ssh实现秘钥登陆
仙士可 发表于 2023/06/21 17:29:23 2023/06/21
【摘要】 2行命令ssh-keygen #生成本地秘钥ssh-copy-id -i ~/.ssh/id_rsa.pub root@ip地址复制输入密码,即可将公钥追加到新的服务器中[root@MiWiFi-RA69-srv ~]# ssh-copy-id -i ~/.ssh/id_rsa.pub root@47.106.110.119/usr/bin/ssh-copy-id: INFO: Source...
2行命令
ssh-keygen #生成本地秘钥
复制
输入密码,即可将公钥追加到新的服务器中
/usr/bin/ssh-copy-id: INFO: Source of key(s) to be installed: "/root/.ssh/id_rsa.pub"
/usr/bin/ssh-copy-id: INFO: attempting to log in with the new key(s), to filter out any that are already installed
/usr/bin/ssh-copy-id: INFO: 1 key(s) remain to be installed -- if you are prompted now it is to install the new keys
root@47.106.110.119's password:
Number of key(s) added: 1
Now try logging into the machine, with:   "ssh 'root@47.106.110.119'"
and check to make sure that only the key(s) you wanted were added.
复制
