链表奇偶位元素排序的问题
赵KK日常技术记录 发表于 2023/07/24 17:36:52 2023/07/24
【摘要】 链表奇偶位元素排序的问题在这个问题中,我们将解决一个链表的排序问题。给定一个链表,其中奇数位是升序排列的,偶数位是降序排列的。我们的目标是将整个链表按升序进行排序。首先,我们需要定义链表的节点类,表示链表中的每个节点:class ListNode { int val; ListNode next; public ListNode(int val) { thi...
链表奇偶位元素排序的问题
class ListNode {
    int val;
    ListNode next;
        this.val = val;
        next = null;
接下来,我们可以实现一个方法,它将采用一个链表作为输入,并返回一个已排序的链表。我们将使用归并排序的思想来解决该问题。
class Solution {
    public ListNode mergeSortList(ListNode head) {
        if (head == null || head.next == null) {
            return head;
        ListNode middle = getMiddle(head);
        ListNode nextOfMiddle = middle.next;
        middle.next = null;
        ListNode left = mergeSortList(head);
        ListNode right = mergeSortList(nextOfMiddle);
        return merge(left, right);
    private ListNode getMiddle(ListNode head) {
        if (head == null) {
            return head;
        ListNode slow = head;
        ListNode fast = head;
        while (fast.next != null && fast.next.next != null) {
            slow = slow.next;
            fast = fast.next.next;
        return slow;
    private ListNode merge(ListNode left, ListNode right) {
        ListNode dummy = new ListNode(0);
        ListNode current = dummy;
        while (left != null && right != null) {
            if (left.val <= right.val) {
                current.next = left;
                left = left.next;
                current.next = right;
                right = right.next;
            current = current.next;
        if (left != null) {
        if (right != null) {
        return dummy.next;
在上面的代码中,我们使用了一个辅助方法getMiddle()来找到链表的中间节点。然后,我们将链表分成两半,分别对左半部分和右半部分进行递归排序。
最后,我们使用一个辅助方法merge()来合并排序后的左右链表。从左链表的头部和右链表的头部开始比较节点的值,并按照升序的顺序连接节点。
现在,我们可以创建一个包含奇偶位元素的链表,并调用mergeSortList()方法来排序该链表:
public class Main {
        ListNode head = new ListNode(1);
        ListNode node2 = new ListNode(8);
        ListNode node3 = new ListNode(2);
        ListNode node4 = new ListNode(7);
        ListNode node5 = new ListNode(3);
        ListNode node6 = new ListNode(6);
        ListNode node7 = new ListNode(4);
        ListNode node8 = new ListNode(5);
        head.next = node2;
        node2.next = node3;
        node3.next = node4;
        node4.next = node5;
        node5.next = node6;
        node6.next = node7;
        node7.next = node8;
        Solution solution = new Solution();
        ListNode sortedList = solution.mergeSortList(head);
        // 输出排序后的链表
        while (sortedList != null) {
            System.out.print(sortedList.val + " -> ");
            sortedList = sortedList.next;
上述代码中的链表head包含了你提供的奇偶位排序的示例。我们创建了一个Solution对象,并使用该对象调用mergeSortList()方法对链表进行排序。最后,我们输出排序后的链表,以验证结果。
输出结果为:
1 -> 2 -> 3 -> 4 -> 5 -> 6 -> 7 -> 8 ->
从以上结果可以看出,链表已按升序进行了排序。
这就是使用链表的归并排序算法对奇偶位元素排序的示例代码。通过这个示例,我们可以看到如何使用递归和归并排序的思想来解决这个问题。下面我们来深入探讨一下该算法的逻辑和实现过程。
算法思路
奇偶位元素排序的问题可以看作是两个独立的排序问题:奇数位上的元素升序排序和偶数位上的元素降序排序。为了解决这个问题,我们可以按照以下步骤进行操作:
  1. 将链表一分为二,分别得到左半部分链表和右半部分链表。
  2. 对左半部分链表和右半部分链表分别进行递归排序。
  3. 对排序后的左半部分链表和右半部分链表进行合并,得到最终的有序链表。
代码实现
在上述示例代码中,我们定义了一个Solution类,并在其中实现了mergeSortList()方法以及辅助方法getMiddle()和merge()。
在递归排序的mergeSortList()方法中,我们首先判断链表是否为空或只包含一个节点,如果是,直接返回链表。否则,我们找到链表的中间节点并将其断开,然后分别对左右两个链表进行递归排序。
在合并两个有序链表的merge()方法中,我们使用了双指针的方法。我们创建一个虚拟头节点dummy作为合并后链表的头部,并创建一个指针current来追踪当前节点的位置。然后,我们比较两个链表的节点值,将较小的节点插入到合并链表的尾部,并移动相应的指针,直到其中一个链表为空。最后,我们将剩余链表连接到合并链表的尾部。
测试结果
在主函数中,我们创建了一个示例链表,其中的节点按照奇偶位要求进行排列。然后,我们调用mergeSortList()方法对链表进行排序,并使用循环遍历输出排序后的链表的元素值。
在示例中,我们创建了一个包含以下元素的链表:
1 -> 8 -> 2 -> 7 -> 3 -> 6 -> 4 -> 5 ->
经过排序后,输出的有序链表为:
从输出结果中可以看出,链表的奇偶位元素已经按照升序进行了排序,满足了问题的要求。
算法复杂度分析
归并排序算法的时间复杂度为 O(nlogn),其中 n 是链表的长度。这是因为在每个递归层级中,我们需要遍历每个节点以找到中间节点,因此总体的时间复杂度是递归层数乘以每层的节点数。
在空间复杂度方面,归并排序算法需要额外的空间来存储递归调用时产生的栈空间,以及合并过程中产生的新链表。因此,空间复杂度为 O(logn),在最坏的情况下,空间复杂度为 O(n)。
通过对链表进行奇偶位元素排序的例子,我们展示了归并排序算法在解决链表排序问题上的应用。该算法通过递归和分治的思想,将链表不断分割为更小的子问题,然后进行合并,最终得到整个链表的有序结果。
