自用swoole环境dockerfile
仙士可 发表于 2023/06/21 17:17:37 2023/06/21
【摘要】 包含了基础的库,ssh 服务,composerFROM centos:8#version definedENV SWOOLE_VERSION 4.4.23#install libsRUN yum -y updateRUN yum install -y curl zip unzip wget openssl-devel gcc-c++ make autoconf git passwd#ins...
FROM centos:8
#version defined
#install libs
RUN yum -y update
#install php
RUN yum install -y php-devel php-openssl php-mbstring php-json php-simplexml php-gd
# composer
RUN curl -sS https://getcomposer.org/installer | php \
    && mv composer.phar /usr/bin/composer && chmod +x /usr/bin/composer
# use aliyun composer
RUN composer config -g repo.packagist composer https://mirrors.aliyun.com/composer/
CMD ["systemctl","restart","sshd"]
#安装ssh服务
RUN yum install -y openssh-server
RUN mkdir -p /var/run/sshd
RUN mkdir -p /root/.ssh
#取消pam限制
RUN sed -ri \
"s/session required pam_loginuid.so/#session required pam_loginuid.so/g" /etc/pam.d/sshd
RUN wget https://github.com/swoole/swoole-src/archive/v${SWOOLE_VERSION}.tar.gz -O swoole.tar.gz \
    && mkdir -p swoole \
    && tar -xf swoole.tar.gz -C swoole --strip-components=1 \
    && rm swoole.tar.gz \
    cd swoole \
    && phpize \
    && ./configure --enable-openssl \
    && make \
    && make install \
    && sed -i "2i extension=swoole.so" /etc/php.ini \
    && rm -r swoole
# Dir
VOLUME /work
WORKDIR /work
EXPOSE 9501 22
复制
评论(0
