO NOT use localhost or 127.0.0.1, because Harbor needs to be accessed by external clients.
hostname: 172.16.20.175
# http related config
http:
  # port for http, default is 80. If https enabled, this port will redirect to https port
  port: 80
# https related config
#https:
  # https port for harbor, default is 443
 # port: 443
  # The path of cert and key files for nginx
 # certificate: /your/certificate/path
 # private_key: /your/private/key/path
5、执行安装命令
mkdir /var/log/harbor/
./install.sh
6、查看安装是否成功
[root@localhost harbor]# docker ps
CONTAINER ID        IMAGE                                COMMAND                  CREATED             STATUS                             PORTS                                   NAMES
de1b702759e7        goharbor/harbor-jobservice:v2.2.4    "/harbor/entrypoint.…"   13 seconds ago      Up 9 seconds (health: starting)                                            harbor-jobservice
55b465d07157        goharbor/nginx-photon:v2.2.4         "nginx -g 'daemon of…"   13 seconds ago      Up 9 seconds (health: starting)    0.0.0.0:80->8080/tcp, :::80->8080/tcp   nginx
d52f5557fa73        goharbor/harbor-core:v2.2.4          "/harbor/entrypoint.…"   13 seconds ago      Up 10 seconds (health: starting)                                           harbor-core
4ba09aded494        goharbor/harbor-db:v2.2.4            "/docker-entrypoint.…"   13 seconds ago      Up 11 seconds (health: starting)                                           harbor-db
647f6f46e029        goharbor/harbor-portal:v2.2.4        "nginx -g 'daemon of…"   13 seconds ago      Up 11 seconds (health: starting)                                           harbor-portal
70251c4e234f        goharbor/redis-photon:v2.2.4         "redis-server /etc/r…"   13 seconds ago      Up 11 seconds (health: starting)                                           redis
21a5c408afff        goharbor/harbor-registryctl:v2.2.4   "/home/harbor/start.…"   13 seconds ago      Up 11 seconds (health: starting)                                           registryctl
b0937800f88b        goharbor/registry-photon:v2.2.4      "/home/harbor/entryp…"   13 seconds ago      Up 11 seconds (health: starting)                                           registry
d899e377e02b        goharbor/harbor-log:v2.2.4           "/bin/sh -c /usr/loc…"   13 seconds ago      Up 12 seconds (health: starting)   127.0.0.1:1514->10514/tcp               harbor-log
7、harbor 的启动停止命令
docker-compose down   #停止
docker-compose up -d  #启动
8、访问 harbor 管理台地址,上面配置的 hostname, http://172.16.20.175 (默认用户名/密码: admin/Harbor12345。
