还在手动写单元测试?
赵KK日常技术记录 发表于 2023/06/21 18:27:31 2023/06/21
【摘要】 JUnitGenerator安装在Idea市场里安装JUnitGenerator插件如图,重启后生效 设置生成路径及模板Output Path: SOURCEPATH/..//../test/java/{SOURCEPATH}/..//../test/java/SOURCEPATH/..//../test/java/{PACKAGE}/${FILENAME}注:根据实际项目结构调整,设置为...
JUnitGenerator安装
流程
设置生成路径及模板
Output Path: S O U R C E P A T H / . . / / . . / t e s t / j a v a / {SOURCEPATH}/..//../test/java/ {PACKAGE}/${FILENAME}
注:根据实际项目结构调整,设置为默认模板,另需要在Project Structure–>Modules中设置Test文件目录,可改造为自启动,随容器启动,
流程
设置Junit4 生成模板
支持 CommonResponse 或 Wrapper
#macro (cap $strIn)$strIn.valueOf($strIn.charAt(0)).toUpperCase()$strIn.substring(1)#end
#foreach ($entry in $entryList)
#set( $testClass="${entry.className}Test")
package $entry.packageName;
import java.util.*;
import org.junit.Test;
import org.junit.Before;
import org.junit.After;
import org.springframework.http.ResponseEntity;
 * BSF+Junit4
 * @Creator zhaokk
 * @CreateDate ${Date}
 * @DESC
 @SuppressWarnings("all")
public class $testClass {
     public final String ipAndPort="localhost:8080/";
    public final String token="login-token";
    public final String extend = "extend";
    private static HttpHeaders requestHeaders;
    @Before
    public void before() throws Exception {
        requestHeaders = new HttpHeaders();
        requestHeaders.add("token", token);
        requestHeaders.add("", "");
        JunitUtils.setRequestHeaders(requestHeaders);
    @After
    public void after() throws Exception {
#foreach($method in $entry.methodList)
    * Method: $method.signature
    @Test
    public void test#cap(${method.name})() throws Exception {
        //Make request
        TestEntity testEntity=JunitUtils.checkRequest(ipAndPort,token);
        //Show Controller & Mehtod
        //FIXME new $entry.packageName.${entry.className}().${method.name}();
        //Model 1 (Parameter is url)
        //Map<String,String> objectRequest=new HashMap();
        //objectRequest.put("{id}","1000000157729");
        //testEntity.setRequestObj(objectRequest);
        //Model 2 (Parameter is Object)
        //UserLoginReq objectRequest = new UserLoginReq();//JSON.parseObject("jsonString",UserLoginReq.class)
        //objectRequest.setUsername("18311140968");
        //objectRequest.setPassword("aa123456");
        //Model 3 (Parameter is url & Object)
        //Map<String,String> urlMap=new HashMap();
        //urlMap.put("{pageNo}","1");
        //urlMap.put("{pageSize}","10");
        //model 1  and model 2 (ResponseEntity)
        ResponseEntity<CommonResponse> responseResponseEntity=JunitUtils.getResponseEntity(testEntity);
	//model 3 (ResponseEntity)
        //ResponseEntity<CommonResponse> responseResponseEntity=JunitUtils.getResponseEntity(urlMap,testEntity);
        //ResponseEntity To Object
        //CommonResponse<UserResp> response = responseResponseEntity.getBody();
        //Check CommonResponse code is 200000
        JunitUtils.checkResponse(responseResponseEntity.getBody());
#end
#foreach($method in $entry.privateMethodList)
@Test
//TODO: Test goes here...
#foreach($string in $method.reflectionCode)
$string
#end
#end
#end
代码块1:根据ipAndPort和token 拼装基础的URL和请求头
代码块2:工具块,方便快速跳转到本方法的源头
代码块3:模式1参数封装,一般用于GET 和DELETE 请求,纯URL
代码块4:模式2参数封装,一般用于POST和PUT 请求,纯对象。支持Json字符串,如下:
         UpdateUserByPKReq objectRequest = JunitUtils.jsonToObject("{\"name\":\"接口测试-勿删\",\"userNumber\":\"1573195928331\"",UpdateUserByPKReq.class);
代码块5:模式1和模式2的组合,拼装URL+对象
代码块6:适用于模式1和模式2,进行具体的请求并获得响应结果
代码块7:适用于模式3,进行具体的请求并获得响应结果
代码块8:检查响应结果,默认200000为成功,如果非200000失败。如有多个状态码均为成功,可以增加成功状态码进行入参,
         如下:JunitUtils.checkResponse(responseResponseEntity.getBody(),600220)
这里可自行改造为
 * @author zhaokk
 * @create ${Date}
@RunWith(SpringJUnit4ClassRunner.class)
@SpringBootTest(classes = com.xxx.class)
@Slf4j
workspace.xml中加入
<component name="PropertiesComponent">
    <property name="dynamic.classpath" value="true" />
流程
不知道大家有没有用有道云笔记的没有,经常性的新打开的笔记会在首行,但除了阅读之外,应该在最后一行继续编辑,所有大多情况下需要鼠标滑动到行尾,搜索过很多方法,不如Ctrl+A,然后→右箭头好用。mark
