分享几个nginx配置文件(没有fpm配置)
仙士可 发表于 2023/06/21 17:31:39 2023/06/21
【摘要】 1950编辑删除单swoole反向代理配置server{ listen 80; server_name 域名(空格分隔可多个); location ~ ^/(\.user.ini|\.htaccess|\.git|\.svn|\.project|LICENSE|README.md) { return 404; } client_max_bod...
1950
删除
单swoole反向代理配置
server
    listen 80;
        return 404;
    client_max_body_size 20m;
    location / {
        proxy_pass_request_body on;
        proxy_pass_request_headers on;
        proxy_pass 代理地址:端口号;
        proxy_http_version 1.1;
        proxy_set_header Upgrade $http_upgrade;# 支持ws
        proxy_set_header Connection "Upgrade";#支持ws
复制
ssl swoole反向代理
server
    listen 443 ssl http2;
    server_name 域名;
    ssl_certificate  /ssl.pem证书地址;
    ssl_certificate_key  /ssl.key证书key地址;
    ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
    ssl_ciphers EECDH+CHACHA20:EECDH+AES128:RSA+AES128:EECDH+AES256:RSA+AES256:EECDH+3DES:RSA+3DES:!MD5;
    ssl_prefer_server_ciphers on;
    ssl_session_cache shared:SSL:10m;
    ssl_session_timeout 10m;
        return 404;
    location / {
server {
    listen 80;
    server_name 域名;
    location / {
        rewrite ^/(.*)$ https://域名/$1 permanent;##由http自动跳转到https
复制
vue代理网站
server
    listen 80;
        return 404;
    location / {
      try_files $uri $uri/ @rewrites;
    location @rewrites {
      rewrite ^(.+)$ /index.html last;
    location ~* \.(?:htm|html)$ {
      add_header Cache-Control "private, no-store, no-cache, must-revalidate";
    location ~* \.(?:ico|css|js|gif|jpe?g|png|svg|ttf|woff|eot|crx)$ {
      expires max;
      add_header Pragma public;
      add_header Cache-Control "public, must-revalidate, proxy-revalidate";
复制
