SpringBoot集成itextpdf动态生成pdf并展示
code2roc 发表于 2023/07/12 10:14:46 2023/07/12
【摘要】 背景接上文SpringBoot集成markdown实现文档管理,对于表格的支持markdown不是特别友好,同时内部文档管理需要增加表格式api接口文档的功能,所以决定采用结合数据库存储与动态生成pdf借助目录结构展示的方式 表结构设计目录表DROP TABLE IF EXISTS `knowledge_interfacecatalog`;CREATE TABLE `knowledge_i...
背景
表结构设计
目录表
CREATE TABLE `knowledge_interfacecatalog` (
  `ID` int(11) NOT NULL AUTO_INCREMENT,
  `UnitGuid` varchar(50) DEFAULT NULL,
  `AddDate` datetime DEFAULT NULL,
  `CataName` varchar(100) DEFAULT NULL,
  `ParentCataGuid` varchar(50) DEFAULT NULL,
  `SortNum` int(11) DEFAULT NULL,
  `DocGuid` varchar(50) DEFAULT NULL,
  KEY `ID` (`ID`)
) ENGINE=InnoDB AUTO_INCREMENT=7 DEFAULT CHARSET=utf8mb4;
接口内容表
DROP TABLE IF EXISTS `knowledge_interfaceinfo`;
CREATE TABLE `knowledge_interfaceinfo` (
  `InterfaceName` varchar(100) DEFAULT NULL,
  `Description` varchar(500) DEFAULT NULL,
  `Remark` varchar(500) DEFAULT NULL,
  `ParamJson` varchar(2000) DEFAULT NULL,
  `ResponseJson` varchar(2000) DEFAULT NULL,
  `InterfaceAddress` varchar(500) DEFAULT NULL,
  `CataGuid` varchar(50) DEFAULT NULL,
  KEY `ID` (`ID`)
) ENGINE=InnoDB AUTO_INCREMENT=24 DEFAULT CHARSET=utf8mb4;
录入界面
PDF生成
引用
        <dependency>
            <groupId>com.itextpdf</groupId>
            <artifactId>itextpdf</artifactId>
            <version>5.4.3</version>
        </dependency>
        <dependency>
            <artifactId>itext-asian</artifactId>
            <version>5.2.0</version>
        </dependency>
创建PDF
	Document document = new Document(PageSize.A2);
    PdfWriter writer = PdfWriter.getInstance(document, new FileOutputStream(filePath));
  	document.addTitle(doc.getDocName());
    document.addAuthor("xxxxx");
    document.addCreationDate();
    document.addLanguage("中文");
    document.open();
设置自定义字体
    File fontFile = new File("font/msyh.ttf");
    BaseFont bf = BaseFont.createFont(fontFile.getAbsolutePath(), BaseFont.IDENTITY_H, BaseFont.EMBEDDED);
    Font fontChinese5 = new Font(bf,14);
添加章节与段落
 	//目录的字体
   Font cataFont = new Font(bf, 24, Font.NORMAL, BaseColor.BLACK);
   // 接口的字体
   Font interFont = new Font(bf, 20, Font.NORMAL, BaseColor.BLACK);
   for(int i=1;i<=10;i++){
		Chapter chapter = new Chapter(new Paragraph("目录", cataFont),i);
        for(int j=1;j<=5;j++){
            Section section = chapter.addSection(new Paragraph("接口", interFont));
        document.add(chapter);
	document.close();
添加表格
  PdfPTable table = new PdfPTable(3);//生成一个3列的表格
  //表格垂直居中
  table.setHorizontalAlignment(Element.ALIGN_CENTER);
  table.setTotalWidth(800f);
  float[] widths = new float[] { 150f,325f,325f };
  table.setWidths(widths);
  PdfPCell cell;
  cell = new PdfPCell(new Paragraph("接口地址",fontChinese5));
  table.addCell(cell);
   cell = new PdfPCell(new Paragraph(interfaceInfoDO.getInterfaceAddress(),fontChinese5));
  cell.setColspan(2);
制表符替换
在pdf生成过程中\t制表符无效导致样式变动,需要进行编码替换replace("\t","\u00a0\u00a0\u00a0\u00a0")
PDF展示
这里选择的是pdf.js进行展示,引用相关文件,地址栏出入file代表url地址即可,因为用于接口文档展示,所以我需要默认进入就是目录模式,所以需要对页面进行相关js处理
<script type="text/javascript">
    var interval = setInterval('loadPdf()', 1000);
    function loadPdf() {
        if (PDFViewerApplication.pdfDocument == null) {
            console.info('Loading...');
            clearInterval(interval);
            console.info('Load Success...');
            var sidebarToggle =   $("#sidebarToggle");
            var viewOutline =   $("#viewOutline");
            if(!sidebarToggle.hasClass("toggled")){
              sidebarToggle.click();
            if(!viewOutline.hasClass("toggled")){
              viewOutline.click();
</script>
展示效果
