Python编写的20个小游戏完整版
赵KK日常技术记录 发表于 2023/06/25 10:26:21 2023/06/25
【摘要】 猜数字游戏pythonimport randomnumber = random.randint(1, 100)guess = int(input('请猜一个1到100之间的数字:'))while guess != number: if guess > number: print('猜大了') else: print('猜小了') guess = ...
  1. 猜数字游戏
python
import random
    if guess > number:
        print('猜大了')
    else:
        print('猜小了')
    guess = int(input('请重新猜一个1到100之间的数字:'))
print('恭喜你,猜对了!')
  1. 石头剪刀布游戏
python
import random
options = ['石头', '剪刀', '布']
computer_choice = random.choice(options)
user_choice = input('请出拳(石头、剪刀、布):')
print('你出了', user_choice)
print('电脑出了', computer_choice)
if user_choice == computer_choice:
    print('平局')
elif user_choice == '石头' and computer_choice == '剪刀' or \
     user_choice == '剪刀' and computer_choice == '布' or \
     user_choice == '布' and computer_choice == '石头':
    print('你赢了')
else:
    print('你输了')
  1. 猜单词游戏
python
import random
words = ['apple', 'banana', 'cherry', 'orange', 'pear']
word = random.choice(words)
letters = set(word)
correct_guesses = set()
incorrect_guesses = set()
tries = 6
while tries > 0 and letters != correct_guesses:
    print('可用次数:', tries)
    print('已猜对的字母:', ' '.join(correct_guesses))
    print('已猜错的字母:', ' '.join(incorrect_guesses))
    guess = input('请猜一个字母:')
    if guess in letters:
        correct_guesses.add(guess)
    else:
        incorrect_guesses.add(guess)
        tries -= 1
if letters == correct_guesses:
    print('恭喜你,猜对了!单词是', word)
else:
    print('很遗憾,你没有猜对。单词是', word)
  1. 猜词游戏
python
import random
shuffle_word = list(word)
random.shuffle(shuffle_word)
print('请猜这个单词:', ''.join(shuffle_word))
guess = input('请输入你的答案:')
if guess == word:
    print('恭喜你,猜对了!')
else:
    print('很遗憾,你没有猜对。正确答案是', word)
5.数字连连看游戏
python
import random
numbers = list(range(1, 9)) * 2
random.shuffle(numbers)
def display_board():
    for i in range(0, 16, 4):
        print(numbers[i:i+4])
def remove_numbers(x1, y1, x2, y2):
    global numbers
    numbers[x1*4+y1] = 0
    numbers[x2*4+y2] = 0
def is_valid_move(x1, y1, x2, y2):
    if x1 == x2 and abs(y1-y2) == 1:
        return True
    if y1 == y2 and abs(x1-x2) == 1:
        return True
    return False
display_board()
while True:
    x1 = int(input('请输入第一个数字的行号(0-3):'))
    y1 = int(input('请输入第一个数字的列号(0-3):'))
    x2 = int(input('请输入第二个数字的行号(0-3):'))
    y2 = int(input('请输入第二个数字的列号(0-3):'))
    if is_valid_move(x1, y1, x2, y2) and numbers[x1*4+y1] == numbers[x2*4+y2]:
        display_board()
        if all(num == 0 for num in numbers):
            print('恭喜你,游戏结束!')
            break
    else:
        print('无效的移动,请重新输入。')
  1. 猜单词游戏(升级版)
python
import random
letters = set(word)
tries = 6
    guess = input('请猜一个字母或整个单词:')
    if len(guess) == 1:
        else:
            tries -= 1
    else:
        if guess == word:
            correct_guesses = letters
        else:
            tries -= 1
else:
  1. 猜数字游戏(升级版)
python
import random
guesses = []
while len(guesses) < 10:
    if guess in guesses:
        print('你已经猜过这个数字了,请重新输入。')
        continue
    guesses.append(guess)
    if guess == number:
        print('恭喜你,猜对了!你用了', len(guesses), '次猜中了这个数字。')
        break
    elif guess < number:
        print('猜小了')
    else:
        print('猜大了')
else:
    print('很遗憾,你没有在规定次数内猜对。正确答案是', number)
这个游戏中,玩家需要在10次之内猜出一个1到100之间的随机数字。每次猜测后,程序会告诉玩家猜的数字是偏大还是偏小,直到玩家猜中这个数字或者用完所有的猜测次数为止。如果玩家在规定次数内猜中了这个数字,则游戏胜利;否则游戏失败。
  1. 猜拳游戏(升级版)
python
import random
wins = {'石头': '剪刀', '剪刀': '布', '布': '石头'}
computer_score = 0
player_score = 0
while True:
    player_choice = input('请出拳(石头、剪刀、布):')
    print('你出了', player_choice)
    if player_choice == computer_choice:
        print('平局')
    elif wins[player_choice] == computer_choice:
        print('你赢了')
        player_score += 1
    else:
        print('你输了')
        computer_score += 1
    print('当前得分:电脑', computer_score, ', 玩家', player_score)
    if computer_score == 3 or player_score == 3:
        break
if computer_score > player_score:
    print('很遗憾,你输了。')
else:
    print('恭喜你,你赢了!')
这个游戏中,玩家和电脑进行猜拳比赛,先达到3分的一方获胜。玩家每次可以选择石头、剪刀或布中的一种,电脑也会随机选择其中的一种。根据石头、剪刀、布之间的胜负关系,程序会判断哪一方获胜,并更新双方的得分。当有一方的得分达到3分时,游戏结束,获得3分的一方获胜。
9.俄罗斯方块
# 导入必要的库
import pygame
import random
# 初始化pygame
pygame.init()
# 定义常量
SCREEN_WIDTH = 800
SCREEN_HEIGHT = 600
BLOCK_SIZE = 30
FONT_SIZE = 36
FPS = 60
# 定义颜色
BLACK = (0, 0, 0)
WHITE = (255, 255, 255)
RED = (255, 0, 0)
GREEN = (0, 255, 0)
BLUE = (0, 0, 255)
YELLOW = (255, 255, 0)
# 定义方块形状
SHAPES = [
    [[1, 1, 1], [0, 1, 0]],
    [[2, 2], [2, 2]],
    [[0, 3, 3], [3, 3, 0]],
    [[4, 4, 0], [0, 4, 4]],
    [[5, 5, 5, 5]],
    [[6, 6, 6], [0, 0, 6]],
    [[7, 7, 7], [7, 0, 0]],
# 定义方块颜色
COLORS = [
    BLUE,
    YELLOW,
    GREEN,
    RED,
    WHITE,
    (255, 165, 0),
    (128, 0, 128),
# 定义方块类
class Block:
    def __init__(self, x, y, shape):
        self.x = x
        self.y = y
        self.shape = shape
        self.color = COLORS[SHAPES.index(shape)]
        self.rotation = 0
    def rotate(self):
        self.rotation = (self.rotation + 1) % len(self.shape)
    def get_matrix(self):
        return self.shape[self.rotation]
    def get_size(self):
        return len(self.get_matrix()), len(self.get_matrix()[0])
    def get_color(self):
        return self.color
# 定义游戏类
class Game:
    def __init__(self):
        self.screen = pygame.display.set_mode((SCREEN_WIDTH, SCREEN_HEIGHT))
        pygame.display.set_caption("俄罗斯方块")
        self.clock = pygame.time.Clock()
        self.font = pygame.font.Font(None, FONT_SIZE)
        self.score = 0
        self.board = [[0] * (SCREEN_WIDTH // BLOCK_SIZE) for _ in range(SCREEN_HEIGHT // BLOCK_SIZE)]
        self.current_block = Block(3, 0, random.choice(SHAPES))
        self.next_block = Block(0, 0, random.choice(SHAPES))
        self.game_over = False
    def draw_block(self, x, y, color):
        pygame.draw.rect(self.screen, color, (x * BLOCK_SIZE, y * BLOCK_SIZE, BLOCK_SIZE, BLOCK_SIZE))
    def draw_board(self):
        for y, row in enumerate(self.board):
            for x, val in enumerate(row):
                if val > 0:
                    self.draw_block(x, y, COLORS[val - 1])
    def draw_current_block(self):
        matrix = self.current_block.get_matrix()
        size_x, size_y = self.current_block.get_size()
        for y in range(size_y):
            for x in range(size_x):
                if matrix[y][x] > 0:
                    self.draw_block(self.current_block.x + x, self.current_block.y + y, self.current_block.get_color())
    def draw_next_block(self):
        matrix = self.next_block.get_matrix()
        size_x, size_y = self.next_block.get_size()
                    self.draw_block(x + SCREEN_WIDTH // BLOCK_SIZE + 2, y + SCREEN_HEIGHT // BLOCK_SIZE // 2, self.next_block.get_color())
    def draw_score(self):
        score_text = self.font.render("Score: {}".format(self.score), True, WHITE)
        self.screen.blit(score_text, (10, 10))
    def check_collision(self, block, dx=0, dy=0):
        matrix = block.get_matrix()
        size_x, size_y = block.get_size()
                    if block.x + x + dx < 0 or block.x + x + dx >= SCREEN_WIDTH // BLOCK_SIZE:
                        return True
                    if block.y + y + dy >= SCREEN_HEIGHT // BLOCK_SIZE:
                        return True
                    if self.board[block.y + y + dy][block.x + x + dx] > 0:
                        return True
        return False
    def merge_block(self, block):
                    self.board[block.y + y][block.x + x] = matrix[y][x]
    def remove_lines(self):
    lines_removed = 0
    y = SCREEN_HEIGHT // BLOCK_SIZE - 1
    while y >= 0:
        if all(self.board[y]):
            lines_removed += 1
            for y2 in range(y, 0, -1):
                self.board[y2] = self.board[y2 - 1][:]
            self.board[0] = [0] * (SCREEN_WIDTH // BLOCK_SIZE)
        else:
            y -= 1
    self.score += lines_removed * 100
    def update(self):
        if not self.check_collision(self.current_block, dy=1):
            self.current_block.y += 1
        else:
            self.merge_block(self.current_block)
            self.remove_lines()
            self.current_block = self.next_block
            if self.check_collision(self.current_block):
                self.game_over = True
    def handle_events(self):
        for event in pygame.event.get():
            if event.type == pygame.QUIT:
            if event.type == pygame.KEYDOWN:
                if event.key == pygame.K_LEFT and not self.check_collision(self.current_block, dx=-1):
                    self.current_block.x -= 1
                if event.key == pygame.K_RIGHT and not self.check_collision(self.current_block, dx=1):
                    self.current_block.x += 1
                if event.key == pygame.K_UP:
                    self.current_block.rotate()
                if event.key == pygame.K_DOWN and not self.check_collision(self.current_block, dy=1):
    def run(self):
        while not self.game_over:
            self.screen.fill(BLACK)
            self.draw_board()
            self.draw_current_block()
            self.draw_next_block()
            self.draw_score()
            pygame.display.update()
            self.handle_events()
            self.update()
            self.clock.tick(FPS)
        pygame.quit()
if __name__ == "__main__":
    game = Game()
    game.run()
10贪吃蛇代码
# 导入必要的库
import pygame
import random
# 初始化pygame
pygame.init()
# 定义颜色
BLACK = (0, 0, 0)
RED = (255, 0, 0)
GREEN = (0, 255, 0)
BLUE = (0, 0, 255)
# 设置屏幕大小
SCREEN_WIDTH = 800
SCREEN_HEIGHT = 600
# 创建屏幕
pygame.display.set_caption("贪吃蛇")
# 定义蛇的初始位置和大小
snake_block_size = 10
snake_speed = 15
snake_list = []
snake_length = 1
snake_x = SCREEN_WIDTH / 2
snake_y = SCREEN_HEIGHT / 2
# 定义食物的初始位置和大小
food_block_size = 10
food_x = round(random.randrange(0, SCREEN_WIDTH - food_block_size) / 10.0) * 10.0
food_y = round(random.randrange(0, SCREEN_HEIGHT - food_block_size) / 10.0) * 10.0
# 定义字体
font_style = pygame.font.SysFont(None, 50)
# 定义分数
score = 0
# 定义游戏结束函数
def game_over():
    message = font_style.render("游戏结束", True, RED)
    screen.blit(message, [SCREEN_WIDTH / 3, SCREEN_HEIGHT / 3])
    pygame.time.delay(2000)
# 游戏循环
game_over_flag = False
while not game_over_flag:
            game_over_flag = True
        # 控制蛇的移动
            if event.key == pygame.K_LEFT:
                snake_x_change = -snake_block_size
                snake_y_change = 0
            elif event.key == pygame.K_RIGHT:
                snake_x_change = snake_block_size
                snake_y_change = 0
            elif event.key == pygame.K_UP:
                snake_y_change = -snake_block_size
                snake_x_change = 0
            elif event.key == pygame.K_DOWN:
                snake_y_change = snake_block_size
                snake_x_change = 0
    # 控制蛇的移动
    snake_x += snake_x_change
    snake_y += snake_y_change
    # 判断蛇是否吃到食物
    if snake_x == food_x and snake_y == food_y:
        snake_length += 1
        score += 10
    # 绘制食物
    pygame.draw.rect(screen, GREEN, [food_x, food_y, food_block_size, food_block_size])
    # 绘制蛇
    snake_head = []
    snake_head.append(snake_x)
    snake_head.append(snake_y)
    snake_list.append(snake_head)
    if len(snake_list) > snake_length:
        del snake_list[0]
    for x in snake_list[:-1]:
        if x == snake_head:
    for x in snake_list:
        pygame.draw.rect(screen, BLUE, [x[0], x[1], snake_block_size, snake_block_size])
    # 绘制分数
    score_message = font_style.render("分数: " + str(score), True, BLACK)
    screen.blit(score_message, [0, 0])
    # 更新屏幕
    # 判断蛇是否撞墙
    if snake_x >= SCREEN_WIDTH or snake_x < 0 or snake_y >= SCREEN_HEIGHT or snake_y < 0:
    # 控制游戏速度
    pygame.time.delay(snake_speed)
# 结束pygame
pygame.quit()
这里需要补充一下 snake_x += snake_x_change snake_y += snake_y_change的初始化
11雷霆战机(待编写)
import pygame
import random
# Initialize Pygame
pygame.init()
# Set the screen size
screen_width = 480
screen_height = 700
screen = pygame.display.set_mode((screen_width, screen_height))
# Set the window title
pygame.display.set_caption("Thunder Plane")
# Load the background image
background = pygame.image.load("images/background.png")
# Load the player image
player = pygame.image.load("images/me1.png")
# Set the player's initial position
player_rect = player.get_rect()
player_rect.left = (screen_width - player_rect.width) // 2
player_rect.top = screen_height - player_rect.height - 60
# Set the player's movement speed
player_speed = 10
# Load the enemy images
enemy1 = pygame.image.load("images/enemy1.png")
enemy2 = pygame.image.load("images/enemy2.png")
enemy3 = pygame.image.load("images/enemy3.png")
# Set the enemy's initial position and movement speed
enemies = []
enemy_speed = 2
for i in range(5):
    enemy_rect = enemy1.get_rect()
    enemy_rect.left = random.randint(0, screen_width - enemy_rect.width)
    enemy_rect.top = random.randint(-5 * enemy_rect.height, -enemy_rect.height)
    enemies.append({"rect": enemy_rect, "image": enemy1})
# Set the game clock
# Set the score
score = 0
# Set the font
font = pygame.font.Font(None, 36)
# Set the game over flag
game_over = False
# Start the game loop
while not game_over:
    # Handle events
            game_over = True
    # Move the player
    keys = pygame.key.get_pressed()
    if keys[pygame.K_LEFT]:
        player_rect.left -= player_speed
    if keys[pygame.K_RIGHT]:
        player_rect.left += player_speed
    if keys[pygame.K_UP]:
        player_rect.top -= player_speed
    if keys[pygame.K_DOWN]:
        player_rect.top += player_speed
    # Keep the player within the screen bounds
    if player_rect.left < 0:
        player_rect.left = 0
    if player_rect.right > screen_width:
        player_rect.right = screen_width
    if player_rect.top < 0:
        player_rect.top = 0
    if player_rect.bottom > screen_height:
        player_rect.bottom = screen_height
    # Move the enemies
    for enemy in enemies:
        enemy["rect"].top += enemy_speed
        if enemy["rect"].top > screen_height:
            enemy["rect"].left = random.randint(0, screen_width - enemy["rect"].width)
            enemy["rect"].top = random.randint(-5 * enemy["rect"].height, -enemy["rect"].height)
    # Check for collisions
        if player_rect.colliderect(enemy["rect"]):
            game_over = True
    # Draw the background
    screen.blit(background, (0, 0))
    # Draw the player
    screen.blit(player, player_rect)
    # Draw the enemies
        screen.blit(enemy["image"], enemy["rect"])
    # Draw the score
    score_text = font.render("Score: {}".format(score), True, (255, 255, 255))
    # Update the screen
    clock.tick(60)
# Quit Pygame
pygame.quit()
