SpringBoot实现redis切换dbindex
code2roc 发表于 2023/07/12 10:36:52 2023/07/12
【摘要】 前言在实际springboot集成redis使用过程中,针对不同类型的业务数据,可能存在不同的dbindex中,例如token存储db0,redis全局锁存储dbindex1,需要我们对RedisTemplate操作进行扩展,支持单次操作不同的dbindex 方案系统加载时初始化根据redis使用库的dbindex,初始化对应个数的RedisTemplate,调用时根据dbindex获取对...
前言
方案
系统加载时初始化根据redis使用库的dbindex,初始化对应个数的RedisTemplate,调用时根据dbindex获取对应的操作对象实例,本次实现是将15个db全部初始化
RedisRegist
初始化redis的Factory,线程池配置及RedisTemplate,StringRedisTemplate的Bean对象
public class RedisRegist implements EnvironmentAware,ImportBeanDefinitionRegistrar {
    private static final Logger logger = LoggerFactory.getLogger(RedisRegist.class);
    private static Map<String, Object> registerBean = new ConcurrentHashMap<>();
    private Environment environment;
    private Binder binder;
    @Override
    public void setEnvironment(Environment environment) {
        this.environment = environment;
        this.binder = Binder.get(this.environment);
    @Override
    public void registerBeanDefinitions(AnnotationMetadata importingClassMetadata, BeanDefinitionRegistry registry) {
        RedisEntity redisEntity;
        try {
            redisEntity = binder.bind("spring.redis", RedisEntity.class).get();
        } catch (NoSuchElementException e) {
            logger.error("redis not setting.");
            return;
        boolean onPrimary = true;
        //根据多个库实例化出多个连接池和Template
        for (int i = 0; i < 15; i++) {
            int database = i;
            //单机模式
            RedisStandaloneConfiguration configuration = new RedisStandaloneConfiguration();
            configuration.setHostName(String.valueOf(redisEntity.getHost()));
            configuration.setPort(Integer.parseInt(String.valueOf(redisEntity.getPort())));
            configuration.setDatabase(database);
            String password = redisEntity.getPassword();
            if (password != null && !"".equals(password)) {
                RedisPassword redisPassword = RedisPassword.of(password);
                configuration.setPassword(redisPassword);
            //池配置
            GenericObjectPoolConfig genericObjectPoolConfig = new GenericObjectPoolConfig();
            RedisProperties.Pool pool = redisEntity.getLettuce().getPoolEntity();
            genericObjectPoolConfig.setMaxIdle(pool.getMaxIdle());
            genericObjectPoolConfig.setMaxTotal(pool.getMaxActive());
            genericObjectPoolConfig.setMinIdle(pool.getMinIdle());
            if (pool.getMaxWait() != null) {
                genericObjectPoolConfig.setMaxWaitMillis(pool.getMaxWait().toMillis());
            Supplier<LettuceConnectionFactory> lettuceConnectionFactorySupplier = () -> {
                LettuceConnectionFactory factory = (LettuceConnectionFactory) registerBean.get("LettuceConnectionFactory" + database);
                if (factory != null) {
                    return factory;
                LettucePoolingClientConfiguration.LettucePoolingClientConfigurationBuilder builder = LettucePoolingClientConfiguration.builder();
                Duration shutdownTimeout = redisEntity.getLettuce().getShutdownTimeout();
                if(shutdownTimeout == null){
                    shutdownTimeout = redisEntity.getTimeout();
                if (shutdownTimeout != null) {
                    builder.shutdownTimeout(shutdownTimeout);
                LettuceClientConfiguration clientConfiguration = builder.poolConfig(genericObjectPoolConfig).build();
                factory = new LettuceConnectionFactory(configuration, clientConfiguration);
                registerBean.put("LettuceConnectionFactory" + database, factory);
                return factory;
            LettuceConnectionFactory lettuceConnectionFactory = lettuceConnectionFactorySupplier.get();
            BeanDefinitionBuilder builder = BeanDefinitionBuilder.genericBeanDefinition(LettuceConnectionFactory.class, lettuceConnectionFactorySupplier);
            AbstractBeanDefinition factoryBean = builder.getRawBeanDefinition();
            factoryBean.setPrimary(onPrimary);
            registry.registerBeanDefinition("lettuceConnectionFactory" + database, factoryBean);
            // StringRedisTemplate
            GenericBeanDefinition stringRedisTemplate = new GenericBeanDefinition();
            stringRedisTemplate.setBeanClass(StringRedisTemplate.class);
            ConstructorArgumentValues constructorArgumentValues = new ConstructorArgumentValues();
            constructorArgumentValues.addIndexedArgumentValue(0, lettuceConnectionFactory);
            stringRedisTemplate.setConstructorArgumentValues(constructorArgumentValues);
            stringRedisTemplate.setAutowireMode(AutowireCapableBeanFactory.AUTOWIRE_BY_NAME);
            registry.registerBeanDefinition("stringRedisTemplate" + database, stringRedisTemplate);
            // 定义RedisTemplate对象
            GenericBeanDefinition redisTemplate = new GenericBeanDefinition();
            redisTemplate.setBeanClass(RedisTemplate.class);
            redisTemplate.getPropertyValues().add("connectionFactory", lettuceConnectionFactory);
            redisTemplate.setAutowireMode(AutowireCapableBeanFactory.AUTOWIRE_BY_NAME);
            RedisSerializer stringSerializer = new StringRedisSerializer();
            Jackson2JsonRedisSerializer jackson2JsonRedisSerializer = new Jackson2JsonRedisSerializer(Object.class);
            // key采用String的序列化方式,value采用json序列化方式
            redisTemplate.getPropertyValues().add("keySerializer",new StringRedisSerializer());
            redisTemplate.getPropertyValues().add("hashKeySerializer",stringSerializer);
            redisTemplate.getPropertyValues().add("valueSerializer",jackson2JsonRedisSerializer);
            redisTemplate.getPropertyValues().add("hashValueSerializer",stringSerializer);
            //注册Bean
            registry.registerBeanDefinition("redisTemplate" + database, redisTemplate);
            //logger.info("Registration redis ({}) !", database);
            if (onPrimary) {
                onPrimary = false;
RedisManage
RedisTemplate,StringRedisTemplate的Bean对象统一管理定义
public class RedisManage {
    private Map<String, RedisTemplate> redisTemplateMap;
    private Map<String, StringRedisTemplate> stringRedisTemplateMap;
    public RedisManage(Map<String, RedisTemplate> redisTemplateMap,
                       Map<String, StringRedisTemplate> stringRedisTemplateMap) {
        this.redisTemplateMap = redisTemplateMap;
        this.stringRedisTemplateMap = stringRedisTemplateMap;
    public RedisTemplate redisTemplate(int dbIndex) {
        RedisTemplate redisTemplate = redisTemplateMap.get("redisTemplate" + dbIndex);
        return redisTemplate;
    public StringRedisTemplate stringRedisTemplate(int dbIndex) {
        StringRedisTemplate stringRedisTemplate = stringRedisTemplateMap.get("stringRedisTemplate" + dbIndex);
        stringRedisTemplate.setEnableTransactionSupport(true);
        return stringRedisTemplate;
    public Map<String, RedisTemplate> getRedisTemplateMap() {
        return redisTemplateMap;
    public Map<String, StringRedisTemplate> getStringRedisTemplateMap() {
        return stringRedisTemplateMap;
RedisConfig
将操作类Bean对象注入道RedisManage中
@AutoConfigureBefore({RedisAutoConfiguration.class})
@Import(RedisRegist.class)
@Configuration
public class RedisConfig implements EnvironmentAware, ApplicationContextAware {
    private static final Logger logger = LoggerFactory.getLogger(RedisConfig.class);
    private static String key1 = "redisTemplate";
    private static String key2 = "stringRedisTemplate";
    Map<String, RedisTemplate> redisTemplateMap = new HashMap<>();
    Map<String, StringRedisTemplate> stringRedisTemplateMap = new HashMap<>();
    private ApplicationContext applicationContext;
    @Override
    @PostConstruct
    public Map<String,RedisTemplate> initRedisTemplate(){
        try {
            throw new RuntimeException("Failed to configure  spring.redis: 'spring.redis' attribute is not specified and no embedded redis could be configured.");
        for (int i=0;i<15;i++){
            int database = i;
            String key = key1 + database;
            RedisTemplate redisTemplate = applicationContext.getBean(key , RedisTemplate.class);
            if(redisTemplate != null){
                redisTemplateMap.put(key , redisTemplate);
            key = key2 + database;
            if(stringRedisTemplateMap != null){
                StringRedisTemplate stringRedisTemplate = applicationContext.getBean(key , StringRedisTemplate.class);
                stringRedisTemplateMap.put(key , stringRedisTemplate);
        if(redisTemplateMap.size() == 0 && stringRedisTemplateMap.size() == 0){
            throw new RuntimeException("load redisTemplate failure , please check spring.redis property config!!!");
    @Override
    public void setApplicationContext(ApplicationContext applicationContext) throws BeansException {
        this.applicationContext = applicationContext;
    @Bean
    public RedisManage redisManage(){
        return new RedisManage(redisTemplateMap , stringRedisTemplateMap);
RedisUtil
调用RedisManage封装具体相关操作调用
@Component
public class RedisUtil {
    @Autowired
    private RedisManage redisManage;
    private int defatuDBIndex= 0;
    public void redisTemplateSet(String key, Object value){
        ValueOperations<Object, Object> ops = redisManage.redisTemplate(defatuDBIndex).opsForValue();
        ops.set(key, value);
    public void redisTemplateSet(String key, Object value,int dbIndex){
        ValueOperations<Object, Object> ops = redisManage.redisTemplate(dbIndex).opsForValue();
    public Object redisTemplateGet(String key){
        return ops.get(key);
    public Object redisTemplateGet(String key,int dbIndex){
    public void redisTemplateRemove(String key){
        ops.getOperations().delete(key);
    public void redisTemplateRemove(String key,int dbIndex){
    public void redisTemplateSetForList(String key, Map<String,Object> map){
        HashOperations<Object, Object,Object> ops = redisManage.redisTemplate(defatuDBIndex).opsForHash();
        ops.putAll(key,map);
    public void redisTemplateSetForList(String key, Map<String,Object> map,int dbIndex){
        HashOperations<Object, Object,Object> ops = redisManage.redisTemplate(dbIndex).opsForHash();
    public void redisTemplateSetForList(String key, String hashKey,Object value){
        ops.put(key,hashKey,value);
    public void redisTemplateSetForList(String key, String hashKey,Object value,int dbIndex){
    public Map<Object, Object> redisTemplateGetForList(String key){
        return ops.entries(key);
    public Map<Object, Object> redisTemplateGetForList(String key,int dbIndex){
    public Object redisTemplateGetForList(String key,String hasKey){
        return ops.get(key,hasKey);
    public Object redisTemplateGetForList(String key,String hasKey,int dbIndex){
    public  void setExpire(String key,long timeout, final TimeUnit unit,int dbIndex){
        redisManage.redisTemplate(dbIndex).expire(key,timeout, unit);
    public  void setExpire(String key,long timeout, final TimeUnit unit){
        redisManage.redisTemplate(defatuDBIndex).expire(key,timeout, unit);
    public boolean isValid(String key){
        boolean flag = false;
        if(  redisManage.redisTemplate(defatuDBIndex).hasKey(key)){
            if( redisManage.redisTemplate(defatuDBIndex).getExpire(key,TimeUnit.SECONDS)>0){
                flag = true;
        return flag;
    public boolean isValid(String key,int dbIndex){
        if(  redisManage.redisTemplate(dbIndex).hasKey(key)){
            if( redisManage.redisTemplate(dbIndex).getExpire(key,TimeUnit.SECONDS)>0){
                flag = true;
        return flag;
