Python最全最常用的日期工具类(随时更新)
赵KK日常技术记录 发表于 2023/06/24 22:17:53 2023/06/24
【摘要】 import datetime FORMAT_YYYYMMDDHHMMSS = "yyyy-MM-dd HH:mm:ss";FORMAT_YYYY_MM_DD = "yyyy-MM-dd";FORMAT_YYMMDD = "yyyyMMdd"; /** * 把日期格式化为yyyy-MM-dd HH:mm:ss字符串 * * @param date * @ret...
import datetime
     * @param date
     * @return
def formatTime(date):
    sdf = datetime.datetime.strptime(date, FORMAT_YYYYMMDDHHMMSS)
    return sdf.strftime(FORMAT_YYYYMMDDHHMMSS)
     * 把日期格式化为pattern字符串
     * @param date
     * @param pattern
     * @return
def formatTime(date, pattern):
    sdf = SimpleDateFormat(pattern)
    return sdf.format(date)
# 把日期字符串转换为yyyy-MM-dd HH:mm:ss或者yyyy-MM-dd格式的日期
def tDate(date):
    if date is None:
        return None
    if '-' in date:
        sdf = datetime.datetime.strptime(date, '%Y-%m-%d')
    else:
        sdf = datetime.datetime.strptime(date, '%Y%m%d%H%M%S')
    return sdf
def tDate(date, pattern):
    if date is None:
        return None
    sdf = datetime.datetime.strptime(date, pattern)
    return sdf
def getTodayStartTime():
    now = datetime.datetime.now()
    todayStart = now.replace(hour=0, minute=0, second=0, microsecond=0)
    formatter = '%Y-%m-%d %H:%M:%S'
    return todayStart.strftime(formatter)
# 日期加减法
def addDate(date, day):
    return (datetime.datetime.strptime(date, '%Y-%m-%d') + datetime.timedelta(days=day)).strftime('%Y-%m-%d')
