k8s学习八:pod
仙士可 发表于 2023/06/30 12:22:01 2023/06/30
【摘要】 pod在k8s中,最小单元就是pod了,程序运行部署在容器中,而容器必须存在于pod中pod可以认为是容器的封装,一个pod可以存放一个或者多个容器:root@master:/home/tioncico# kubectl get podsNAME READY STATUS RESTARTS AGEgo-deploym...
pod
go-deployment-86f769995d-frw28   1/1     Running   0             38s
nginx-7cbb8cd5d8-w9tn2           1/1     Running   4 (12d ago)   18d
复制
查看pod详细信息
root@master:/home/tioncico# kubectl describe pod go-deployment
Namespace:    default
Priority:     0
Node:         node-1/192.168.192.10
Start Time:   Mon, 26 Sep 2022 05:56:03 +0000
Labels:       app=go
              pod-template-hash=86f769995d
Annotations:  <none>
Status:       Running
IP:           10.244.1.10
IPs:
  IP:           10.244.1.10
Controlled By:  ReplicaSet/go-deployment-86f769995d
Containers:
  go:
    Container ID:  docker://fa6cfef2511074866a6b626295314cb4b9dc275894ec7d137616d800e1a84bae
    Image:         tioncico/go:v1.0.1
    Image ID:      docker-pullable://tioncico/go@sha256:08271bc1b9ac9317c577bf2888f36c0897996f5bae1085e941dcee62a21a8776
    Port:          8080/TCP
    Host Port:     0/TCP
    Command:
      ./main
      -v
      v1.0.1
    State:          Running
      Started:      Mon, 26 Sep 2022 05:56:11 +0000
    Ready:          True
    Restart Count:  0
    Environment:    <none>
    Mounts:
      /var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-7fcwk (ro)
Conditions:
  Type              Status
  Initialized       True
  Ready             True
  ContainersReady   True
  PodScheduled      True
Volumes:
  kube-api-access-7fcwk:
    Type:                    Projected (a volume that contains injected data from multiple sources)
    TokenExpirationSeconds:  3607
    ConfigMapName:           kube-root-ca.crt
    ConfigMapOptional:       <nil>
    DownwardAPI:             true
QoS Class:                   BestEffort
Node-Selectors:              <none>
Tolerations:                 node.kubernetes.io/not-ready:NoExecute op=Exists for 300s
                             node.kubernetes.io/unreachable:NoExecute op=Exists for 300s
Events:
  Type    Reason     Age    From               Message
  Normal  Scheduled  8m4s   default-scheduler  Successfully assigned default/go-deployment-86f769995d-frw28 to node-1
  Normal  Pulling    8m1s   kubelet            Pulling image "tioncico/go:v1.0.1"
  Normal  Pulled     7m57s  kubelet            Successfully pulled image "tioncico/go:v1.0.1" in 4.542296147s
  Normal  Created    7m57s  kubelet            Created container go
  Normal  Started    7m56s  kubelet            Started container go
复制
可以看到pod有着以下几个关键信息
pod-label
pod-label的作用就是在pod中添加标识,用来对资源进行区分和选择,例如上面的 app=go
同样可以添加版本,环境,架构等等标签  version:"1.0.1"  environment:"dev"
通过label,可以对资源进行筛选,区分
root@master:/home/tioncico# kubectl get pod -l app=go
go-deployment-86f769995d-frw28   1/1     Running   0          13m
复制
pod-namespace
Namespace是kubernetes系统中的一种非常重要资源,它的主要作用是用来实现多套环境的资源隔离或者多租户的资源隔离。
默认情况下,kubernetes集群中的所有的Pod都是可以相互访问的。但是在实际中,可能不想让两个Pod之间进行互相的访问,那此时就可以将两个Pod划分到不同的namespace下。kubernetes通过将集群内部的资源分配到不同的Namespace中,可以形成逻辑上的"组",以方便不同的组的资源进行隔离使用和管理。
可以通过kubernetes的授权机制,将不同的namespace交给不同租户进行管理,这样就实现了多租户的资源隔离。此时还能结合kubernetes的资源配额机制,限定不同租户能占用的资源,例如CPU使用量、内存使用量等等,来实现租户可用资源的管理。
查看列表
root@master:/home/tioncico# kubectl get namespace
NAME                   STATUS   AGE
default                Active   18d //默认的命名空间,没有声明的都会在默认
kube-flannel           Active   18d //k8s flannel插件
kube-node-lease        Active   18d //集群节点心跳维护
kube-public            Active   18d //k8s公共资源你,可以被所有人访问
kube-system            Active   18d //k8s系统创建的资源
kubernetes-dashboard   Active   18d //k8s dashboard
复制
查看详情
root@master:/home/tioncico# kubectl  describe  ns default
Labels:       kubernetes.io/metadata.name=default
Annotations:  <none>
Status:       Active
No resource quota.
No LimitRange resource.
复制
创建
root@master:/home/tioncico#  kubectl create ns dev-test
namespace/dev-test created
复制
删除
root@master:/home/tioncico# kubectl delete ns dev-test
namespace "dev-test" deleted
复制
yaml配置
可通过  kubectl get ns default -o yaml 输出yaml格式的配置项
root@master:/home/tioncico# kubectl get ns default -o yaml
apiVersion: v1
kind: Namespace
metadata:
  creationTimestamp: "2022-09-07T08:11:59Z"
  labels:
    kubernetes.io/metadata.name: default
  resourceVersion: "205"
  uid: d1f23d3c-ed99-41e8-83b3-366e203d2384
spec:
  finalizers:
  - kubernetes
status:
  phase: Active
复制
pod-controller
Pod是kubernetes的最小管理单元,在kubernetes中,按照pod的创建方式可以将其分为两类:
  • 自主式pod:kubernetes直接创建出来的Pod,这种pod删除后就没有了,也不会重建
  • 控制器创建的pod:kubernetes通过控制器创建的pod,这种pod删除了之后还会自动重建
什么是Pod控制器 Pod控制器是管理pod的中间层,使用Pod控制器之后,只需要告诉Pod控制器,想要多少个什么样的Pod就可以了,它会创建出满足条件的Pod并确保每一个Pod资源处于用户期望的目标状态。如果Pod资源在运行中出现故障,它会基于指定策略重新编排Pod。
在kubernetes中,有很多类型的pod控制器,每种都有自己的适合的场景,常见的有下面这些:
  • ReplicationController:比较原始的pod控制器,已经被废弃,由ReplicaSet替代
  • ReplicaSet:保证副本数量一直维持在期望值,并支持pod数量扩缩容,镜像版本升级
  • Deployment:通过控制ReplicaSet来控制Pod,并支持滚动升级、回退版本
  • Horizontal Pod Autoscaler:可以根据集群负载自动水平调整Pod的数量,实现削峰填谷
  • DaemonSet:在集群中的指定Node上运行且仅运行一个副本,一般用于守护进程类的任务
  • Job:它创建出来的pod只要完成任务就立即退出,不需要重启或重建,用于执行一次性任务
  • Cronjob:它创建的Pod负责周期性任务控制,不需要持续后台运行
  • StatefulSet:管理有状态应用
在我之前的文章中,基本是deployment控制器,然后控制replicaSet来控制pod的,其他控制器可以自行了解试试
