SpringCloud微服务实战——搭建企业级开发框架(六):使用knife4j集成Swagger2接口文档
knife4j是为集成Swagger生成api文档的增强解决方案,前后端Java代码以及前端Ui模块进行分离,在微服务架构下使用更加灵活,
提供专注于Swagger的增强解决方案,不同于只是改善增强前端Ui部分,我们这里使用knife4j作为文档管理工具来代替swagger-ui。
1、在GitEgg-Platform工程下新建gitegg-platform-swagger子工程,在GigEgg-Platform中的子工程gitegg-platform-bom中,修改pom
.xml,以maven bom的方式使用knife4j:
<!-- Swagger2 knife4j bom方式引入 -->
<dependency>
<groupId>com.github.xiaoymin</groupId>
<artifactId>knife4j-dependencies</artifactId>
<version>${knife4j.version}</version>
<type>pom</type>
<scope>import</scope>
</dependency>
2、在gitegg-platform-swagger子工程中的pom.xml添加knife4j引用:
<project xmlns="http://maven.apache.org/POM/4.0.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
<parent>
<artifactId>GitEgg-Platform</artifactId>
<groupId>com.gitegg.platform</groupId>
<version>1.0-SNAPSHOT</version>
</parent>
<modelVersion>4.0.0</modelVersion>
<artifactId>gitegg-platform-swagger</artifactId>
<name>${project.artifactId}</name>
<version>${project.parent.version}</version>
<packaging>jar</packaging>
<dependencies>
<dependency>
<artifactId>knife4j-spring-boot-starter</artifactId>
</dependency>
</dependencies>
</project>
3、在gitegg-platform-swagger子工程中新建SwaggerConfig.java文件:
package com.gitegg.platform.swagger.config;
import com.github.xiaoymin.knife4j.spring.annotations.EnableKnife4j;
import org.springframework.context.annotation.Bean;
import org.springframework.context.annotation.Configuration;
import org.springframework.context.annotation.Import;
import springfox.bean.validators.configuration.BeanValidatorPluginsConfiguration;
import springfox.documentation.builders.ApiInfoBuilder;
import springfox.documentation.builders.PathSelectors;
import springfox.documentation.builders.RequestHandlerSelectors;
import springfox.documentation.service.ApiInfo;
import springfox.documentation.spi.DocumentationType;
import springfox.documentation.spring.web.plugins.Docket;
import springfox.documentation.swagger2.annotations.EnableSwagger2;
@Configuration
@EnableSwagger2
@EnableKnife4j
@Import(BeanValidatorPluginsConfiguration.class)
public class SwaggerConfig {
@Bean(value = "GitEggApi")
public Docket GitEggApi() {
Docket docket=new Docket(DocumentationType.SWAGGER_2)
.apiInfo(apiInfo())
//分组名称
.groupName("2.X版本")
.select()
//这里指定Controller扫描包路径
.apis(RequestHandlerSelectors.basePackage("com.gitegg.*.*.controller"))
.paths(PathSelectors.any())
.build();
return docket;
private ApiInfo apiInfo() {
return new ApiInfoBuilder().version("1.0.0")
.title("Spring Cloud Swagger2 文档")
.description("Spring Cloud Swagger2 文档")
.termsOfServiceUrl("www.gitegg.com")
.build();
4、在gitegg-service工程中引入gitegg-platform-swagger
<parent>
<artifactId>GitEgg-Cloud</artifactId>
<groupId>com.gitegg.cloud</groupId>
</parent>
<artifactId>gitegg-service</artifactId>
<packaging>pom</packaging>
<modules>
<module>gitegg-service-base</module>
<module>gitegg-service-bigdata</module>
<module>gitegg-service-system</module>
</modules>
<dependencies>
<!-- gitegg数据库驱动及连接池 -->
<dependency>
<artifactId>gitegg-platform-db</artifactId>
</dependency>
<!-- gitegg mybatis-plus -->
<dependency>
<artifactId>gitegg-platform-mybatis</artifactId>
</dependency>
<!-- gitegg swagger2-knife4j -->
<dependency>
</dependency>
<!-- spring boot web核心包 -->
<dependency>
<artifactId>spring-boot-starter-web</artifactId>
</dependency>
<!-- spring boot 健康监控 -->
<dependency>
<artifactId>spring-boot-starter-actuator</artifactId>
</dependency>
</dependencies>
</project>
5、在gitegg-service-system工程下的SystemController.java类里面添加Swagger2相关注解
package com.gitegg.service.system.controller;
import com.gitegg.service.system.service.ISystemService;
import io.swagger.annotations.Api;
import io.swagger.annotations.ApiOperation;
import lombok.AllArgsConstructor;
import org.springframework.web.bind.annotation.RequestMapping;
@RestController
@RequestMapping(value = "system")
@AllArgsConstructor
@Api(tags = "gitegg-system")
public class SystemController {
private final ISystemService systemService;
@GetMapping(value = "list")
@ApiOperation(value = "system list接口")
public Object list() {
return systemService.list();
@GetMapping(value = "page")
@ApiOperation(value = "system page接口")
public Object page() {
return systemService.page();
6、GitEggSystemApplication.java加入组件扫描的注解,让Spring在启动的时候加载到swagger2的配置:
package com.gitegg.service.system;
import org.mybatis.spring.annotation.MapperScan;
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.SpringBootApplication;
import org.springframework.context.annotation.ComponentScan;
* gitegg-system 启动类
@ComponentScan(basePackages = "com.gitegg")
@MapperScan("com.gitegg.*.*.mapper")
@SpringBootApplication
public class GitEggSystemApplication {
SpringApplication.run(GitEggSystemApplication.class,args);
7、运行gitegg-service-system,打开浏览器访问:http://127.0.0.1:8001/doc.html,可以看到swagger2文档界面
本文源码在 https://gitee.com/wmz1930/GitEgg 的chapter-06分支。
GitEgg-Cloud是一款基于SpringCloud整合搭建的企业级微服务应用开发框架,开源项目地址:
